Old 08-24-2013, 02:47 PM   #1
smitty141 OP
smitty141's Avatar
Oddometer: 600
Extra watts left over??
I have a 2012 990 abs and wondering ?? How much power do I have left for aux lights, heated gear and other farkels. I do have a Datel volt meter.
Smitty
2011 Prudoe bay, Dalton Hwy.
2014 Inuvik, NWT. Demster Hwy. D2D, Yukon
2013 Yamaha FJR1300...2010 BMW F800GS..
1999 Yamaha YZ250.. 2008 Suzuki DRZ400SM
smitty141 is offline   Reply With Quote
Old 08-25-2013, 12:25 PM   #2
Zuber
Zoob
Zuber's Avatar
Oddometer: 1,944
From a faulty memory: the bike puts out about 400 watts at a high rpm. You will be using about 80 watts for normal bike running, mostly for the 55/60 watt headlight. So, you can plan on having about 100 watts available most of the time at lower rpm's.
If you run a heated vest/grips/gloves/aux lights just turn some things off while in stop and go traffic.
You can monitor this with voltage. Check the voltage with everything off. This will be the 'balance' voltage. Run the bike and gear. Any voltage above this 'balance' voltage and it's charging the battery, and voltage below and you are discharging. You may find there is an rpm that relates to the 'balance' voltage. So, keep it above this rpm or turn the heated gear off.
"Son, you can't do both"
Times are GMT -7.   It's 06:19 AM.
