Old 09-13-2013, 07:06 PM   #106
anotherguy
anotherguy's Avatar
Oddometer: 6,207
He's high altitude. It has an effect on compression.
Old 09-14-2013, 02:17 AM   #107
LasseNC
XSessive!
LasseNC's Avatar
Oddometer: 1,059
This is the best thing I've ever done for all my two strokes. It will save you a shitload of problems down the road.
http://www.powerdynamo.biz/deu/syste...7238acmain.htm
Old 09-14-2013, 10:43 AM   #108
Inane Cathode OP
Cheated Anion
Inane Cathode's Avatar
Oddometer: 4,601
Originally Posted by Twin-shocker View Post
Many years ago I had a very strange problem with a bike, which turned out to be a damaged crankcase gasket, that was ok when the bike was cold, but when it heated up and the cases moved a little, leaked pressure. Seemed very much like seals, and only found it when I stripped the motor completely.
In terms of CDI boxes, you would probably find that the AC coil/CDI units used on Vespa PE200 scooters would work fine. They can be found on Ebay very cheap, and you should be able to wire up pretty easily, as there is only a trigger, feed, and earth to connect.
Never quite been able to work out why people seem to have so much hassle with CDI units, when cheap and easily available units for AC bikes, will in most cases work on other AC bikes, and only need changes to wiring to fit to bikes.
It's buried a bit, but i did exactly that. Got a yamaha jog cdi box (ac two stroke cdi) and put it in, and it ran exactly the same.
Originally Posted by Valleyrider View Post
The results of your compression test concern me!
http://www.marinemechanic.com/New-Folder2/comp-test.htm
At the bottom, read the special note. Not able to pull up any info for the DT400, but your compression sounds low and may be a part of your issue.
It's a little low for this altitude. From experience the highest i've ever seen here is right around 100psi. I know it needs a new top end (piston slaps pretty good at idle) but im waiting to make sure everything else is fixed before i go on a top end adventure. Add up it being a smidge worn out, being a two stroke (meaning half the charge is blown back out the exhaust anyway) and low altitude, and i'll believe a 90psi comp test isn't terrible. Then again maybe it is, who knows :P
So, update time. Got the points plate and rotor last night, was expecting it mondays but it shows up early, neat. Put it in this morning, got the points gap right (i have to love, btw, yamaha's timing advice on the subject "if the stator has been removed, put it back with the screws centered"). Got everything ghetto rigged back together and took a rip down the street.
I know i've said it before in this thread but it certainly does feel like it's running good. It's pulling hard enough to let me know my clutch cable is too tight and slipping the clutch. Once i had it adjusted right i could whack the throttle open and the front wheel jumps up a few inches, hadn't done that before. Sounds very healthy, and only starts to four stroke out at really high rpm (probably running out the spark advance, i suppose i could screw with that a little bit down the road if i wanted to, low air pressure means you can get away with crap like that up here, lol). It revved a little like it did before under no load (revs to the moon then backs off and sounds like the plug/pipe is loading up) but under load it performs great. Once it was totally warmed up theres no throttle/rpm combination i could put it under that would make it run like before.
Maybe it's just faking me out but it feels like it's finally fixed. Woot! Now to figure out how to wire this thing ><
As a funny post script, guess what just rolled into the shop last night? A 1976 yamaha IT400 that "Seems like it has spark when you kick it over but it just starts really hard and runs like shit otherwise"
_______
Pokey The Wunderbus
The VEEP Project
Inane Cathode is offline   Reply With Quote
Old 09-14-2013, 01:05 PM   #109
Twin-shocker
Oddometer: 1,673
I take it that fitting an inductive ignition has cured the problem then?
Old 09-15-2013, 09:38 PM   #110
Inane Cathode OP
Cheated Anion
Oddometer: 4,601
Woohoo! Seems like it's running just fine now :)
A little bit "flat", doesnt seem to "wake up" but it does put out some torque and it didnt run like dog shit again. Couple pictures from today:
A few things i'd like to fix: Main feels a little flat, i think it's a bit rich. I'd like to change the gearing quite a bit lower, feels like i have to fly everywhere to be able to get up hills. The kick starter detent ball and spring are gone, that gets annoying. I'd also like to finish up the electrics on it. I went ahead and burned out every bulb on the bike by not having a battery installed, so that's good. I'm considering just going to regulated A/C instead of jacking around with the whole rectifier and battery arrangement..
_______
Pokey The Wunderbus
The VEEP Project
Old 09-15-2013, 10:48 PM   #111
dhallilama
Oddometer: 476
... I'm considering just going to regulated A/C instead of jacking around with the whole rectifier and battery arrangement..
awesome that it's a rider, now! congratulations!
for what it's worth, i use a tympanium 12v ac regulator on damn near anything with a stator and no battery. typanium makes the MSR regulator:
http://www.motorcycle-superstore.com...Regulator.aspx
cheap, easy to use, reliable.
dhallilama is offline   Reply With Quote
Old 09-16-2013, 12:04 AM   #112
LasseNC
XSessive!
