Old 08-11-2013, 08:28 PM   #1
ktmklx OP
ktmklx's Avatar
Oddometer: 689
Introducing Back Road Equipment LLC
http://www.backroadequipment.com/
Back Road Equipment LLC was formed to bring some innovative new products to the dual sport accessory market. My goal is to provide high quality innovative products that solve problems for dual sporters. I have no intention of making copies of what is already available on the market; our products have to offer something unique or different.
Our first product is a rear rack for all years Kawasaki KLR 650s. This rack features a cut out for stock tool pouch access, a bolt pattern for a Rotpax container and the most unique feature a very slick quick connect top box mount. This quick connect is called the “Slider System”. More about this KLR specific product later.
What is a Slider and how was it developed?
When it came time to put pannier racks on my dual sport ninja it was quite evident that I was going to have to build something, let’s face it Motorcycle Superstore was not going to have racks for long travel Ninjas.
I made a list of characteristics that was important for these luggage mounts and came up with this:
Adaptable – The racks needed to be able to mount top loader or side loader boxes, aluminum or plastic.
Quick connect - I wanted to be able to take the bags off easily without tools and take them in the motel room with me. Removal had to be done without opening the box and spilling the contents on side opening bags.
Forgiving – The racks needed to be able to take a hit from the ground, tree or boulder without breaking the bike, the racks or the boxes.
Light weight – No brainer.
Low cost – Nobody wants to spend a paycheck on some steel tubing to hold a couple boxes on their motorbike.
Look good – Nobody wants to put ugly on his or her motorbike.
These criteria led to rack design that I built for the Ninja. This rack design was going be tested immediately as I had a Colorado back country ride planned. The key design trait was the rack main body, a 3/16” 6061 aluminum plate (light weight) with 2 horizontal grooves cut into it. These grooves would allow 4 plastic pucks bolted directly to the Pelican case (adaptable) to slide into the aluminum plate from the rear (quick connect). The Pelican case was hooked to the plate by a rubber strap that acts as a shock cord. If the box took an impact from the front, it would slide backwards in the grooves and the rubber strap acts like a shock absorber (forgiving).
The rack system looks like no other rack on the market and has kind of a high-tech billet look to it (looks good). The rack system worked great on the Colorado ride and I thought other advriders could use the features of this system. Unfortunately there is no market for Ninja dual-sport accessories.
My son drives a gen 1 KLR so I thought what the heck let’s see what it would take to adapt the “Slider” to the KLR. After many design iterations we have Slider production prototypes for gen 1 and gen 2 KLRs.
While designing the side racks a light bulb lit and I thought why not use the same puck mounting system for a rear rack and top box mount. The rear rack prototypes we built worked so well it was decided that we would take those to market first. Today we have rear rack top box mounts ready to ship to KLR owners everywhere.
We are finalizing testing of the rear side racks, so in the near future the original BRE product will be available. These racks have features that no one else offers and will be very competitively priced (low cost).
The first ever Slider mount on a one of a kind Ninja 650 dual-sport
[/URL]
Pelican cases slid into the Slider rack on the Ninja 650
[/URL]
Slider top box prototype on Ninja 650
[/URL]
Gen 1 KLR 650 with prototype Slider side rack system
[/URL]
Gen 2 KLR 650 with prototype Slider side and top racks
[/URL]
ktmklx screwed with this post 11-23-2013 at 11:54 AM
ktmklx is offline   Reply With Quote
Old 08-11-2013, 08:48 PM   #2
ktmklx OP
ktmklx's Avatar
Oddometer: 689
Slider Top Rack for Gen 1 & Gen 2 KLR 650s
13" x 16" rack
3/16" 6061 aluminum material
Charcoal gray hard anodized
CNC cut
stock tool kit access
hole pattern for Rotopak mount
keyhole mounts for quick connect top box
stainless steel mounting hardware
top box quick connect:
four heavy duty plastic pucks create quiet and tough mounting system
four large 6061 washers
zinc plated button head mounting screws
6061 quick cam lock (top box attaches in less than 10 seconds) when locked into position the box is tightly locked onto the rack
top box can be locked onto rack with a padlock
optional integrated lock is available
mounting is symmetrical, box can be mounted in one orientation and 10 seconds later be mounted in a different orientation
top box can be attached and removed without opening the box
rack & top mount kit is $149.90
or
rack only can be purchased for $99.95 and mount kit $49.95
free shipping to inmates in the CON USA
Our website is under construction, so PM me if you would like to buy one and get the ADVrider free shipping deal.
