Go Back   ADVrider > Fluff > Ask Baldy, blame AceRph
View Results: test poll
yes 0 0%
no 0 0%
maybe 0 0%
only on tuesdays 0 0%
not on your life 0 0%
Voters: 0. You may not vote on this poll
Thread Tools Rating: Thread Rating: 52 votes, 5.00 average. Display Modes
Old 05-03-2013, 05:23 AM   #4546
travelingaustralian
Globe Trotting
travelingaustralian's Avatar
Oddometer: 95
test larger picture
“There are no foreign lands. It is the traveler only who is foreign.”
"Quad Biking in Antarctica"----->http://advrider.com/forums/showthrea...886240&page=10
travelingaustralian is offline   Reply With Quote
Old 05-03-2013, 05:54 AM   #4547
travelingaustralian
Globe Trotting
Oddometer: 95
Resized
Old 05-03-2013, 07:28 AM   #4548
Superzoom
Superzoom's Avatar
Oddometer: 553
Superzoom screwed with this post 05-03-2013 at 07:43 AM
Superzoom is offline   Reply With Quote
Old 05-03-2013, 07:40 AM   #4549
Superzoom
Superzoom's Avatar
Oddometer: 553
0123456789120709154322
Old 05-03-2013, 07:03 PM   #4550
Averse2work
über n00b
Averse2work's Avatar
Oddometer: 9
Test
test
Averse2work is offline   Reply With Quote
Old 05-04-2013, 05:21 AM   #4551
Averse2work
über n00b
Oddometer: 9
Originally Posted by sunset_ryder View Post
test
that's it
Old 05-05-2013, 01:53 PM   #4552
team8
team8's Avatar
Oddometer: 429
video test
team8 is offline   Reply With Quote
Old 05-05-2013, 02:39 PM   #4553
team8
team8's Avatar
Oddometer: 429
Sent from my DROID RAZR HD using Tapatalk 2
Old 05-05-2013, 02:41 PM   #4554
team8
team8's Avatar
Oddometer: 429
Test
Old 05-06-2013, 07:01 PM   #4555
sccommuter
sccommuter's Avatar
Oddometer: 1
test
sccommuter is offline   Reply With Quote
Old 05-07-2013, 10:32 PM   #4556
12120
Indenturedx5
12120's Avatar
Oddometer: 432
testing
video?
If you find yourself in a fair fight, your tactics are wrong.
'83 XL 600r
12120 is offline   Reply With Quote
Old 05-08-2013, 08:53 AM   #4557
leo_jb
leo_jb's Avatar
Oddometer: 133
http://leobragagnolo.zenfolio.com/p5...2552#h47de2552
leo_jb is offline   Reply With Quote
Old 05-08-2013, 11:49 PM   #4558
travelingaustralian
Globe Trotting
Oddometer: 95
Test Panoramic shot.
Old 05-09-2013, 08:28 AM   #4559
Shooby
Anti-Cager
Shooby's Avatar
Oddometer: 991
Test
Resized
Shooby screwed with this post 05-09-2013 at 08:34 AM
Shooby is offline   Reply With Quote
Old 05-10-2013, 10:35 PM   #4560
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,543
Do NOT try to adjust the collars on the 1981 and later pushrod tubes...they are brazed in place. It is unclear to me exactly when the brazing first began; I believe it was phased-in during the 1981 production year. I HAVE seen earlier brazed ones! Some literature will state that it was from the 1981 change to Nikasil cylinders. If you have earlier adjustable ones, you could back them off a bit before assembling the cylinders to the block, and adjust them after you are all done. Frankly, I feel these should not be touched at all unless grossly wrong; and setting them too tight to the seals is hard on the seals, particularly the /5 types. The WORST thing you can do would be to bang on them and damage; or, WORSE, move the tubes. If you insist, there is a BMW tool ....HOWEVER, a very simple tool from a piece of old electrical conduit can be used to work on the collars. See any Clymer's or Haynes for the sketch....but, again, I feel you should leave the movable version of the collars alone, unless grossly at the wrong depth. The collar ring is about 5 mm below the cylinder base seating plane surface at the highest point. One thing you sure want to do is avoid ever having to replace a pushrod tube, as the process and special tool needed is unpleasant, and you surely will ruin some new tubes in the learning process. Aftermarket stainless steel ones are the way to go. You need a well-fitting mandrel. Seibenrock makes one, I think.....and there is also the front axle! More information later in this article, because some of you WILL someday replace tubes. Perhaps yours are rusting or leaking.
---Albert Einstein
disston is online now   Reply With Quote
Thread Tools
Times are GMT -7.   It's 02:49 AM.
