Old 08-11-2013, 05:54 PM   #16
dwj - Donnie OP
dwj - Donnie's Avatar
Location: Traveling on the Moto or Escuitla, Chiapas, Mexico
Oddometer: 14,660
Originally Posted by grant22 View Post
Thanks to you all!
I just ordered the Motion Pro Fork Cap Wrench Tool.
Donnie - Retired & Riding - 2010 990ADV - 48,200 Miles - 2 Continents - 10 Countries
Return to Panama - SPOT
dwj - Donnie is offline   Reply With Quote
Old 08-11-2013, 11:18 PM   #17
mousitsas
mousitsas's Avatar
Oddometer: 2,879
A few people pm-ed to ask me what is the 'easy' method I use, here is goes:
1) Loosen the top triple tree bolts, keep the bottom tree bolts tight
2) Turn (unscrew) the preload bolts on the top, when all preload is removed give it a bit more and the top caps will loosen. When they loosen stop turning them.
3) Loosen bottom tree bolts and remove forks
4) keep forks vertical, hold stationary the top caps and the fork boots and unscrew the top fork legs from the caps.
5) pull top fork legs all the way down
6) reverse forks and empty oil in a container. Measure exactly how much oil comes out from each leg. You have to assume here that last person who screwed with your forks put the correct amount of oil.
7) keep forks upside down to drain as much oil as possible
8) Get a small funnel, small enough for its pointy end to get between the fork spring and the fork leg and fill with same quantity of new oil. I use a big plastic syringe and a funnel on top of it.
9) pull up the upper fork leg and screw it back to the top cap, again without turning the cap, just the leg.
10) Replace forks, tighten bottom tree bolts, then fork caps then top triple bolts.
mousitsas is online now   Reply With Quote
Old 08-12-2013, 12:48 AM   #18
Peanuts
Peanuts's Avatar
Oddometer: 1,664
I would never use the preload adjuster to undo fork caps. If you dont have the 4 pin tool, use an adjustable 2 pin tool designed for angle grinders, very cheap to buy.
http://www.ebay.co.uk/itm/Silverline...item2a14a6112d
I must admit I do the tip out the oil and measure method for quick changes on non leaking forks.
I thought about taking out the base valve and pumping empty, then refil through the bleed screw hole. I will give it a try this Winter.
Peanuts is offline   Reply With Quote
Old 08-12-2013, 02:18 AM   #19
mousitsas
mousitsas's Avatar
Oddometer: 2,879
Thanks for the tips Peanuts.
The fork cap on my forks was not tight at all, maybe that was just my bike.
If it is as easy to remove the base valve, then it would be dream come true. I will check it out on an old pair of WP 43mm forks I have lying around.
Old 08-12-2013, 05:12 AM   #20
dwj - Donnie OP
Oddometer: 14,660
Thanks! I think this will work for me!
Old 08-12-2013, 11:29 AM   #21
Peanuts
Peanuts's Avatar
Oddometer: 1,664
So long as there is weight on the forks to stop the cartridge spinning, it will come out easy. If it seems to be just spinning, use a ratchet strap from handlebars to wheel to compress the fork a bit more.
BUT bleed the fork via the screw in the top cap before you take the base valve out otherwise it will be under pressure!
Just do one side at a time.
Old 08-12-2013, 02:40 PM   #22
dwj - Donnie OP
Oddometer: 14,660
Originally Posted by dwj - Donnie View Post
Thanks to you all!
Times are GMT -7.   It's 04:31 AM.
