Old 08-13-2013, 02:14 AM   #1
two trackin fool OP
two trackin fool's Avatar
Oddometer: 1,302
oil loss 990
I hope this is not a repost I did look ......
Is it normal for the 990 to use oil ? I have just over 7000 miles and I seem to be adding oil often . If I am not alone that is fine Im just wondering if I should be contacting the dealer .........
Thanks in advance .
Stay Patient and Trust your Journey
two trackin fool is offline   Reply With Quote
Old 08-13-2013, 04:11 AM   #2
Yascher
Yascher's Avatar
Oddometer: 388
Thanks in advance .
if that is the only 7000 miles so far, than it is normal, wait till it gets double of that and oil level will settle)))))
Yascher is offline   Reply With Quote
Old 08-13-2013, 05:08 AM   #3
Peanuts
Peanuts's Avatar
Oddometer: 1,698
Mine goes from top of stick to just below bottom of stick in 3000 miles
Peanuts is offline   Reply With Quote
Old 08-13-2013, 06:36 AM   #4
xTomKx
xTomKx's Avatar
Oddometer: 195
I've noticed that mine uses oil also. Only 1300 miles but I ride her hard
2012 KTM 990A, 2006 KTM 250 2s, and many other toys
xTomKx is offline   Reply With Quote
Old 08-13-2013, 07:45 AM   #5
NKL
Oddometer: 196
Mine uses none between services, 08 with 30,000 miles on it.
NKL is offline   Reply With Quote
Old 08-13-2013, 08:25 AM   #6
two trackin fool OP
Oddometer: 1,302
Yes only 7992 miles on the clock and Im not easy on her .
Old 08-13-2013, 05:52 PM   #7
FuTAnT
KTM 990ADV
FuTAnT's Avatar
Oddometer: 342
Yeah its a bit of a known issue. Not exactly like a jap 4 that never uses any oil. I found mine used far more oil in stop start city riding, but bugger all when riding hard out in the bush or on the road. Pays to take a quart / litre spare on a long trip or a weekender just in case. It will settle down with more miles.
Sent from my Nexus 4 using Tapatalk 4
Cameron Corner - 6 Day Blast
FuTAnT is offline   Reply With Quote
Old 08-13-2013, 08:30 PM   #8
two trackin fool OP
Oddometer: 1,302
Well I had 30 thousand on the KLR and it was still using oil . I guess I can wait a little longer .
Old 08-14-2013, 11:03 AM   #9
xTomKx
xTomKx's Avatar
Oddometer: 195
What oil is everybody using?
As for my bike I'm going to give it a little more time to see if consumption decreases with higher mileage and then consider switching to 10w50 oil. I run 5w40 right now.
Old 08-14-2013, 09:00 PM   #10
two trackin fool OP
Oddometer: 1,302
I'm running 10w50 like they call for .
I tried Dino oil very short term shifted like hell ! Engine temp came up . Mileage dropped .
two trackin fool screwed with this post 08-15-2013 at 12:29 AM
Old 08-14-2013, 10:37 PM   #11
grant22
grant22's Avatar
Oddometer: 479
I'm curious if there's any correlation to how some of our bikes have been broken in and the oil consumption issue.
grant22 is offline   Reply With Quote
Old 08-14-2013, 11:06 PM   #12
Mr_Snips
Husky BRAAAAAAAAP!
Mr_Snips's Avatar
Oddometer: 352
Burning some oil has a lot to do with how the bike broke itself in. How tight or loose the rings seated. I assume you are running rotella t6 which burns a little in my bike too. Normally i run 15w60 out here in the desert with motul 300v but i was in a pinch and it needed changed bad so i through rotella back in it for my ride friday.
Originally Posted by Reprobate
Familiar. My stock response: "Most people die in bed. So, where do you sleep?"
Mr_Snips is offline   Reply With Quote
Old 08-15-2013, 12:17 AM   #13
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,140
Consistant Oil Check
Be sure to check the oil AFTER you finish a ride, not before. Park it on the centerstand, in the same place, and check it right after you pull off your helmet. Overfilling will cause more oil use.
That said, these engines will go from high mark to low mark in 2-3000 miles. That's less than 1/2 qt which is not bad for big twins. High RPM pumps it out faster.
"Son, you can't do both"
Old 08-15-2013, 12:37 AM   #14
two trackin fool OP
Oddometer: 1,302
Yes I have been battling with the oil check thing . Oil level is all over the place Hot to Cold level that is .
Old 08-15-2013, 07:34 AM   #15
FuTAnT
KTM 990ADV
FuTAnT's Avatar
Oddometer: 342
Oil level must be checked hot. See the owners manual. It is a dry sump, hence the need to check it hot when the oil tank is full. Checking cold will always read low or off the dip stick.
Times are GMT -7.   It's 11:35 PM.
