Old 08-22-2013, 07:29 PM   #1
Denalidirt OP
High Plains Drifter
Denalidirt's Avatar
Oddometer: 924
Lambda sensor?
What does this mean?
2012 990 adv
Flash code of warning lamp FI (MIL)
18 Warning lamp FI (MIL) flashes 1x long, 8x short
Error level condition
Lambda sensor cylinder 2, sensor 1 - circuit fault
Denalidirt is offline   Reply With Quote
Old 08-22-2013, 11:47 PM   #2
dmn0507
dmn0507's Avatar
Oddometer: 352
Pinched/worn wire, bad connection or faulty sensor.
dmn0507 is offline   Reply With Quote
Old 08-23-2013, 12:20 AM   #3
Chewy750
Chewy750's Avatar
Oddometer: 52
Hi, have you just refitted crash bars? If so you have probably caught the wire that runs down the left hand side to the sensor - easily done. You can repair this with a bit of effort and a soldering iron. If not the sensor will have gone US.
Chewy750 is offline   Reply With Quote
Old 08-23-2013, 12:56 AM   #4
Denalidirt OP
High Plains Drifter
Denalidirt's Avatar
Oddometer: 924
Yes I have
The bike only has 200 mikes on it. I did change the oil at fifty, maybe I pinched a wire. I will have it looked at tomorrow. Brining it to the shop for the "first" oil change. I'll have them take a look.
Thanks.
Old 08-23-2013, 09:44 AM   #5
SierraJeep
It's toast
SierraJeep's Avatar
Oddometer: 630
Just reach up behind the crash bar arm that mounts to the left side frame rail and you'll be able to feel if there is a wire running behind the frame that is caught under the crash bar arm's clamp. If so, a 6mm allen wrench and 30 seconds is all you'll need to resolve the problem.
Tod
2010 KTM 990 Adventure
2010 KTM 450 EXC
SierraJeep is offline   Reply With Quote
Times are GMT -7.   It's 06:04 AM.
