Old 08-20-2013, 05:49 AM   #61
boatpuller OP
Oddometer: 625
Originally Posted by Twin-shocker View Post
Interesting.................does the bike have a far shorter motor then?
By 2 inches.
boatpuller is offline   Reply With Quote
Old 08-31-2013, 01:13 PM   #62
Jan from Finland
Registered
Oddometer: 567
Originally Posted by boatpuller View Post
Been reading the reviews of the new water cooled GS, and most talk about the 2 inch longer swing arm, and that that provides better traction in the dirt or off road.
Why?
That's a good question. Even if this thread went down since page 2.
I think that there are two reasons. Longer swingarm moves less front-to-back for given suspension movement. Additional horizontal movement at tires's contact patch reduces traction. The other reason is that longer swingarm resist wheeling so you can accelerate harder. That works like added traction.
The BMW's rear suspension is not a simple swingarm. It's a form of paralleogram suspension. If it were true parallelogram, where the facing sides are of equal length, effective swingarm length would be infinite and tire would only move only up and down (like in equal length double wishbone suspension in a car). In that case adding 2 inches to length of swingarm would do nothing.
However, in BMW's paralever all opposing sides are not equal length. A to B is not the same as C to D. B to C is different than A to D. That's because there is build in anti-squat in the design. It uses shaft effect to prevent squat during acceleration. Therefore BMW's swingarm length is finite and adding 2 inches actually lengthens the swingarm. At least in theory. I am not sure how much adding 2 inches to about 55 inches effective swingarm length actually helps. At least it gives the marketing department some bragging rights...
If you are ever attacked by lion, your best defense is to shove your arm down
their throat, grabbing the back of their tongue and hope help arrives quickly.
- Pro Travel Tip by Overland Journal
Jan from Finland is offline   Reply With Quote
Old 08-31-2013, 07:18 PM   #63
JDK111
Oddometer: 280
Agreed with both points .... AND ... There's a u-joint (or cv joint) at the swing arm pivot point. For a given length of suspension vertical travel, the longer the swing arm, the less the angle the driveline joint will see. The less this angle is - the better.
JDK111 is offline   Reply With Quote
Times are GMT -7.   It's 11:58 AM.
