Old 08-29-2013, 09:23 PM   #1
2low2go OP
Oddometer: 10
Riding on tire with unseated bead for 1/2 mile
It's going to be a front tubeless tire. I need to change it out. I have no way of seating the bead at home. The nearest gas station is a 1/2 mile away. I'll install the tire on the wheel. Install the wheel. And slowly ride down to the pumps to air it up. What could go wrong?
2low2go is offline   Reply With Quote
Old 08-29-2013, 09:26 PM   #2
trc.rhubarb
trc.rhubarb's Avatar
Oddometer: 1,977
Walk with the wheel to the gas station?
Ride a bicycle with the wheel?
Get a ride from a friend with it?
It might go fine but probably wont end well to ride with a totally flat and unseated tire.
2007 BMW GS Adventure / 2000 Ducati 900ss / 2010 Harley Ultra Limited / 1975 BMW R90/6 / 2006 DRZ400S
Follow me here
trc.rhubarb is offline   Reply With Quote
Old 08-29-2013, 09:58 PM   #3
TortillaJesus
Authentic
TortillaJesus's Avatar
Oddometer: 3,680
Use a bicycle tire pump.
TortillaJesus is offline   Reply With Quote
Old 08-29-2013, 10:01 PM   #4
gearheadE30
gearheadE30's Avatar
Oddometer: 853
A bike pump should work fine. I've had good luck with silicone spray or WD40 on stubborn beads, but you should be fine without. If that for whatever reason doesn't work, it's 1/2 mile....just walk. A wheel isn't that heavy.
2005.5 KTM 950 Adventure and 2012 KTM 200 XC-W
1991 BMW 318is turbo track car
1989 Chevrolet Caprice Classic Wagon sleeper tow car
1992 Subaru SVX daily
3 Months Exploring the US on a 950
gearheadE30 is offline   Reply With Quote
Old 08-29-2013, 10:26 PM   #5
2low2go OP
Oddometer: 10
Okay. I'll walk it.
Old 08-29-2013, 10:35 PM   #6
randyo
randyo's Avatar
Oddometer: 1,662
not sure If I understand what you mean by unseated
1 you haven't got any air in the tires and can't get the tire to hold air
2 you have air in it, but tire beads haven't popped all the way out
#1 wrap a rope or belt around the circumference and tighten making the beads squish out to the rim of t he wheel then pump air in
or #2 put as much air as you can in, and bounce the wheel on the ground like a basketball, and rotate as you bounce it
RandyO
IBA # 9560
07 VeeStrom
99 SV650
82 XV920R
A man with a gun is a citizen
A man without a gun is a subject
randyo is offline   Reply With Quote
Old 08-30-2013, 01:35 AM   #7
farqhuar
Lone Wolf
farqhuar's Avatar
Oddometer: 1,088
1/2 a mile no problem. I recently had a flat in the desert and rode 200 mile with a totally flat front tyre - tyre is fine and still running it.
farqhuar is offline   Reply With Quote
Old 08-30-2013, 03:12 AM   #8
Ceri JC
UK GSer
Ceri JC's Avatar
Oddometer: 2,462
+1 on this.
With regard #2, even push bike pumps can put out enough PSI to usually seat a tyre. Just be sure to drop the pressure to the correct level after hearing both sides 'ping'.
I like my bike because I can overtake 4x4s down farm tracks with a week's worth of shopping on the back.
Ceri JC is offline   Reply With Quote
Old 08-30-2013, 07:34 AM   #9
hippiebrian
Oddometer: 3,339
Originally Posted by Ceri JC View Post
+1 on this.
This right here. I sometimes have to go as high as 70 psi to seat a tire and most bicycle pumps will pump to 100.
hippiebrian is offline   Reply With Quote
Old 08-30-2013, 08:42 AM   #10
trc.rhubarb
Oddometer: 1,977
While I agree here, I don't believe the results will be the same with a tubeless tire that is still sitting in the channel rather than up against the rim. The tire will just push aside leaving him to ride on the metal rim at best. Had the tire been seated then went flat, no problem.
It's also a real bitch to seat a tubless tire with a hand pump. Doable, but usually with a ratchet strap or some sort of tourniquet device. I bet I could walk the 1/2 mile each way before you could seat with a bike pump.
Follow me here
Old 08-30-2013, 10:54 AM   #11
ttpete
Rectum Non Bustibus
Oddometer: 5,758
Starting fluid and a match.........
15 BMW RnineT
09 Kaw Versys
Old 08-30-2013, 10:54 AM   #12
el queso
toda su base
el queso's Avatar
Oddometer: 686
Just wheelie it down to the gas station.
el queso is offline   Reply With Quote
Old 08-30-2013, 11:12 AM   #13
kerhonky
Adventure Poser
Oddometer: 1,144
Not that I'm an expert, but every time I've changed the tires on my V-Strom I've seated the beads using a hand pump. Didn't even have to go very far above the recommended pressure. A little bit of furniture polish spread around the rim helps.
Not calling you a liar or an idiot. I suppose there could be some variation in tires or rims that might make some combinations more difficult to seat. But my limited experience is that it's not a problem.
You learn something new every day if you're not careful.
"When you have to shoot, shoot, don't talk."
Tuco Benedicto Pacifico Juan Maria Ramirez, otherwise known as "The Rat."
kerhonky is offline   Reply With Quote
Old 08-30-2013, 11:20 AM   #14
randyo
randyo's Avatar
Oddometer: 1,662
just don't use too much starting fluid
never used that method on a bike tire, but used it once on a 6 foot tall tractor tire, and even in that size of tire it only took about a 0.25 second squirt of ether
RandyO
IBA # 9560
07 VeeStrom
99 SV650
82 XV920R
Old 08-30-2013, 11:52 AM   #15
Red9
Oddometer: 424
Why install the wheel?
Carry the wheel to the pump.
Red9 is offline   Reply With Quote
Times are GMT -7.   It's 03:31 AM.
