Old 08-23-2013, 06:09 AM   #1
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,274
External Fuel pump(990-1190).
Ive searched a bit for an external fuel pump for my bike. I dont like the design of the Aqualine tanks and would like to have it where i can maintain it easy.
Has anyone done this before. Pressure should be around 40-60 psi? And would i be needing an regulator.
Regards
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is offline   Reply With Quote
Old 08-23-2013, 10:41 AM   #2
Rally_West
Central Scrutinizer
Oddometer: 142
Subscribed.
'07 450EXC Sold but not forgotten...you will be replaced soon.
'07 990 Adv...BOOYAH!
Rally_West is offline   Reply With Quote
Old 08-23-2013, 12:28 PM   #3
mousitsas
mousitsas's Avatar
Oddometer: 2,728
it is quite simply really
What would one need is an external fuel pump (hayabusa turbo dudes like the walbro), a pressure regulator and a way to install a return line. A flat plate can fit on the original tank mount with a fuel outlet and a fuel inlet for the return line. You would also need to have enough electrical juice and of course a place to mount the pump.
Having said that I can't stress enough that I haven't actually done anything like this (but I have carbs)
Old 08-23-2013, 01:01 PM   #4
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,160
A few inmates have been working on a solution. I know CJ and I have talked about this quite a bit. He was working on a solution but I think life got in the way. Maybe soon?
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 08-23-2013, 01:16 PM   #5
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,311
I've had one running on my SER for 3 years now without a single issue. Maybe CJ and I can work together and assemble a kit for the masses. I'll bring it up next time we chat...
~ Ken
www.powercellperformance.com
PowerCell is online now   Reply With Quote
Old 08-23-2013, 01:18 PM   #6
bikyto
bikyto's Avatar
Oddometer: 2,160
Old 08-23-2013, 01:59 PM   #7
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,274
Ken: That sounds awsome. Could/would give me some links to elaborate on.
Case is that my projects Safaris leaked at the fuelpump. Easy enough, pulled the tanks and got 3 screws out. The 4th just turned around, or more detailed the unit encapsuled in the tank turned with the screw. Ive got a guy whome welds in plastic. Thinking of just going bombproof with external fuel pump.
Mikael
KTM 530 EXC-R 08
Old 08-23-2013, 04:45 PM   #8
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,105
Evil invader , used a Suzuki external pump on his 690 same pressure as yours
But the volume may be the issue
Birth of a Rally Bike - KTM525
Mudguts is offline   Reply With Quote
Times are GMT -7.   It's 12:21 PM.
