Old 08-11-2013, 06:10 AM   #1
dwj - Donnie OP
dwj - Donnie's Avatar
Location: Traveling on the Moto or Escuitla, Chiapas, Mexico
Oddometer: 15,273
I need A Picture Tutorial For Changing Fork OIL
Hi!
My 2007 990 Adventure has almost 28,000 miles and has never had the fork oil changed. I assume that it is about time that it be changed. I have not been able to locate a good photo tutorial, maybe I have just over looked it. There are no leaks or problems, just PM. What weight oil do y'all use? Thanks!
Donnie
Donnie - Retired & Riding - 2010 990ADV - 54,750 Miles - 2 Continents - 10 Countries
Return to Panama - SPOT
dwj - Donnie is offline   Reply With Quote
Old 08-11-2013, 06:45 AM   #2
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,199
I know of one but it's in French. Might be more confusing than anything else.
I use 5W on mine.
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 08-11-2013, 07:13 AM   #3
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,047
Try Slavens Racing.
Jeff has some good videos on fork maintenance.
Max
Da oggi la strada
é senza limiti
MAXVERT is offline   Reply With Quote
Old 08-11-2013, 07:30 AM   #4
dwj - Donnie OP
Oddometer: 15,273
Originally Posted by MAXVERT View Post
Try Slavens Racing.
Max
I didn't see one for changing fork oil.
Old 08-11-2013, 08:12 AM   #5
Hootowl
Oddometer: 1,278
You'll need one of these fork cap tools http://www.motionpro.com/motorcycle/partno/08-0290/
How to set fork oil level https://www.youtube.com/watch?v=glG3gUjxjEU
complete fork disassembly and assembly (PDF) https://docs.google.com/file/d/0B5nb...thkey=CNm9_sIE I would use the fork cap tool to remove the cap & not the box end as shown on page 5
And this: http://www.dirtyadv.com/ktm-950-adve...l-replacement/
Might as well change out the seals as well while the forks are off the bike
Keep it Wild, Keep it Free
'07 990A
'12 Super Tenere
Hootowl screwed with this post 08-11-2013 at 08:19 AM
Hootowl is offline   Reply With Quote
Old 08-11-2013, 09:03 AM   #6
DirtyADV
DirtyADV's Avatar
Oddometer: 2,414
Have a "tutorial" from when I changed the fork seals.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 08-11-2013, 09:10 AM   #7
dwj - Donnie OP
Oddometer: 15,273
Thanks for the info! Is there one that is only for changing the oil or does everyone wait until they start leaking and change seals/bushings at the same time? Thanks!
Donnie
Old 08-11-2013, 09:14 AM   #8
Peanuts
Peanuts's Avatar
Location: Beautiful but often rainy North Yorkshire, UK
Oddometer: 1,731
I change my fork oil every 2 years.
Run a piece of plastic coke bottle around the seals to clean them from time to time.
Peanuts is offline   Reply With Quote
Old 08-11-2013, 09:29 AM   #9
fast4d
Oddometer: 2,481
get some race tech fork grease. apply a little between dust wiper and oil seal. do it even if you are just changing fluid and not replacing seal or bushing.
if your fluid is oem or have have lots of miles you should take it completely apart and clean. fluid will have lots of sediments
fast4d is offline   Reply With Quote
Old 08-11-2013, 09:29 AM   #10
LocuL
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,385
http://www.youtube.com/watch?v=eUYCPZDzg4g
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is online now   Reply With Quote
Old 08-11-2013, 10:42 AM   #11
DirtyADV
DirtyADV's Avatar
Oddometer: 2,414
Donnie
For a change just go into it so you can remove the spring (has to be out when setting oil level.
I would recommend to pour a little fresh oil into it and pump inner part a few times and drain that, will get some of the old stuff out.
/Johan
Old 08-11-2013, 10:46 AM   #12
Peanuts
Peanuts's Avatar
Oddometer: 1,731
Originally done by Adz on the UKKTMForum:
Heres some pics so you have an idea whats inside.
Undo the cap..
22mm spanner, pull down the spring and slip it in..
take cap off and pull the long ally rod out of the center of the cartridge. remove the spring, pour the oil out, pump the cartridge untill all the oils out..
work around the dust seal with a small screwdriver, steady or it will mark the outer tube.
slide the dust seal down..
i like to grip the outer tube lighty in a vice..
Remove the circlip, it has one open end you can work that with a small screwdriver or seal pick.
now it helps to heat the seal area with a heat gun but you dont have to.
give the innner tube a sharp tug and the seal and bushes should all come out. if you didnt heat it and it was hard to part make shure the large washer is still flat and not dished.
remove old seal, tape the end of the inner tube and slap some grease on it, slide the new seal on.
should look like this right to left, dust seal,circlip,oil seal,washer outer tube bush.
slide the inner tube back in and use the seal driver you got off the nice man on ebay to tap in the outer tube bush.
pop the wahser in then use the same driver with the under cut lip to tap the seal in..
re fit the circlip, make shure its snug in the grove all the way round or the seal will come out, re fit dust seal.
turn the fork upright and fill with oil about 525 to 540 mls pump the cartridge untill its smooth all the way through its action and pop the ally rod back in the center, make sure it sits down flush with the top.
put the spring in pull i down and pop the 22mm in, then refit the cap.
Old 08-11-2013, 10:49 AM   #13
Peanuts
Peanuts's Avatar
Oddometer: 1,731
You ideally should fill with about 550ml of oil, then pump the cartridge up and down until no bubbles are coming up, then suck out the excess oil to set the fork level to around 100mm on an Adv. Then fit the spring, rebound tube and cap.
Old 08-11-2013, 03:21 PM   #14
mousitsas
mousitsas's Avatar
Oddometer: 2,992
I do it without even removing the spring. About 100ml of old oil remains inside, but its so fast and easy that who cares. Not the purist's way by any means....
Old 08-11-2013, 05:48 PM   #15
grant22
grant22's Avatar
Oddometer: 507
http://www.rockymountainatvmc.com/Video/93
grant22 is offline   Reply With Quote
Times are GMT -7.   It's 10:55 AM.
