Old 08-29-2013, 08:19 AM   #1
Rodknee OP
sensitive? who, me?
Rodknee's Avatar
Oddometer: 2,462
disable abs? it comes back on...
bike: 12' 990 ADV w/ abs. i go throught the 3rd button hold procedure, which disables the abs for what seems to be a few minutes then it reenables.
has anyone else had this issue? what am i doing wrong?
Originally Posted by DUCATIJAY View Post
I was at a restaurant and I noticed my waitress had a black eye. So I ordered very sloooowly because obviously she doesn't listen.
NY to Alaska Ride Report Aug 14'
2015 Rides: Katie M Big girl, Berg Hoon'icycle, some really fat dude's 690
RIP Buddy 1999-2014
Rodknee screwed with this post 08-29-2013 at 01:19 PM
Rodknee is offline   Reply With Quote
Old 08-29-2013, 11:48 AM   #2
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,576
Yeah every winter it comes back on my abs too
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is offline   Reply With Quote
Old 08-29-2013, 04:23 PM   #3
viverrid
not dead yet
Oddometer: 30,482
No.
Advanced pancreatic cancer found 04/2010. Have outlived +/- 97% of patients with this diagnosis, but 08/2013 cancer now in liver, vascular system and lungs with 20+ lung tumors. Sick/weak sometimes, not riding much. No more treatments & now under Hospice care.
viverrid is offline   Reply With Quote
Old 08-29-2013, 04:34 PM   #4
Pops of the desert
Oddometer: 82
Abs
Procedure is to start bike then press ABS button until it flashes, release button.
ABS button will now flash and ABS will be disabled until the engine is shut off or dies.
When not disabled ABS button goes dark after a few minutes of riding.
Are you sure yours is re-enabling?
It is a PIA when you kill the motor and restart because you now need to go thru the procedure all over.
Pops of the desert is offline   Reply With Quote
Old 08-29-2013, 05:14 PM   #5
Katoom72
Katoom72's Avatar
Oddometer: 861
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is offline   Reply With Quote
Old 08-29-2013, 07:03 PM   #6
Rodknee OP
sensitive? who, me?
Rodknee's Avatar
Oddometer: 2,462
positive. i was doing some very steep decents and i turned the abs off. for a couple hundred feet i could lock the rear wheel up, then it started pulsing again.
the first time i figured i didnt disable it, but it has done the same thing on me 4 separate times.
yes, i was thinking of cutting then switching the cable, but have not done it yet. i have a ride this sat where i will most likely have to disable the abs, so i wont have time to cut it and cleanly splice in a switch.
RIP Buddy 1999-2014
Old 08-29-2013, 07:24 PM   #7
ktmjohn
ktmjohn's Avatar
Oddometer: 206
Can you just remove the ABS fuse or rig it to a toggle switch ?
It doesn't have to be fun, to be fun.
www.lirtc.org | www.occr.net
ktmjohn is online now   Reply With Quote
Old 08-29-2013, 07:31 PM   #8
Jbone11 11
Jbone11 11's Avatar
Oddometer: 711
Yeah... I was thinking the same thing. I find the ABS more of a pain than anything, but I guess on pavement it has its uses. I definitely like that you can disable it...unlike the R.
2011 990 ADV
2000 996 SPS (SOLD)
2002 748E Bip
2003 Honda Hornet 600 (SOLD)
1969 BSA Royal Star - Let the Resurrection Begin!
Jbone11 11 is offline   Reply With Quote
Old 08-29-2013, 07:38 PM   #9
Rodknee OP
sensitive? who, me?
Rodknee's Avatar
Oddometer: 2,462
you can space the rear sensor out a bit and kill it that way. i do a lot of mixed surface rides, so i will most likely put in a switch.
most common method is to cut/splice the rear sensor wire, so the speedo is not affected.
RIP Buddy 1999-2014
Old 08-29-2013, 08:13 PM   #10
txbear55
Oddometer: 262
Yes, experienced the same on 2011. Did the "disabling switch" mod...works great now!
txbear55 is offline   Reply With Quote
Old 08-30-2013, 07:12 AM   #11
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 6,426
I'll guess that when you disable ABS and then skid the back on dirt that you kill the motor because the rear locks w/o clutch. It restarts when you let off the brake. You may not even notice, but enough to reset the ABS. Recluse EXP and I never have to think about clutching while braking again.
"got no problem with keeping truly roadless areas as wild....
On the other hand, if it has been logged or mined and roads already exist,,
...then that land should be open for public use" (peterman)
Apple Jam is offline   Reply With Quote
Old 08-30-2013, 07:24 AM   #12
Rodknee OP
sensitive? who, me?
Rodknee's Avatar
Oddometer: 2,462
Originally Posted by Apple Jam View Post
I'll guess that when you disable ABS and then skid the back on dirt that you kill the motor because the rear locks w/o clutch. It restarts when you let off the brake. You may not even notice...
umm, no. after 30 years of riding, i think i can figure out if i stall a motor or not.
downhill, clutch in, lock up the rear a few times, then abs re-enables and i am unable to lock the rear brake again. engine never skipped a beat. happened a few times. i'm perplexed.
RIP Buddy 1999-2014
Old 08-31-2013, 04:01 AM   #13
OlivierS
Oddometer: 98
Just pull the plug under the seat before you go offroad...
OlivierS is offline   Reply With Quote
Old 09-01-2013, 05:14 AM   #14
Rodknee OP
sensitive? who, me?
Rodknee's Avatar
Oddometer: 2,462
yesterday i did a bunch of muddy singletrack, and was able to finally disable to abs and not have it re-enable. OMG, i love this bike so much more now that i can pivot it at will... rear tires were lasting 800 miles, NOW what will they last?!?
it works now as advertised! i dunno, i didnt do anything differently. mebbie since my cooling fan was on for an hour, something "clicked"? voodoo? satanic worship?
i still plan to splice in a switch, but i need to do some riding first!
RIP Buddy 1999-2014
Times are GMT -7.   It's 04:28 PM.
