Old 08-12-2013, 03:42 PM   #1
VitSports6 OP
VitSports6's Avatar
Oddometer: 195
Just picked up an '73 Suzuki TS185
I couldn't pass it up, it was only $125.00.
I checked to see if it had oil in the canister and case, added a little fuel and it fired right up! Smoked like crazy as it had sat for a couple years, but the smoke subsided and it idles well, I need to figure out the lever on the carb as to which way the choke works.
I have a Clymers manual on order, as it needs fork seals and some routine maint, I noticed chain is a little lose and the chain adjusters at the rear were extended past the furthest mark.
The PO removed all the lights and I haven't looked close enough at the title to see how they registered it last, So I don't know if I will be adding ligs or not.
I will get some pics up a little later, she ain't pretty, but it's a start!
Have Fun!
Brian
VitSports6 is offline   Reply With Quote
Old 08-12-2013, 03:45 PM   #2
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,301
lever down is choke on. if the carb has been swapped to some other carb with a rod choke, pulled up is choke on.
current bikes
stainlesscycle is offline   Reply With Quote
Old 08-12-2013, 03:49 PM   #3
VitSports6 OP
VitSports6's Avatar
Oddometer: 195
Great thans! It has the lever.
Have Fun!
Brian
Old 08-12-2013, 06:23 PM   #4
VitSports6 OP
VitSports6's Avatar
Oddometer: 195
Here she is!
I ended up shortening the chain by one full link, it brought the rear wheel forward back to the largest mark on the swing arm with a little over 1" play.
Stay classy
That's gotta go!
Family photo.
Have Fun!
Brian
Old 08-12-2013, 10:13 PM   #5
volkrt
Oddometer: 37
nice buy.....great trail bike and super reliable..and you can still get a decent amount of parts for it too
volkrt is offline   Reply With Quote
Old 08-13-2013, 04:45 AM   #6
Spikester300
Roll Tide!
Spikester300's Avatar
Oddometer: 127
That brings back memories, looks just like mine I had back in the day, stripped down for trails with knobbies. Wish I could find one just like it, nice find.
2007 Suzuki DL650 V-Strom
1976 Suzuki GT750 Waterbuffalo
Spikester300 is offline   Reply With Quote
Old 08-14-2013, 10:26 AM   #7
VitSports6 OP
VitSports6's Avatar
Oddometer: 195
Thanks guys!
I'm curious, is there a specific 2 stroke oil I should use, or can I just use outboard 2 stroke oil?
Have Fun!
Brian
Old 08-14-2013, 01:31 PM   #8
Andyinhilo
Andyinhilo's Avatar
Oddometer: 1,710
You should use a two stroke oil designed for air cooled motors, not water cooled like an outboard. The air cooled oils are designed for higher temperatures.
"The rifle itself has no moral stature, since it has no will of its own. Naturally, it may be used by evil men for evil purposes, but there are more good men than evil, and while the latter cannot be persuaded to the path of righteousness by propaganda, they can certainly be corrected by good men with rifles."J. Cooper
Andyinhilo is offline   Reply With Quote
Old 08-14-2013, 01:48 PM   #9
VitSports6 OP
VitSports6's Avatar
Oddometer: 195
Excellent!
Makes sense, the search continues.
Thank you.
Have Fun!
Brian
Old 08-19-2013, 08:20 PM   #10
VitSports6 OP
VitSports6's Avatar
Oddometer: 195
I replaced the fork seals tonight, kind of a PITA without the manual, which was suppose to be here...
Anyhow, my biggest issue was the threaded portion where the seal is, I knew it had to come apart but I wasn't quite sure where, but a diagram of the forks helped out.
Too bad I put my new registration sticker on the upper portion of the fork, I kind of scratched it up when I pulled the fork out.
At least it's not leaking or clunking anymore, I got mixed reviews on the amount of oil to use, I think I may need to add another 45cc or so as I added only 150cc.
Have Fun!
Brian
Times are GMT -7.   It's 06:06 PM.
