Old 08-25-2013, 05:50 PM   #16
brooks
Oddometer: 323
I'm with east side, make sure the backer isn't warped-or get a new metal or plastic backer, make sure the oring is there as well. Good luck!
Brooks
brooks is offline   Reply With Quote
Old 08-26-2013, 08:09 PM   #17
ABuck99
0.0
ABuck99's Avatar
Oddometer: 582
M8- Why dont you call Oberon directly they are right there in the UK- they have excellent support.
KTM: 06 KTM950S & 10 KTM450EXC
ABuck99 is offline   Reply With Quote
Old 08-27-2013, 01:20 AM   #18
Oz_ OP
Oddometer: 22
Unfortunately it was national holidays yesterday but think I have solved it now.
I went back out yesterday to clean all the grease out of the hole and while unbolting realised it was a lot harder to do than the first time I undid it and after I put it back together. My reckoning is that the garage didn't bolt it on tight enough to seal it, so I've cleaned out all the grease(ball bearing is in there) and fluid from around/inside the spacer.
Following the cleaning I changed out the fluid for a different colour one - from amber to green bleeding it through till just green was coming out, reapplied some grease bolted everything back up and went for a 15 mile ride. Got home and there was just a little drop of amber fluid under the slave, stuffed a white tissue under the slave and went to bed. This morning all there is on the tissue is a small amount of amber fluid which I think is just the remnants of whatever escaped into the spacer etc, I'll continue to monitor it but if the slave was still leaking I'd have expected to see the green fluid staining the paper.
But thanks everyone for the advice, I guess I was massively on edge due to my big trip to Italy on Thursday oh and that it wasn't my usual garage...
Oz_ is offline   Reply With Quote
Old 08-27-2013, 06:02 AM   #19
Oz_ OP
Oddometer: 22
Spoke to soon, lots of Amber fluid - so looks like it might be the oil seal for the clutch pushrod that is leaking..
Old 08-28-2013, 12:40 AM   #20
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,885
Clutch fluid is pressurized in there.
You will feel the faulty operation on your hands if something is leaking seriously.
Cheers.
Old 08-29-2013, 12:46 PM   #21
5 speed
Oddometer: 883
Do not be tempted to disassemble the unit. You will not get it back together and in fact will damage the u-shaped seals and will have to send it back to the factory. It was an expensive lesson for me and doubled the cost with shipping. It should not require disassembly and I doubt there is anything wrong with the seals. check the banjo bolt and suppose the plastic housing could cause an issue but I doubt it would cause a leak, it might not work well but thats it. The ball bearing should be down in the grease. If you use a paperclip or something thin you should be able to dig around and figure it out. You can always put another one in there. Good luck
If you call ask for Steve
5 speed is offline   Reply With Quote
Old 08-29-2013, 04:15 PM   #22
ICERIDER
Adventure Rider
ICERIDER's Avatar
Oddometer: 443
Could be going around in circles here... the amber is residual from around your clutch rod. Clean it. Ride it. Enjoy your trip!
950 SE
WR250R
950 ADV
ICERIDER is offline   Reply With Quote
Old 08-31-2013, 02:18 PM   #23
Oz_ OP
Oddometer: 22
Turned out to be the clutch push rod seal in the end! Must have been disturbed when the old slave was removed and the new one fitted. Seal swapped and not a drop of oil since.
Currently sat on the balcony in the Dolomites.
Old 09-01-2013, 07:15 AM   #24
ICERIDER
Adventure Rider
ICERIDER's Avatar
Oddometer: 443
Thanks for the info. I'll carry one of these seals with me from now on.
950 SE
WR250R
950 ADV
Times are GMT -7.   It's 04:11 AM.
