Old 11-24-2013, 01:02 PM   #46
Zander
Zander's Avatar
Oddometer: 194
Originally Posted by DirtyADV View Post
Had some nylon plastic laying around, so made a try making a snap out dog house:
/Johan
Nice work. Great improvement on the original design.
Beginner's mind !
KTM 950
Zander is offline   Reply With Quote
Old 11-24-2013, 02:28 PM   #47
DirtyADV OP
DirtyADV's Avatar
Oddometer: 2,324
Soon my bike will be disassembled without tools ...maybe not.
But would like to get hold of a winged style DZUS that would fit the glove compartment with the snap out bracket, had some but they are a smaller size.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 11-26-2013, 02:14 PM   #48
DirtyADV OP
DirtyADV's Avatar
Oddometer: 2,324
Tried lifting the front wheel some when filling coolant since there won't be any wheelie until the spring:
So once the bikes were buttoned back up and I had played a little with TuneECU it was time for a test start:
But there is some strange high pitch sound from the new bike.
Hope its just the clutch, did try to skip the extra thin friction plate at the bottom of the stack and the steel place showed some wear for the bent spacer washer spring thingie.
And the old 950 had cam chain clatter as after an oil change, have noticed that before after its been on its side.
Any thoughts about the strange sound? Please say!
Cheers!
/Johan
Old 12-01-2013, 02:45 PM   #49
DirtyADV OP
DirtyADV's Avatar
Oddometer: 2,324
Have some new friction plates on the way for the old bike to get it working.
Ran into an issue with the seat, missing one rubber spacer (well have 3 seats so no problem right now).
But would like to get hold of one so they are all complete but can find this rubber piece as a spare part?
Adding another question also anyone use the glovebox for First Aid kit? And can direct me to a suitable kit that will fit there?
/Johan
Old 12-01-2013, 03:26 PM   #50
Zander
Zander's Avatar
Oddometer: 194
/Johan
For day ride: http://www.mec.ca/product/5003-378/a...&q=first%2Baid
This is what I use for long / group rides : http://www.mec.ca/product/5003-379/a...&q=first%2Baid
Beginner's mind !
KTM 950
Old 12-01-2013, 09:46 PM   #51
DirtyADV OP
DirtyADV's Avatar
Oddometer: 2,324
They look to fit what Im looking for, question is the inner bag a rip to open? See it seems to have a zip-lock seal to close also?
Miss blister patches but that can be added, that is what has been mostly used so they should be easy to get to also.
Have a Lifesystem First Aid kit that I have been using for longer travels, very complete kit but a bit on the big side and will NOT fit inside the glove box.
Thanks for the help, have to see if they can be bought in Sweden or how bad shipping would be.
/Johan
Old 12-02-2013, 04:04 AM   #52
desmorado
desmorado's Avatar
Oddometer: 10
Hei,
I have this laying in the glovebox:
http://www.biltema.se/sv/Bil---MC/MC...de-mini-39552/
There is still room for gloves also.
Regards
desmorado is offline   Reply With Quote
Old 12-02-2013, 03:08 PM   #53
DirtyADV OP
DirtyADV's Avatar
Oddometer: 2,324
Originally Posted by desmorado View Post
Hei,
Regards
Have biltema nearby and its cheap, not sure how waterproof the glove box is and if its going to be in there all the time waterproof would be preferred, will at least go look at the biltema solution.
/Johan
Old 12-02-2013, 06:26 PM   #54
Zander
Zander's Avatar
Oddometer: 194
/Johan
Zip-Lock seal on the inner bag.
Beginner's mind !
KTM 950
Old 12-02-2013, 10:40 PM   #55
desmorado
desmorado's Avatar
Oddometer: 10
Hei Johan,
My 950 glovebox is waterproof (rainproof) from factory. I bet, Your`s also.
Have had this biltema`s first aid kit laying in there for 3 seasons - no problemo.
Regards
Old 12-02-2013, 10:55 PM   #56
DirtyADV OP
DirtyADV's Avatar
Oddometer: 2,324
Hei Johan,
Regards
There is a break in the seal on the 990 glovebox but still should be quite protected.
The Biltema kit in a sturdy plastic bag might be the cheapest simplest solution.
I like cheap right now, wanted to keep the 950 another year or 2 but since the LC8 is going out of style if felt right to buy one now.
/Johan
Old 12-05-2013, 06:46 AM   #57
DirtyADV OP
DirtyADV's Avatar
Oddometer: 2,324
That biltema first aid kit wont fit in a 990 new style glove box:
Maybe they had one that was slightly smaller a few years ago or the 950 has a bigger glovebox?
/Johan
Old 12-05-2013, 01:40 PM   #58
DirtyADV OP
DirtyADV's Avatar
Oddometer: 2,324
Mounted some straps under the seat to be able to easily hook up a kriega pack:
/Johan
Old 12-06-2013, 01:33 AM   #59
desmorado
desmorado's Avatar
Oddometer: 10
/Johan
Hei,
Seems that the biltema kit has changed. I got then (few years ago) a kit with soft shell. Unfortunately my bike is in molecules right now, so I can try to make glovebox assembly and take the picture.
Regards
Old 12-06-2013, 03:46 AM   #60
DirtyADV OP
DirtyADV's Avatar
Oddometer: 2,324
Hei,
Regards
This is more of a hard shell, would have been great had it been a little smaller.
Think the glove box is a little smaller also then the 950, was so long since I had that useable, been occupied by a Pyndon pre-filter the last few years.
The CPR dog house might be another option, but the heat might ruin some stuff in a first aid kit? Most have some burn cream and the most important and mostly used blister patches might not like.
And its harder to get to you have to get the seat of and depending if things are strapped to it might be annoying for just a band aid or something small.
Used to have some tank panniers mounted to the front fairings had the first aid kit in one of those before but not sure I will mount them on the new bike, maybe if I can figure out an easier way to take them on and off.
/Johan
DirtyADV screwed with this post 12-15-2013 at 02:35 PM
Times are GMT -7.   It's 05:49 AM.
