Old 08-06-2013, 08:43 PM   #1
TMoore OP
Arai Test Dummy
TMoore's Avatar
Oddometer: 218
Help! 950 leaking oil pressure switch...
I'm on the road heading back from Alaska. I noticed oil leaking that I strongly suspect to be the oil pressure switch (original @ 37k miles....I know, I'm kicking myself for not replacing it). I'm in Watson Lake Yukon. Its not leaking too bad but I'm wondering if it will get worse or stay same? Nearest dealer is 680 miles. I'm thinking about just sticking an M10X1 bolt in it here in the hotel parking lot instead of soldering on and adding oil. That's assuming I can source a bolt. Even if the bolt weeps its better than the leak I have.
Opinions/experience welcome.
Tim
KTM->2014 450 XCW, 2008 690 SMC, 2004 950 ADV
2012 Ducati Pikes Peak Multistrada 1200
2009 BMW R1200RT
2001 Aprilia RSVR Mille
TMoore is offline   Reply With Quote
Old 08-06-2013, 09:12 PM   #2
Tha Rick
Shake and bake!
Tha Rick's Avatar
Oddometer: 5,472
Grab an extra quart of oil on your way to the dealer..top it off about every 150 miles, more often if it goes low before then.
Have a great trip!
Happy Trails Y'all.
It's not about tha bike nor tha ride; it's about tha adventure in life we all seek. Great memories are made of taking tha trail less traveled and explored.
Tha Rick is offline   Reply With Quote
Old 08-06-2013, 09:49 PM   #3
Newbusa
Newbusa's Avatar
Oddometer: 620
I rode back 600 miles with mine leaking,Just keep an eye on it and top up as needed,over the 600 miles home it never did get worse.
2010 990R Adventurer.
2007 Tuono 1000R
Newbusa is offline   Reply With Quote
Old 08-06-2013, 10:00 PM   #4
TMoore OP
Arai Test Dummy
TMoore's Avatar
Oddometer: 218
I need to go about 1700 miles back to my truck & trailer in Yakima WA. If I keep riding its going to drive me nuts! I just checked the dipstick and is about 2/5th of the way from full to the bottom of the dip stick. I figure that leaked over about 360 miles, maybe 400.
2009 BMW R1200RT
Old 08-06-2013, 11:26 PM   #5
TcRulz
Oddometer: 289
Mine never got any better or any worse...just kept leaking. I'm not sure how far the dipstick is off the bottom of the tank but it holds about 2.25 litres (so it's a fair bit).
TcRulz is offline   Reply With Quote
Old 08-07-2013, 04:26 AM   #6
adiablolex
Lost again
adiablolex's Avatar
Oddometer: 3,692
got in a similar scenario 2500K from home and I just substituted for a bolt, worked fine.
In a pinch you can also remove the electrical end of the sensor and fill with JB weld.
Mine was leaking profusely so had to be changed before I continued my trip.
Good luck with it man
DRCOOL rides with me
adiablolex is offline   Reply With Quote
Old 08-07-2013, 10:03 PM   #7
TMoore OP
Arai Test Dummy
TMoore's Avatar
Oddometer: 218
I tried to get to the thing in the hotel parking lot. Took the tank off but it looked like I either need to pull the carbs/air box or a couple radiator hoses to get access? I don't have the tools for that. I ended up adding some oil and riding it to Fort Nelson. It made a mess but there is still plenty of oil in the tank. Will attempt Grande Prairie tomottow. Trying to make it to Canmore where I have a truck available.
2009 BMW R1200RT
Old 08-08-2013, 09:18 PM   #8
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,585
a rather small amount of oil will "make a mess". so, .5 L (basically half a quart) will make a REALLY wet mess. Stay on top of it at each fuel stop and keep topping it off until you can get to a area where you can get to it without causing other issues. Yes, you have to remove the carbs/airbox. I have not been able to find the automotive crossover YET....
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 08-13-2013, 02:15 PM   #9
stickysidedown
stickysidedown's Avatar
Oddometer: 661
Just had the same go on mine somewhere in The Czech Republic on the way back home to the UK, Everything that is in the stock tool kit is there to get at the sensor, I replaced mine with a drain plug from an exc radiator that fitted
weirdly it didnt seem to lose much oil until I stopped the motor (backpressure?)
In my case I pulled the tanks, glove box, I moved the airbox and throttle bodies and to do this I needed to remove throttle cables (gaining necessary slack by removing from throttle tube on the bars) and unplug the large grey plug on the RHS of the frame that goes to the throttle bodies
All in all it was a couple hours playing with the stock toolkit which continually surprises me with its efficacy
stickysidedown is offline   Reply With Quote
Old 09-14-2013, 09:42 AM   #10
mamacone
mamacone's Avatar
Oddometer: 149
What Leaks on the Oil Pressure Switch?
What actually leaks on the Oil Pressure Switch? Have been searching and have not seen an explanation. What kind of mileage before the oil pressure switch leaks?. My of 04 has 28,000 miles and leaked 16 oz over 10 plus hours of ride time. Sounds like it should become a preventive maintenance item.
13 500 EXC
04 950 adventure
00 300 exc plated
mamacone is offline   Reply With Quote
Old 09-14-2013, 09:55 AM   #11
DADODIRT
DADODIRT's Avatar
Oddometer: 3,559
Hope TMoore made it back.
Not sure why he needed to remove the tank though. If I am correct, the oil pressure switch is behind the drive sprocket. New o-ring should be all you need. Correct me if I'm wrong.
I find your lack of faith in the force disturbing.
DADODIRT is offline   Reply With Quote
Old 09-14-2013, 10:28 AM   #12
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,970
The oil pressure switch is on the side of the front cylinder, inside the "V". It is a standard Automotive pressure switch so automotive parts place should have one (eg NAPA).
The switch is just a bakelite switch pressed into a metal body, it leaks between the bakelite and the body. You can replace it by just removing the left side tank, but it is much easier to remove the airbox to get at it.
Consider yourself corrected :-) that is the gearshift/neutral switch.
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema is offline   Reply With Quote
Old 09-14-2013, 10:34 AM   #13
Katoom72
Katoom72's Avatar
Oddometer: 900
Anyone tried putting liquid gasket ontop of it?
Mine is fine but just thinking of options if it would happen on a trip. (yes i bring liquid gasket on my trips )
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is online now   Reply With Quote
Old 09-14-2013, 11:27 AM   #14
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,970
It might work. The leak is normally slow and you should be able to get a replacement in short order, even in less developed places.
Old 09-16-2013, 03:42 PM   #15
TMoore OP
Arai Test Dummy
TMoore's Avatar
Oddometer: 218
Yeah I rode it 1500 miles back to Canmore Alberta. It leaked about
300 ml over that time and made a pretty nasty mess. At least the
chain stayed oiled! Back at home in Massachusetts now with a
new switch installed. I pulled the airbox/carbs. I don't see how it can
be done without doing that.
Thanks for your help guys.
T
2009 BMW R1200RT
Times are GMT -7.   It's 05:17 PM.
