Old 08-11-2013, 07:49 PM   #1
skidxr OP
Excuses
skidxr's Avatar
Oddometer: 396
990 Idle Problem
Hey all. My 2007 990 Adv will not idle. Just out of the blue when I come to a stop it just dies. I haven't done anything to troubleshoot except connect to TuneECU to check for any error codes and there are none. Where should I begin to troubleshoot this?
skidxr is offline   Reply With Quote
Old 08-11-2013, 09:30 PM   #2
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,193
In tuneecu, with a warm engine but not running, check your tps.
Anything below 0.58v or above 0.64 could lead to idling issue.
Most target 0.60v as ideal tps.
The race is long and, in the end, it's only with yourself...
bikyto screwed with this post 09-04-2013 at 08:02 PM
bikyto is offline   Reply With Quote
Old 08-11-2013, 09:52 PM   #3
Midlife
HalFassed
Midlife's Avatar
Oddometer: 69
Simple stuff first?
Clean filter? How old are the plugs?
STILL fun after all these years! Thanks GOD!
2008 KTM 990 Adventure, and a bunch of dream bikes in my head.
Midlife is offline   Reply With Quote
Old 08-11-2013, 10:03 PM   #4
Mother_trucker69
Mother_trucker69's Avatar
Oddometer: 16
Check fuel filter.
Mother_trucker69 is offline   Reply With Quote
Old 08-12-2013, 04:30 PM   #5
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,144
Check the throttle cables, if too tight, the ECU will not pick up the idle. You are starting it with a closed throttle? If you crack the throttle, the auto-idle will not take over.
Then +2 on the TPS sensor.
-2 on fuel filters, they usually don't show problems on idle.
So the count sofar is 2 for TPS, 1 for cables and 0 for filters. Any one of us is not as stupid as all of us.
"Son, you can't do both"
Old 08-13-2013, 03:04 PM   #6
skidxr OP
Excuses
skidxr's Avatar
Oddometer: 396
Thanks for the replies.
So I connected it up to TuneECU again after riding it around for a bit. I had the ignition turned on but the engine is not running and the headlight fuse is out. On the test screen under TPS it reads 0.71
I don't know enough about TuneECU to know if I did that right.
When started it today after sitting for a couple days it started just fine and idled fine while in neutral. It did not die on me but the idle dropped down to just below 1k after I popped it into gear and rolled forward a few feet and then stopped. Then it will slowly increase up to about 1400k.
Thanks again...
Old 09-04-2013, 03:48 PM   #7
skidxr OP
Excuses
skidxr's Avatar
Oddometer: 396
I adjusted to TPS and all is good with the idle now.
Thank you all for the help. I couldn't own this bike if not for this forum !!!
Old 09-04-2013, 08:00 PM   #8
bikyto
bikyto's Avatar
Oddometer: 2,193
Times are GMT -7.   It's 01:30 AM.
