Old 09-02-2013, 01:59 AM   #1
karabasan OP
Oddometer: 29
19/17 Suspension set-up question 990ADV
Hi all,
I have recently had my suspension and rear shock serviced, together with tire change.(Conti Road Attack2)
Now all adjustments are set to standard.
However the front tire start to vibrate side to side over speeds of 80 Mph(135kph).
Any ideas about which adjustments to go first for the front to settle down are more than welcome
Note: The tires were balanced properly before put on. Plus the tire pressures are 34-38 (f7R)
Thank you ,
karabasan is offline   Reply With Quote
Old 09-02-2013, 03:23 AM   #2
Yascher
Yascher's Avatar
Oddometer: 388
Hi,
you have changed many things at once, try to change the tire first!
I've experienced these tires wobble on 1190 from factory, no balancing helps
Yascher is offline   Reply With Quote
Old 09-02-2013, 07:44 PM   #3
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,457
Contis...check and see where the tire was made. If it's from Korea, check for an out of round tire. I've had three of those.
For Sale: 2012 KTM 990 Adventure
Chuckracer is offline   Reply With Quote
Old 09-02-2013, 08:34 PM   #4
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,151
I'd max out front preload if you're on stock springs.
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Old 09-02-2013, 11:59 PM   #5
karabasan OP
Oddometer: 29
It is made in Germany.
I will try changing the preload.
There is also the idea of rising the fork stanchions 10mm , however I am not sure on doing that.
Before the Road Attacks I had Pilot Road 1 on the front and there was no wobble.
So I think it is whether a faulty tire or a suspension set up issue.
Old 09-03-2013, 11:32 PM   #6
slackmeyer
slackmeyer's Avatar
Oddometer: 3,151
Well, that makes it sound like your tire. I don't know about the profile of the contis in that size, but I have thought that other contis had too much of a v shaped profile for my taste, and I prefer michelins, I'm using the pilot road 3 19" as my front tire, it works great.
Zak
ktm
old bmw
others
Old 09-04-2013, 01:29 AM   #7
Yascher
Yascher's Avatar
Oddometer: 388
+1 on the road 3 19/17 -best so far
Times are GMT -7.   It's 06:11 AM.
