Old 11-06-2013, 06:40 AM   #256
RoundOz
Plenty of seasoning
Oddometer: 1,014
Originally Posted by bikyto View Post
That's good info about the Snapout and Safari combo, I was wondering as the safari are not perfect like you mentioned. Thank you.
I would prefer if the snapout lock wasn't centered in the middle of the compartment but perhaps right under the oem fuse block. Maybe i'll modify one to make it work like that. hum.....
The supplied fastener is flush and doesnt get in the way...of course you may have other uses for the real estate for something else, or not wish to unpack the glovebox before dismounting it. Something to keep in mind is that the Snapout plate offers a convenient place to mount other electrical gear, such as more terminals or fuses, either on its face or below it using an angle bracket. Next time I take the glovebox off i will have to cut/file two small slots for the fusebox cover catches to fit through...I think this will allow the cover to go back on. Maybe this is detailed in the instructions but I was a typical male and didnt read them...
Being able to leave the fusebox in place during airfilter/valve services etc is just another added convenience, as is the amount of space opened up by removing the airbox. Hmmm...I will have to check if I can access the front spark plug now....that would be a big bonus too.
My Dogbox will be used to keep spares - regulator, start relay, clutch and brake levers, or maybe a tube. Nice to know these things are with the bike at all times. I used to keep my tubes in my fairing "pockets", but the Safaris have me revising that...
2009 KTM Adventure
RoundOz is offline   Reply With Quote
Old 11-06-2013, 12:20 PM   #257
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,190
Yes I have a fuse block installed in the compartment with a couple Deutsche connectors so that I can unplug it on the back side in 5 sec.
I'd like to keep it there. I could see about relocating it but… I like that access. Maybe I'll mount it on the back side… hum…
The front spark plug is accessible with tiny hands. I end up loosening the radiator a bit…
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 11-07-2013, 07:06 AM   #258
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,439
I have a fuze block in there too, and I don't have the handy disconnects.
It was in the way of the snap out, and was velcroed to the glovebox. I just replaced the Velcro with a ziptie run through a couple of holes in the bottom of the box to keep it in place; now if I want to take the glovebox off I just cut the ziptie and the fuzebox moves right out of the way. Gotta remember to replace the ziptie before the box goes back on, do up the dzus fastener then pull the ziptie tight.
I may look at relocating the fuzebox under the glovebox this winter but it's working fine for me this way for now.
SA
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 11-09-2013, 11:39 AM   #259
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,411
Ok, just burnt though my first tank of gas with the new filter and MAP and all i gotta say is WTF?
low fuel light came on at 82 miles.
please tell me i've done something wrong because that is just unacceptable. power is great but being stranded because my bike cant make it to the next station is not cool.
what are you guys getting for MPG with the CPR filter?
thanks,
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 11-09-2013, 11:48 AM   #260
LocuL
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,332
Open the other tank...
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is offline   Reply With Quote
Old 11-09-2013, 12:08 PM   #261
mountain eagle
terrorist
mountain eagle's Avatar
Oddometer: 2,921
I once ran out of gas in 75 miles.......... and that was before the filter swap. Also before the 2-1 and aux tank........
Since the filter I haven't noticed much change in the 35-45 mpg I was getting before, once I adjusted the jets. It's quite wrist variable.
thanks,
laramie
mountain eagle
08'Husky TE610 x 2 TE/SM
KTM 950SE
my smugmug gallery
How can it be fun if there's not at least an outside chance of dying?
mountain eagle is offline   Reply With Quote
Old 11-09-2013, 12:20 PM   #262
smitty141
smitty141's Avatar
Oddometer: 661
thanks,
laramie
I have only burned a couple tanks on mine. Got 38 on first and 37 on the second..
Smitty
RIP.. Skinny Dave...RIP.. Chester_______________
2015 KTM 690r Enduro, 2010 BMW 800gs. 2008 Suzuki DRZ400SM, 2004 KTM 450 EXC
smitty141 is offline   Reply With Quote
Old 11-09-2013, 12:50 PM   #263
RoundOz
Plenty of seasoning
Oddometer: 1,014
Yeah...what he said....you wd have to have raw fuel coming out the pipe....
2009 KTM Adventure
Old 11-09-2013, 02:54 PM   #264
laramie LC4
crash test dummy!
Oddometer: 2,411
win a chicken dinner!
neither of the tanks were fully open. not sure what i did but i swore i had opened them back up. rode all week to work and back without issues. cant believe i didn't have problems before.
thanks guys, panic relieved....
laters,
laramie
Old 11-09-2013, 08:36 PM   #265
bikyto
bikyto's Avatar
Oddometer: 2,190
SA
Thanks a lot!
Looks like I'm going to put it down there as well :)
Old 11-10-2013, 07:28 PM   #266
skidxr
Excuses
skidxr's Avatar
Oddometer: 394
laters,
laramie
I sort of had the same problem but it turned out the fuel tap screw was just spinning. It would open and if you kept turning it would close again. 20 bucks for a new one.
skidxr is offline   Reply With Quote
Old 11-15-2013, 03:35 AM   #267
Resnais
Resnais's Avatar
Oddometer: 25
Water crossin
How deep we can ride with cpr???
http://advrider.com/forums/showthread.php?t=934427
Resnais is offline   Reply With Quote
Old 11-15-2013, 12:53 PM   #268
Spark01
V-Twin
Spark01's Avatar
Oddometer: 305
Originally Posted by Resnais View Post
The height of the standard intake stack are about the same height as the height of the original intake snorkel.
So not much of a big difference and when you would drop your bike into water the intake is much easier to clean and dry with a CPR then with the original air filter box.
'10 990SMT
Spark01 is offline   Reply With Quote
Old 11-15-2013, 02:23 PM   #269
laramie LC4
crash test dummy!
Oddometer: 2,411
ok, this time i actually burned through the whole tank...
went 160 miles on 4.3 gallons of gas = 37.3 MPG
not too shabby considering i wasn't exactly what you would call light on the throttle. bike is running like a champ and i couldn't be happier. i bet on a nice, steady throttle ride i will easily get 40+ MPG.
laters,
laramie
Old 12-26-2013, 09:44 AM   #270
ÖÖ.
Ajaa kuin mummo
ÖÖ.'s Avatar
Oddometer: 280
This Rottweiler setup with all the extras looks so good. But I'm still wondering about few things which are keeping me away from the "pay with paypal" -button.
How do you prevent water entering the engine when washing the bike or leaving it standing in the rain? Or is that a problem at all?
People driving in places where they use salt on the road, do you have any signs of corrosion on your carbs / tb's?
Pics and vids
ÖÖ. is offline   Reply With Quote
Times are GMT -7.   It's 09:59 PM.
