Go Back   ADVrider > Fluff > Ask Baldy, blame AceRph
View Results: test poll
yes 0 0%
no 0 0%
maybe 0 0%
only on tuesdays 0 0%
not on your life 0 0%
Voters: 0. You may not vote on this poll
Thread Tools Rating: Thread Rating: 53 votes, 5.00 average. Display Modes
Old 01-22-2013, 05:02 PM   #4306
ADWrider
AKA Acorn27
ADWrider's Avatar
Oddometer: 88
vid test
http://www.youtube.com/watch?v=u2UP86bciVA
ADWrider is offline   Reply With Quote
Old 01-22-2013, 05:04 PM   #4307
ADWrider
AKA Acorn27
ADWrider's Avatar
Oddometer: 88
vid test 2
Old 01-22-2013, 05:05 PM   #4308
ADWrider
AKA Acorn27
ADWrider's Avatar
Oddometer: 88
vid test 3
Old 01-22-2013, 05:30 PM   #4309
knybanjo
kinda slow
knybanjo's Avatar
Oddometer: 24,225
smugmug animated gif sizing test
..nope..guess they only work in original size?
knybanjo is offline   Reply With Quote
Old 01-22-2013, 06:59 PM   #4310
CNDRAT
CNDRAT's Avatar
Oddometer: 13
Test
Triumph Sprint ST 2009
Yamaha RZ350 1985
Men do not stop playing because they grow old, they grow old because they stop playing - Oliver Wendell Holmes
CNDRAT is offline   Reply With Quote
Old 01-23-2013, 02:44 PM   #4311
pprO.R.A.
pprO.R.A.'s Avatar
Oddometer: 269
refresher
testing
another
Somebody could get their eye put out, or die, or even worse
pprO.R.A. is offline   Reply With Quote
Old 01-24-2013, 07:46 AM   #4312
Grinnin
Forever N00b
Oddometer: 2,835
Tabbed list.
Eureka! -- Spitfire 2 -- 2012 -- Aluminum -- 15"
Kelty -- Salida 2 -- 2012 -- Aluminum -- 18.5"
Morpho
Hmph! Tabs get compressed. Hmph!
Or, in "code" turned into several five spaces.
I can use HTML but I want to easily add submissions and it's been 12 years since I coded HTML.
Dashes?
Courier?
Code:
Eureka!    Spitfire 2    2012    Aluminum    15"
Kelty      Salida 2      2012    Aluminum    18.5"
Morpho
OK, can I do that entirely in the ADV editor?
HTML Code:
Eureka! &#9 -- Spitfire 2 -- 2012 -- Aluminum -- 15"
Morpho
No.
OK, let me try inserting an HTML table:
Eureka
Spitfire 2
2012
Alum
15"
Kelty
Salida 2
2012
Alum
18.5"
REI
Camp Dome
2013
Half Dome1990Aluminum21.5"
Needs work.
Working space for recode:
Brand
ModelYear or versionMaterialLengthAngles/hubs/spiders
Alps MountaineeringMystique 2.02012Aluminum(44cm) 17"
Taurus 2
Fiberglass(51cm) 20"
Big AgnesBig House 42013 Aluminum(65cm) 25.5"
Copper Spur UL22010Aluminum 54cm (21.5")Aluminum hubs
Copper Spur UL22011/2012Aluminum(42cm) 16.5"Aluminum hubs
Emerald Mountain SL2
(47cm) 18.5"
Gore Pass 3
(51cm) 20"
Black DiamondMesa2009
54cm/ 21.25"1 hub
CabellasXPG Ultralight (3-person)
Aluminum(45cm) 17.5"
EurekaApex 2XT2007Fiberglass
(47cm) 18.5"
Backcountry 1 and 2
Aluminum(36cm) 14"
Spitfire 12011 (?)Aluminum35cm, 14"Angles strung in-line
Spitfire 22012Aluminum(38cm) 15"Angles strung in-line
Mountain Pass 2XTE2012Aluminum(41cm) 16"
Timberline 4
Aluminum(52cm) 20.5"2 hubs
Golite
Imogene UL2
2013
Aluminum
(46cm) 18"
KeltyGrand Mesa 22010Aluminum47cm (18.5")
Gunnison 2
(47cm) 18.5"
Salida 22011/12Aluminum(47cm) 18.5" or (46cm) 18" (either can compress about 1/2" in length)
Stick 12009 Aluminum16"
Trail Dome 42011Aluminum(55cm) 21.5"
MarmotAstral 2P
Aluminum(59cm) 23"
Mountain HardwearCorners 4
(54cm) 21"
Super Mega Ultralight 22012
53cm, 21"1 hub, one bend
MSRHubba2008
Aluminum49cm, 19.25"2 hubs
Hubba Hubba2011Aluminum43cm, 17"aluminum hubs (2)
Zoid 12007Aluminum47cm (18.5")Angles
NemoMorpho 2P2011InflatableShort
REICamp Dome 22013Aluminum52cm 20.5"
Half Dome Plus 2
Aluminum(46cm) 18"
Half Dome 4 (name applied to different designs)2012Aluminum(59cm) 23"Angles + hubs
Sierra DesignsCirrus 3
Aluminum 45cm, 17.5"
Clip Flashlight 22002
Aluminum46cm, 18"
The North FaceBedrock 42012/13Aluminum(52cm) 20.5"
Big Fat Frog2010Aluminum53 cm, 21 in4 poles, 2 with angles
Flint 22012Aluminum (2)(51cm) 20"
Tadpole
Aluminum(37cm) 14.5"
End of re-code.
