Old 08-24-2013, 09:13 AM   #1
NeedForSpeed OP
Nitron Shocks USA
NeedForSpeed's Avatar
Oddometer: 1,353
Pak-Meister 41L Panniers
PAK-MEISTER Adventure Series Panniers are our Premium cases for the BMW KTM KLR DR XR and Vstrom
These cases are handmade made from 6061 aluminum with 2mm sidewalls and a 3mm lid/bottom for extra strength. The large volume (41L) panniers have protective corners and tie down points for top bags making them ideally suited for your travels- around the block or around the world.
Size- 45x27x43cm ea.
Net Wt.- 6.4kg ea.
* Sold in Pairs
* pre-installed mounting hardware
We usually sell these without the mounting pucks installed so they will mount to any rack system, and any bike. Unfortunately, somebody in the shop made a mistake and mounted all the hardware!
We are blowing these out for $595.00 per set (2) with FREE Shipping CONUS
http://www.pak-meister.com/PAK-MEISTER-Adventure-Series-41L_p_12.html
We have successfully mounted them to factory BMW, HT, and SW-Motech racks.
You may need to replace or relocate the pucks, cut the pucks down, fill a hole, and be a little creative to mount them. These are new old stock and may some slight scuff/handling marks on some of the panniers but the price is CHEAP!
ONLY 7 SETS AVAILABLE BEFORE WE START OUR NEXT PRODUCTION RUN!
CobraHeat LLC
PAK-MEISTER.COM- Motorcycle Adventure Gear
NITRON RACING SHOCKS USA
(801) 663-7436
NeedForSpeed is offline   Reply With Quote
Old 09-16-2013, 04:34 PM   #2
LaurelPerryOnLand
Oddometer: 3,478
Bear Tooth Pass?
https://fbcdn-sphotos-g-a.akamaihd.n...85005510_n.jpg
LaurelPerryOnLand is offline   Reply With Quote
Times are GMT -7.   It's 12:35 AM.