Rack for Gen 1 or Gen 2 KLR 650
[/URL]
Top box quick connect kit
[/URL]
Gen 2 KLR 650 with rear top rack
[/URL]
Image of Kawasaki KLR 650 rear rack
[/URL]
Rear view of Gen 2 KLR 650 with Pelican case mounted as a top box
[/URL]
Dry bag mounted with flat straps or hooked strap on top rack
[/URL]
Rotopax container mounted on top rear rack
[/URL]
Pad lock in place to lock top box to rack by locking attachment lever
[/URL]
Steve
ktmklx screwed with this post 08-12-2013 at 09:18 PM
Old 08-11-2013, 09:00 PM   #3
ktmklx OP
ktmklx's Avatar
Oddometer: 689
More info here
Related link
http://www.advrider.com/forums/showthread.php?t=897738
Old 08-12-2013, 07:58 AM   #4
G-Wing
G-Wing's Avatar
Oddometer: 199
Thumb
Well done Amigo!
06-wr450f -bigga 'n betta
06-950 Adventure - PURE EXHILARATION!
“Life is a verb, not a noun.” ~Charlotte Perkins Gilman
"Excellent, there was a big one coming up ‘Cheap petrol in hell’, that really got me pondering, until I got a little closer and realised the ‘S’ had dropped off the sign advertising the Shell servo in Norseman. Shame really, it was a thought-provoking slogan." - Katie em
G-Wing is offline   Reply With Quote
Old 09-21-2013, 09:10 AM   #5
ktmklx OP
ktmklx's Avatar
Oddometer: 689
Feedback
I have sold some of the "Slider" KLR rear racks on that auction site nobody likes. Feedback has been very positive.
Purchase the rack directly from me via a PM and buy for less than on that auction site!!!!
[/URL]
Old 10-12-2013, 03:50 PM   #6
JStory
JStory's Avatar
Oddometer: 2,732
Just read through both of your threads. Any idea when you will have a universal top plate available? Will it be the same plate minus the tool pouch hole? Thanks.
Jeff
"He who makes a beast of himself gets rid of the pain of being a man." Dr Samuel Johnson.
JStory is offline   Reply With Quote
Old 10-14-2013, 05:58 PM   #7
ktmklx OP
ktmklx's Avatar
Oddometer: 689
Thanks for your interest. I expect the universal top plate to be available in 2 weeks. It is very close to the same plate minus the tool kit cut, but it is also 1" shorter.
Old 10-14-2013, 06:19 PM   #8
JStory
JStory's Avatar
Oddometer: 2,732
Thanks for the info. I'm going to buy a universal plate and a quick connect kit.
Jeff
Old 10-15-2013, 05:30 PM   #9
ktmklx OP
ktmklx's Avatar
Oddometer: 689
That is good news, I will post here and send you a PM when they are available.
Steve
Old 10-15-2013, 05:54 PM   #10
JStory
JStory's Avatar
Oddometer: 2,732
Steve
Thank You.
Jeff
Old 10-15-2013, 09:32 PM   #11
ktmklx OP
ktmklx's Avatar
Oddometer: 689
Universal Rack with Top Box Quick Connect
A 12" x 16" universal rack (you drill your own mounting holes) will be available in approximately 2 weeks. The rack will include the top box mount kit. I will post pictures of the new rack as soon as I have one available.
Price for the entire kit is $145.00
Free shipping to the CON US
Payment can be made via PayPal to:
backroadequipment@frontier.com
ktmklx screwed with this post 11-01-2013 at 08:54 PM Reason: changed 13 x 15 to 12 x 16
Old 10-16-2013, 10:11 AM   #12
16VGTIDave
blame Reaver...
16VGTIDave's Avatar
Oddometer: 493
Any idea what USPS shipping to Canada would be? Specifically to Postal Code "N0J 1G0". I'm hoping that if it is shipped as "Automotive Parts, Made in USA" that there won't be any import duties...
16VGTIDave is offline   Reply With Quote
Old 10-16-2013, 04:30 PM   #13
Joe Houle
Joe Houle's Avatar
Oddometer: 19
pre-order payment sent!
and now, we wait!
This is going on my Speed Triple, but I was thinking if I put a piece of aluminum sheet in the bottom of a milk crate and mounted it that way, I could pass her off as a KLR...
Sua Sponte
2008 Scrambler
2008 Speed Triple
Joe Houle is offline   Reply With Quote
Old 10-16-2013, 05:53 PM   #14
ktmklx OP
ktmklx's Avatar
Oddometer: 689
and now, we wait!
Payment received, thank you. Be sure to post pictures of the beast with the rack here on this thread.
Old 11-01-2013, 08:53 PM   #15
ktmklx OP
ktmklx's Avatar
Oddometer: 689
The universal racks are ready to ship.
The rack is 3/16" x 12" x 16" 6061 aluminum with grey hard anodized coating.
It has a Rotopax mounting bolt pattern in the center of the rack and has the keyholes for the top box quick connect.
The rack includes four 1.0" diameter x 5/8" tall spacers that you may or may not use for mounting.
Drill your own mounting holes.
Rack only $94.95
Rack with top box mounting puck kit $144.95.
Free shipping to inmates in the CON US (approximately $20.00 value)
Top Box Quick Connect Kit
Times are GMT -7.   It's 04:14 AM.
