Old 08-28-2013, 09:29 AM   #1
kenhaw OP
2006 Adventure S EU
kenhaw's Avatar
Oddometer: 31
2006 adventure 990S Idle problem
Hi Guys
I have a very irritating problem.
Sometimes coming to a halt and when activating the clutch, the idle rpm drops to around 1000 rpm and the motor cuts out.
I have Akropovic slipons and all the ¨emission¨ stuff removed and disabled in Tune Ecu. Running the 2006 akro map EU model.
Atm the clutch switch is jumped but does not change anything.
A couple of days ago I cleaned the throttle bodies and I thought they were the culprit, because suddenly the idle was at 14-1500 rpm and it did not act up on a 400 km trip.
Today it did it again.
This is very tiresome and takes away the lust for riding, sometimes you end up in some sketchy situations when the engine cuts out.
My idle is set at 1450 in Tune Ecu.
I also have the G2 Throttlecam installed.
Was told by a friend riding behind me that it smells rich, could that be the problem?
Hope someone can help
Kenneth
KTM Forever.
kenhaw screwed with this post 09-07-2013 at 02:38 AM
kenhaw is offline   Reply With Quote
Old 08-28-2013, 10:49 AM   #2
GrenDesb
Oddometer: 327
Possible causes of those engine cutting problems:
Sidestand switch acting up
Ignition switch contacts dirty
Ignition switch wire cut
Main relay or battery connections loose
Bad grounds
GrenDesb is offline   Reply With Quote
Old 08-28-2013, 02:47 PM   #3
kenhaw OP
2006 Adventure S EU
kenhaw's Avatar
Oddometer: 31
Ok, but would that not mean that I should have problems just going down the road?
Its only when pulling the clutch.
It did it again tonight, the rpm goes down to around a 1000 rpm when clutch is pulled, sometimes it cuts the engine and other times it comes back to 1400 rpm after 2 seconds.
I will check all the other stuff tomorrow but it sounds like I would have the problem more often with the problems you have described.
KTM Forever.
Old 08-28-2013, 04:05 PM   #4
Katoom72
Katoom72's Avatar
Oddometer: 862
Sync throttlebodies and clean the injectors, also check your gearselector sensor because the plug might be dirty.
Now, when the rpm drops, did you try and blip the throttle to see if it stays above 1400?
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is offline   Reply With Quote
Old 08-28-2013, 04:51 PM   #5
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 894
What TPS values?
690R
Old 08-28-2013, 06:46 PM   #6
kenhaw OP
2006 Adventure S EU
kenhaw's Avatar
Oddometer: 31
Will let you know tomorrow regarding sync. Dumped some injector cleaner in the tanks today and took a long ride on the highway keeping rpm up.. Will check gearselectorswitch,but this is a road driven bike and the weather in the south of france is sun,sun and sun, so I doubt that it is dirty,but will check it.
No havent tried that, all happens so quick so its hard to know if it will drop or stay, but will try that tomorrow too.
KTM Forever.
Old 08-28-2013, 06:47 PM   #7
kenhaw OP
2006 Adventure S EU
kenhaw's Avatar
Oddometer: 31
Originally Posted by Gustavo.Ramos View Post
What TPS values?
Will check with Tune Ecu tomorrow..
KTM Forever.
Old 08-28-2013, 06:59 PM   #8
Sheep Shagger
Show me your fleece
Sheep Shagger's Avatar
Oddometer: 2,133
What TPS values?
This is probably your culprit.
Sheep Shagger is offline   Reply With Quote
Old 08-29-2013, 12:51 AM   #9
SixDays02
SixDays02's Avatar
Oddometer: 270
What TPS values?
Same bike, same story here.
TPS was in range but idle would drop after an hour of driving and the motor would just die.
Solution that worked for me: turn O2 sensors back on.
SixDays | Croatia
SixDays02 is offline   Reply With Quote
Old 08-29-2013, 10:05 AM   #10
kenhaw OP
2006 Adventure S EU
kenhaw's Avatar
Oddometer: 31
Hi Guys. Checked lots of things today but everything looks to be within specs.
Battery was dry though so refilled it and put it on charge. No problem starting the bike. All surfaces are nice and clean; no corroded contacs anywhere but still gave everything some dielectric grease.
The tps reads 0.59 or 0.6 warm at 4 bars.
The sync is good 365 vs 370 which is pretty close.
The gear selector switch is located where? the only thing I can see near the gearselector is the switch for the sidestand.
Havent tried activating O2 sensors yet
KTM Forever.
Old 08-29-2013, 04:22 PM   #11
Katoom72
Katoom72's Avatar
Oddometer: 862
Follow the wires from here:
It's a black plug with a green, green-yellow and red-blue wire. The green wire is for neutral, the other 2 for first and 2nd gear. Maybe take the 2 contacts out of the plug, put some tape around them so they don't short and go for a ride. (make sure it's not raining because the connector is not sealed with the wires out!) See if the problem still persists.
Worth a shot.
edit: wrong about the colors, those where from my SDR.
Here is the adv color code, just keep the green-blue one connected:
Now:
Before:
Katoom72 screwed with this post 08-29-2013 at 04:33 PM
Old 08-30-2013, 06:20 PM   #12
kenhaw OP
2006 Adventure S EU
kenhaw's Avatar
Oddometer: 31
Hi All
Well today I reenabled the o2 sensors and so far no stalling. Can this be the solution? I sure hope so. The bike runs fine no dead spots. Why do some of us disable them in the first place?
So far thx for the tip "sixdays".
Kenneth
KTM Forever.
Old 09-07-2013, 02:48 AM   #13
kenhaw OP
2006 Adventure S EU
kenhaw's Avatar
Oddometer: 31
Hi guys
So today on a short 5 km trip it stalled again, all the time. Wth is going on?
How can so many people have exactly the same problem and KTM does not do anything about this? This is starting to bother me big time, never knowing whether or not it stalls when pulling the clutch.
Since last I also changed the battery, since the old one was completely dry.
Besides the stalling problem, I must say I find the difference between O2 sensor off vs on, huge. Some large bangs in the exhaust when decellerating and also more rough on the gas, however the smell of too much fuel is gone with O2's enabled. I personally prefer the O2 sensors disabled.
If anyone has any new advice,it would be much appreciated.
KTM Forever.
Old 09-07-2013, 03:04 AM   #14
Sumi
Sumi's Avatar
Oddometer: 1,796
Does it do it in neutral as well or only when it's in gear? Do you experience hanging IDLE (3-4k rpm) sometimes?
If not yet done, try reloading the map into the ecu and after that do the 15min idle trick.
Old 09-07-2013, 07:52 AM   #15
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,738
Sounds like the bike is stalling due to low rpm caused by clutch dragging
If you roll to the lights in neutral does it still stall?
Try that and it may eliminate or be the culprit ??? If it is u may need to shim ur push rod at the slave end
Pete
Turtleshell5@icloud.com
For those who sit at home and dream-let them...Meoni
Pete640 is offline   Reply With Quote
Times are GMT -7.   It's 08:49 AM.
