Old 08-12-2013, 08:03 PM   #1
Maoule OP
Maoule's Avatar
Oddometer: 607
Water under the gas cap?
After a nice day of dirty riding in KS, I decided to wash away all my off-road cred. Today, when I filled up, much to my surprise, I found about 2-3 tablespoons of water in the cavity around the tank spout of the left tank. Is this normal and what happened to the water on the right side? Should I not be hosing around the gas caps? Sheesh!
Maoule screwed with this post 08-12-2013 at 08:30 PM
Maoule is offline   Reply With Quote
Old 08-12-2013, 09:15 PM   #2
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,176
hi there
there is a draining hole, connected to a hose, routed at the inside of the tank. This should be pinched. You need to rearrange it.
Cheers
Old 08-12-2013, 09:24 PM   #3
Maoule OP
Maoule's Avatar
Oddometer: 607
Ah haah...oh wait, does that mean I have to take off the frickin tank!? Dammit..oh well, guess I'll change the oil and make a day of it. Thanks
Old 08-14-2013, 10:26 AM   #4
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,440
Yep, pinched drain hose. Learned this in huge thunderstorms in Colorado last year....
Thank you, mr. dealer.
SA
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 08-14-2013, 02:59 PM   #5
TcRulz
Oddometer: 289
On my 03 model they hadn't drilled the holes in the tank...so the water just sat there. Made it interesting when you had to fuel up on a rainy day. Might be worth pulling the caps to have a look if she's an early model.
TcRulz is offline   Reply With Quote
Old 08-14-2013, 04:09 PM   #6
Dale950
Dale950's Avatar
Oddometer: 989
Ah yes this has happened to mine too .
To make matters worst I found the actual caps don't seal that well allowing that water to go into the tanks once it fills over the lip inside .
I tape over my caps just as a precaution when washing it now .
Yes pinched hose or blocked drain hole .
Dale950 is offline   Reply With Quote
Old 08-14-2013, 05:25 PM   #7
Tee2
I SAID! Woo Hoo!
Oddometer: 1,288
Been there, Done that.
Tee2 is offline   Reply With Quote
Old 09-07-2013, 03:19 PM   #8
Maoule OP
Maoule's Avatar
Oddometer: 607
Cheers
That was it...finally got around to changing my oil; I was waiting for my cj oil drain hose and motivation. I guess I jerked on the hose too much the last time I changed the oil and it wadded up when I put the tank back. It's amazing how much easier to work on it with the top bolt in place;). But even so, what a PITA to do an oil change; at least it'll be easier the next go round with the drain hose.
Thanks for the advice.
Old 09-07-2013, 04:35 PM   #9
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,176
Times are GMT -7.   It's 09:15 AM.
