Old 08-28-2013, 10:01 AM   #1
PatrickM OP
Oddometer: 366
Headlight Modulators
Anyone use them?
I put one on about 1000 miles ago and they do seem to work as advertised. Cars get out of the way a bit faster when I'm lane splitting and I'm feeling that on the narrow two lane roads, people see me coming from a bit further away.
But one thing I don't like is that when activated, the Canbus throws a lamp error.
The wiring is pretty simple, you disconnect the hi-beam and connect the modulator. From the regular input, you tap the hot wire to the device, and ground the wire from the device (I just plugged it into the brown/ground of the head light connector). In other words, it just fits right in between the head light and the connector.
I tried grounding the device as normal (as per instructions) and tossed in a spare turn signal bulb to the lamp connector, but that didn't work.
Does anyone know:
1. What is the wattage that the system is looking for?
2. For some reason, if the bike wasn't running, LAMP failure wasn't being indicated initiallly.
3. Is there a ECM/software update to reduce the threshold like there is to get rid of the LAMP failure with BMW LED turn signals?
PatrickM is offline   Reply With Quote
Old 08-28-2013, 10:09 AM   #2
VikB
VikB's Avatar
Oddometer: 763
Originally Posted by PatrickM View Post
Anyone use them?
Nope and I hate running into folks who have them. They are completely obnoxious for other riders and drivers to have to deal with.
If you are concerned about a specific driver seeing you toggle your high beams a couple times.
Thankfully most riders around here don't use 'em.
safe riding,
Vik...
www.klr650blog.com
I didn't done the doo!
VikB is online now   Reply With Quote
Old 08-28-2013, 10:24 AM   #3
PatrickM OP
Oddometer: 366
Thanks for chiming in as someone who doesn't use them. I'm sure there are a lot of you.
Some of us do prefer using legal means to increase visibility. If you're not one of them, that's fine. It's the same argument I hear about "loud pipes saves lives" which actually does break the law in a myriad of places and as a motorcyclist is one of the chief criticisms of riders I hear of when discussing things that upset motorists.
It's patently obvious that these do increase visibility the same way that motion attracts attention by the human consciousness.
As I mention, I ride in places like CA where I can lane split and as I'm riding between lines of cars and I'll take an additional margin of safety.
But hey, it's probably cooler to mount up on a black bike, wearing all black leathers as well.
Old 08-28-2013, 10:48 AM   #4
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,758
another way would be to use aux lights to be seen. It's what I do. Fog lights that can be run at any time and some powerfull aux lights for the night use when nobody's on the road
Loutre is offline   Reply With Quote
Old 08-28-2013, 11:09 AM   #5
duffs
I have a beard
duffs's Avatar
Oddometer: 1,207
Anyone use them?
Does anyone know:
Firstly while it is legal in the US and your choice to run these, don't be lulled into a false sense of security that they will significantly increase your conspicuity - a study for the NHTSA showed there may be some increase in conspicuity, but there was not enough evidence for a recommendation. In other words, while they may help to some degree, wearing a bright/fluorescent jacket and simply having the headlamp on in the first place are more important.
1/3 - The CANbus is looking for a steady burning 55W H7 bulb to be fitted, as modulators are illegal in the EU the bike was never designed/intended to accommodate these (and BMW doesn't localise this for US models). The difference between LED and standard indicators is simply the wattage (2W vs 10W) since the CANbus is performing the flashing function - the software setting for this only reflects how much wattage the computer should expect based on which bulbs are being used.
2 - When the engine isn't running, firstly the computer keeps the headlamp switched off (only parking lamp), but also the computer assumes the bike will not be in motion and de-prioritises non-essential functions (ie if the headlamp is off, it's not a priority to check if it is functional) which may explain the delay. Its goal is self-preservation to ensure there is enough power to start the engine. For the same reason the handgrip heaters will not function unless the engine is running and there is sufficient charge in the battery (on very cold days where the battery struggles somewhat, the computer won't allow the grips to switch on).
Ride reports: Europe 2014 | Alps 2013 | Fryslân 2012
2012 F 800 GS Trophy 2014 R 1200 GS TE
Blog: Gelände Straßetastic! Facebook Tumblr
Ride reports, photos, tips, experiences, general twaddle
duffs screwed with this post 08-28-2013 at 01:21 PM
duffs is offline   Reply With Quote
Old 08-28-2013, 01:16 PM   #6
Full Power
Oddometer: 1,479
Headlamp "Modulators" are so annoying, even your MOTORCYCLE hates them.
Warm enough to RAIN is warm enough to RIDE.
