Old 08-30-2013, 11:59 AM   #16
Falconx84
Lurker
Oddometer: 371
Bike pump and windex... Worked out great on my Strom, just a little tiring. No straps or other tools needed.
Wish I took video of it, just didn't think it would work. You could probably have it done in less time than it takes to walk it to the shop
V-Strom DL1000k7
Falconx84 is offline   Reply With Quote
Old 08-30-2013, 02:29 PM   #17
ttpete
Rectum Non Bustibus
Oddometer: 5,754
Sometimes it works, and sometimes you get a tire that was at the bottom of a stack that's been squeezed flat.
15 BMW RnineT
09 Kaw Versys
ttpete is online now   Reply With Quote
Old 08-30-2013, 03:49 PM   #18
Andyvh1959
Cheesehead Klompen
Andyvh1959's Avatar
Location: Da frozen tundra eh? 1.5 mile west of Lambeau
Oddometer: 682
My experience with tubeless tires has been: once the tire is on the rim but still in the center, I take out the tire valve core and use shop air to "pop" the beads into place. Then after the air bleeds out the valve, I replace the core and pump the tire to the right pressure.
I'd ride carefully to an air pump on a tubeless tire that had already been set into the bead on the rim. I would NOT try riding on a tire that was still in the center of the rim.
When life throws you a curve,.....lean into it!
42+ year rider, 22+ year MSF Coach, Street, Dirt, Ice, ride em all!
Andyvh1959 is offline   Reply With Quote
Old 08-30-2013, 03:53 PM   #19
joexr
Oddometer: 3,773
Reading comprehension at its best.
Old 08-30-2013, 07:36 PM   #20
trc.rhubarb
trc.rhubarb's Avatar
Oddometer: 1,974
Originally Posted by kerhonky View Post
Not that I'm an expert, but every time I've changed the tires on my V-Strom I've seated the beads using a hand pump. Didn't even have to go very far above the recommended pressure. A little bit of furniture polish spread around the rim helps.
Not calling you a liar or an idiot. I suppose there could be some variation in tires or rims that might make some combinations more difficult to seat. But my limited experience is that it's not a problem.
Hmm, mine have always been a bitch, even with the air compressor. Often a lot of air leaks on my wheels until I get the tire pushed just right and it 'catches'
I've done with a handpump but never succeeded without a ratchet strap. Only done tires on the HD and GS. All other tires I've had were tube type.
2007 BMW GS Adventure / 2000 Ducati 900ss / 2010 Harley Ultra Limited / 1975 BMW R90/6 / 2006 DRZ400S
Follow me here
trc.rhubarb is online now   Reply With Quote
Old 08-31-2013, 05:38 PM   #21
ChaoSS402
Oddometer: 44
I vote for wheelie it.
ChaoSS402 is offline   Reply With Quote
Times are GMT -7.   It's 11:51 AM.