LasseNC's Avatar
Oddometer: 1,059
The powerdynamo is an all in one solution there then.
Old 09-16-2013, 11:21 AM   #113
dhallilama
Oddometer: 476
at US$324 (€243 without vat) + shipping/customs + unavailable replacement parts without getting from overseas... while the unit itself sounds good, it's costlier than some bikes here :)
wonder if ricky stator or other local-ish company makes a nifty stator for DTs?
Old 09-29-2013, 10:47 PM   #114
Inane Cathode OP
Cheated Anion
Oddometer: 4,601
Well, crap. Hopped on the bike at work to blast over to the parts place to get some stuff. Bike sounded normal, ran ok, all that.
Got to the store, got the stuff, got out. Started the bike and ran up the street about half a block when suddenly the bike's normal piston slappy noise sounded a little louder and a little weirder followed by KA-CHUNK. Seized motor.
By the sound of it the piston skirt broke and sent chunks into the bottom end. Awesome.
That'd make every single part on this bike being broken in some way. Well, actually, the frame hasn't cracked yet, the wheels are generally straight, and the fender's havent fallen off.
Timing is pretty awful as well, wife fell off a horse and got a pretty nasty hit in the head, hospitalization and no work for a month or so while things de-scramble. Seems like fall has suddenly arrived as well with snow up in the high country. Oh well.
_______
Pokey The Wunderbus
The VEEP Project
Old 11-19-2013, 10:58 PM   #115
dsm
Oddometer: 1
Dt 400 Not running correct
Well I just came across this post and I have to tell you a quick story about my 1975 dt 400.
I fixed it up got a title for it and within 100 miles the piston blew up and bent the connecting rod. Fixed that but the shop bored it out wrong . Got is bored out again ok now. Then one day no spark. turns out the pickup coil overheated for who knows why possibly age. Cannot find a pickup coil. I thought of a way to rewind the coil and did it but due to mounting problems I switched to the DT 250 points ignition (pretty expensive). But now I know a way to mount the pickup but I already have the points ignition soo..... Thing never ran correct just like yours......... Seems to be running lean at mid to open throttle since I hear pinging but it idles pretty good. Well I let it sit outside for 3 years and I just got it back on the road but I have this problem with the pinging and lost power. Found my fuel tank was all messed up with rust. I need to clean that out AGAIN
I went through A LOT OF BS with this bike and 8 years later I am sstill trying to figure it out LOL! Hey we should get together and bring these bikes and burn em LOL!!!!
Just kidding I will be in my death bed thinking "how can I get that dt 400 to run like is suppose to ,,,Well I ahve a plan for mine......
1. Clean fuel tank again ,,,HARDCORE this THIRD time
2.Clean carb AGAIN (To rid that ethonal left overs I think muratic acid dilutted is the best but you must be careful and kill it with baking soda) I already destroyed a carb with that stuff. The trick is to dilute the acid like 70% water 30% acid and keep checking the progress once all the white stuff is gone use baking soda to kill the acid. Cannot lewt carb sit in the acid long just a few minutes
3. Go back to stock jetting
4.Clean reed valves (I guess gum cutter)
5. Check carb boots for leaks and I mean really check those bastards
6.I guess I should by a new points and do timing since the one that I had in there got all messed up since I let the bike sit ouside . I had no spark again but I sanded the points and got spark.
This sucks
I have replaced all the seals and even made a spring for the decompression valve since you can't get that stupid spring anymore from yamaha . I'm telling ya my dt400 has the same type of issues yours has.
I had ricky stator recoil the dt 250 coils and they did them wrong (blew my headligh out) so I had to buy NOS ...... Yea lot of money and a big mess with everthing kinda like your hell.
Now for your bike I wanted to ask you did you check the fuel tank Because just A little bit of rust can cause a lean mixture since the small particals get through the fuel filter and into the carb or just partly clog the fuel fliter. Yes it sounds almost NO WAY but I just witnessed it. Once you throw the reserve on that is when it sucks any debris into the carb even with the filter. Very fine rust particals. I wonder if they can attach themselves to the reed valves and cause a fuel mix problem. I think that is possible. These 2 strokes are very sensitive .
P.S. Don't use regular oil in the transmission as the book says it's ok. Yea it was ok to use regular oil 20 years ago but now the regular oil has additives that willl destroy the clutch plates. Yea I need a new cluth now
dsm is offline   Reply With Quote
Times are GMT -7.   It's 11:06 AM.