"The belief that there is only one truth, and that oneself is in possession of it, is the root of all evil in the world."-- Max Born, Nobel Physicist
Grinnin screwed with this post 03-15-2013 at 06:03 AM
Grinnin is offline   Reply With Quote
Old 01-24-2013, 11:50 AM   #4313
ixab
just Aaron, really
ixab's Avatar
Oddometer: 376
vimeo - old style embed
VT moto from Aaron B on Vimeo.
Doooood. It works without having that 'switch edit mode' button that the other thread talks about. However, when you preview your post, it just looks blank, and when post, it just looks blank as well. You have to post, then reload the page, and DING! there's your vid.
Now... I wonder if there's a way to use the newer iframe embed tag...
Youtube - Death, Death, Everywhere!
ixab is offline   Reply With Quote
Old 01-24-2013, 11:55 AM   #4314
ixab
just Aaron, really
ixab's Avatar
Oddometer: 376
Vimeo - iframe embed
I suspect iframe is parsed out, since there's all kinda cross site weidness you could achieve with iframes....
And, I was wrong! So, you can use the newer iframe embed from vimeo, just copy and paste and let it rip. Neat.
Old 01-24-2013, 02:00 PM   #4315
2manyrides
shifty charactor
2manyrides's Avatar
Oddometer: 1,621
testing
This is a test to see if I embed a videom then change the embedding selection on youtube, if the video is taken down or remains up as it was embedded before the change took place...
You'll see the results shortly as I perform this rask...
Edit,....,
OK
so even though I disabbled it on youtube, the fact that I still had the code in my copy/past clicker, it let me embed it again.
that said the question I was asking myself is, if I shut embedding down will that take away the videos that all those people were robbing from my site to post on their own. But the answer is NO
Once they have the code, they are good to go. And it also tels me I'll have to go through and disable all embedding, Then if I want to embed some where I'll have to temporarily enable to get the codem shut it back doen, then it wioll be safe to have my stuff viewable on my channel and where I choose to embed only.
Those that have gotten away with it to this point are just that, getting away with rocking tunes for no charge that they can draw people to their site with.
The final truth is to give this an hour or so, come back here and see if it's all still "up".
See ya then...
nerpnilknarf
Yep it's all still here! edit 1 hour later
too many...
I have completely lost count
and here's my channel...
http://www.youtube.com/user/2manyrides?feature=mhsn#p/u
2manyrides screwed with this post 01-24-2013 at 03:31 PM
2manyrides is offline   Reply With Quote
Old 01-25-2013, 10:18 AM   #4316
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,527
Photo & Video Sharing by SmugMug
Old 01-27-2013, 04:56 PM   #4317
Haggs
Tigre Verde
Haggs's Avatar
Oddometer: 134
Signature test
2013 TIGER 800XC KHAKI
Haggs is offline   Reply With Quote
Old 01-29-2013, 12:30 AM   #4318
sidetrack one
Chief Tiddler
sidetrack one's Avatar
Oddometer: 5,682
Originally Posted by woopwoop View Post
Press "quote" on original post, copy quote from "Reply to Thread", do not press "Submit Reply", paste into "New Reply" in desired thread.
test!
I live more in 5 minutes on my motorcycle than some people live in a lifetime...............
Where are my pants?
www.buyabale.com.au.. Our farmers thank you!
sidetrack one is online now   Reply With Quote
Old 01-29-2013, 10:20 AM   #4319
OTB
Oh fer Chrissakes
Oddometer: 7,473
He not busy being born is busy dying
OTB is offline   Reply With Quote
Old 01-29-2013, 02:06 PM   #4320
rockyroad
Oddometer: 137
sunrise photo[/IMG]13-01-11%2007.56.41-L.jpg[/img]
rockyroad is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 06:39 PM.