Full Power is offline   Reply With Quote
Old 08-28-2013, 01:30 PM   #7
JoshBMW
JoshBMW's Avatar
Oddometer: 353
This; they are fing obnoxious.
Josh
"Integrity, justice, courage, and action - without these, a person is of no consequence." Don Nelson my friend gone from us, 06/06/04.
JoshBMW is offline   Reply With Quote
Old 08-30-2013, 12:07 AM   #8
Schai
Oddometer: 49
Sorry boys, but I'm a confirmed wimp. I don't like vacations in hospitals and my family actually likes having me around, if for nothing more than my credit card and checkbook.
I have a pair of bright, auxiliary LED flood lights on a modulator flashing on and off all day long. They are very visible from quite an angle off to the sides and very white. My friends tell me about the scares that they've had from cagers making left turns and coming out of side streets, but I haven't had a single such case in the 8,000 miles that I've had the bike.
I have the modulator and auxiliary lights on a relay and fuse from the battery, so the CANBUS doesn't know it. There are a couple of diodes in the wiring so the relay and lights come on with either the high beam or a switch from the low beam. The pair of lights were about $60 from Ebay. The Modulator, brackets, relay, connectors, etc., were another $130.
Schai is offline   Reply With Quote
Old 09-05-2013, 02:37 PM   #9
PatrickM OP
Oddometer: 366
That's my take as well. I changed out to HID for better visibility. Put in LEDs into the turn signals for increased brightness. Put on hyperlites because I do not want to be rear ended at an intersection, changed out the horn for a siebel to get attention of the person drifting across lanes, and finally... A headlight modulator.
With the HID running at 35W, I don't get a CANBUS error, and based upon what I'm reading, the headlight modulator isn't turning off the light, but reducing the voltage to. IIRC the turn signal is ~10W and when I hooked it up in parallel, it would still throw a LAMP failure. So somewhere between 35W and 10W is the sweet spot for an inline resistor.
No aux lights now, so can't place modulate them. But will see if I can get the new lights from BMW and potentially upgrade them to CREE LEDs as well.
Old 09-05-2013, 02:46 PM   #10
FredRydr
Danger: Keep Back 500 Ft.
FredRydr's Avatar
Oddometer: 2,460
They are annoying as hell, like loud pipes.
Fred
FredRydr is offline   Reply With Quote
Old 09-05-2013, 05:02 PM   #11
Full Power
Oddometer: 1,479
Nobody gets mesmerized, and then DRIVES right into a set of obnoxiously loud exhaust pipes.. HEADLIGHT blinkers, however have to be one of the absolutely most idiotic motorcycle accessories in use.
But, go ahead and MODULATE your way to Nirvana if you are so compelled.
Old 09-05-2013, 05:44 PM   #12
Emperor Norton
Kilroy was here
Emperor Norton's Avatar
Oddometer: 1,214
Interesting how the "don't like them" crowd seem to come from places where lane splitting isn't legal. I wonder if that has anything to do with it? Another curiosity, I wonder how many people who've made the "they're obnoxious" claim are running stock pipes or aftermarkets that are the same or lower decible rating as stock.
I loved the one I had on my Monster, but that wasn't a canbus bike.
Id also rather have people run modulators than some of those extra purple xenons, or the brighter than the sun "fog" lights.
Pics of whatever/where ever http://joee.smugmug.com
I used to be indecisive, now I'm not so sure.
Emperor Norton is offline   Reply With Quote
Old 09-05-2013, 06:14 PM   #13
FredRydr
FredRydr's Avatar
Oddometer: 2,460
WTF kind of logic is that? Okay, let's see if I can come up with the same kind of observation. I've never seen a headlight modulator in Italy, which makes California a lane-splitting joke.
Fred
Old 09-05-2013, 06:28 PM   #14
Hucker
Lost
Oddometer: 690
When I see a "modulated" bike from afar, my first reaction is that an emergency vehicle is coming. When I notice that it is a bike, I think, and
I also wonder about the possibility of target fixation by someone under the influence...like a little bug to the flashy-blinky-thingy...similar to the traffic cones on the side of the road, or the myriad emergency vehicles struck by DUIers. Just not my thing. And, my opinion is worth exactly what you just paid for it.
Hucker is offline   Reply With Quote
Old 09-07-2013, 08:59 AM   #15
cchoc
Outdoor Photographer
cchoc's Avatar
Oddometer: 203
Modulated headlights are guaranteed to make oncoming drivers mutter 'asshole' as they approach, at best.
Charlie...
Stalking Light
'13 F800GS Kalamata Metallic
cchoc is offline   Reply With Quote
Times are GMT -7.   It's 01:57 PM.
