Old 09-07-2013, 09:09 AM   #16
kenhaw OP
2006 Adventure S EU
kenhaw's Avatar
Oddometer: 31
Originally Posted by Sumi View Post
Does it do it in neutral as well or only when it's in gear? Do you experience hanging IDLE (3-4k rpm) sometimes?
If not yet done, try reloading the map into the ecu and after that do the 15min idle trick.
I never have a problem with high idle when driving, but sometimes when I start the bike cold it goes up to 3/4000 rpm. I just switch it off and restart.
Have reloaded the map today and disabled the O2 sensors, set idle at 1600 rpm and did the 15 min idle afterwards. Havent driven it yet, also checked the fuelfilters and ofcourse need a new o ring, the old one broke. Also did an oilchange.
Checked all plugs I could find on the bike and gave them dielectric grease.
Also did the Black Dog sidestand relocator.
KTM Forever.
kenhaw is offline   Reply With Quote
Old 09-07-2013, 09:10 AM   #17
kenhaw OP
2006 Adventure S EU
kenhaw's Avatar
Oddometer: 31
Originally Posted by Pete640 View Post
Sounds like the bike is stalling due to low rpm caused by clutch dragging
If you roll to the lights in neutral does it still stall?
Try that and it may eliminate or be the culprit ??? If it is u may need to shim ur push rod at the slave end
God idea. Will try and look into that.
KTM Forever.
Old 09-08-2013, 08:40 AM   #18
kenhaw OP
2006 Adventure S EU
kenhaw's Avatar
Oddometer: 31
Took the throttlebodies of today. Can anyone explain what the 3 small locked screws control? They are locked with yellow paint and can only be adjusted from underneath. Can they by any chance be related to my stalling problems?
KTM Forever.
Times are GMT -7.   It's 07:20 PM.
