Go Back   ADVrider > Riding > The Perfect Line and Other Riding Myths
Old 09-02-2013, 08:35 AM   #1
randyo OP
randyo's Avatar
Oddometer: 1,807
Studs
it's getting to be that time of year, winter will soon be upon us and I am trying to decide which route to take
my previous experience with studs, I drilled stud pockets in Karoo Ts and inserted standard automotive studs with a pneumatic gun, I got 1 season out of the rear then went to the darkside with a General Altimax Arctic in the rear which I will continue to use
my front lasted 4 seasons but now must be replaced, I am debating using Aerostitch self tapping studs instead. Anyone with any experience that can tell me if they work better or worse than regular studs ? Cost for studs from Stitch is outrageous,$109 per bag of 100.
I know I'll need about 180 studs for my front wheel, I stud the center heaviest and the further from the center the fewer studs, outer knobs I leave unstudded, my theory is on ice, I won't be leaning much and when I am on dry pavement, I will want a rubber contact patch instead of studded after 4 winters and some insane conditions, my theory has held
auto studs are $75 for a bag of 1000, I'm also thinking buying my own pneumatic gun $350-$400
because the pockets that get drilled are not the correct shape like a molded stud pocket in a car tire, it takes 50-100 mile of sketchy riding for the studs to get seated, but once they get seated
in 4 winters/approx 14k miles of use, I didn't throw any studs in the front tire
I guess mostly I'd like experience of performance, longevity and whether or not Aerostitch studs are subject to getting thrown
RandyO
IBA # 9560
07 VeeStrom
99 SV650
82 XV920R
A man with a gun is a citizen
A man without a gun is a subject
randyo is offline   Reply With Quote
Old 09-02-2013, 10:27 AM   #2
windmill
windmill's Avatar
Oddometer: 4,084
I've used both, and find standard automotive studs will stay in place longer. Function wise there is absolutely no difference.
Keep in mind I'm using them on a sidecar rig that subjects them to lateral loads not experienced on a 2 wheeler, and that I push it much harder than you can on a 2 wheeler, so YMMV.
A local tire shop will stud my tires for $40, as apposed to $100 for 1.5 tires with the aerostitch studs.
"Take care, sir," cried Sancho. "Those over there are not giants but windmills".
windmill is offline   Reply With Quote
Old 09-02-2013, 11:07 AM   #3
randyo OP
randyo's Avatar
Oddometer: 1,807
do you drill your own stud pockets or do they so that as part of the $40?
RandyO
IBA # 9560
07 VeeStrom
99 SV650
82 XV920R
Old 09-02-2013, 02:45 PM   #4
iamcanjim
Face drop
Oddometer: 756
Here are some.
Wait, what?
iamcanjim is online now   Reply With Quote
Old 09-02-2013, 04:32 PM   #5
windmill
windmill's Avatar
Oddometer: 4,084
Started out that they would drill them, but they decided it was too time consuming, and wanted $20 more if they drill.
Old 09-02-2013, 04:35 PM   #6
RobbieO
Muskokatard
RobbieO's Avatar
Oddometer: 9,107
Only a biker knows why a dog sticks his head out of a car window.
RobbieO is offline   Reply With Quote
Old 09-02-2013, 04:53 PM   #7
Kafn8td
Oddometer: 179
I quit wasting my time. http://www.frpoffroad.com/Motorcycle...Id=-1039&fpg=1
Kafn8td is online now   Reply With Quote
Old 09-02-2013, 05:01 PM   #8
KustomizingKid
Oddometer: 678
I have done a lot of research on studs... There is a big difference between street studs and ice racing studs. Tungsten carbide is expensive, but the best for on the street.
Those gnarly tires and linked ones are much more ice racing oriented.
2000 Xr650r!
KustomizingKid is offline   Reply With Quote
Old 09-02-2013, 05:20 PM   #9
randyo OP
randyo's Avatar
Oddometer: 1,807
I have heard for other sources that aerostitch studs don't stay in place as well
as far as pushin it, when riding in blizzard conditions or other "only lunatics are on the road conditions" , I find myself catching up with what ever is in front of me, then waiting for them to pull off, so I can speed up again, the car tire in back was an experiment that was successful beyond my wildest expectations and its not even studded, just a regular old winter tire
what tires are you studding ? I had good luck with the Karoo T, which I'll probably use again, knobs are deep enuf for a 10mm stud
RandyO
IBA # 9560
07 VeeStrom
99 SV650
82 XV920R
Old 09-02-2013, 09:19 PM   #10
windmill
windmill's Avatar
Oddometer: 4,084
I've studded the Heidenau K37, Duro 207, and the Kenda 335. Unfortunately there are no automotive winter tires that will fit a Ural, though the k37 is also available in a winter traction compound they call "snowtex".
When I say "pushing it" I mean nonsense such as drifting, full throttle power slides, doing doughnuts, steep climbs over rocks and deadfalls when off pavement, and riding snowmobile trails, which are all tough on studs.
If you look close, you can see aerostich studs in a Duro 307 on the spare tire. I usually save it just for bad conditions such as solid ice, or fresh snow over compact snow or ice.
windmill screwed with this post 09-02-2013 at 09:24 PM
Old 09-03-2013, 05:32 AM   #11
Kafn8td
Oddometer: 179
Ahh sorry, I thought you were building them for the ice.
Old 09-03-2013, 06:03 AM   #12
randyo OP
randyo's Avatar
Oddometer: 1,807
http://www.youtube.com/watch?v=NDrRieJK3aQ
RandyO
IBA # 9560
07 VeeStrom
99 SV650
82 XV920R
Old 09-03-2013, 08:19 AM   #13
i_isntreal
Oddometer: 104
Concerning drilling your own tires for automotive studs, I did it for my truck tires. The local tire shop 'experts' said that they would all fall out right away because of not having the correct ' mushroom shaped' hole. So I proved them wrong by doing a two step drilling process that gave me the correct hole shape (time consuming). Not to mention that I also dipped the studs in rubber cement before riveting them in (extra time consuming and messy). Worked like a charm and only lost 1 or 2 studs a tire over two winters of doing donuts and tail slides at every opportunity. It was definitely worth all the effort (and always enjoyable to prove the 'experts' wrong)
Back to motorcycles, a former coworker did a lot of research into tire studding while making his own studding apparatus that took far less time than the hand gun. He commented that they used a black locktite for extra assurance. His experience was that the locktite bond was stronger than the rubber and studs that did come out had literally ripped a chunk of tire out with it.
For every mile of road there are two miles of ditches.
i_isntreal is offline   Reply With Quote
Old 09-03-2013, 09:36 AM   #14
randyo OP
randyo's Avatar
Oddometer: 1,807
I say not worth the effort
I just drilled straight holes using a burr bit
did not loose a single stud in 4 winters/14k miles on my front tire
RandyO
IBA # 9560
07 VeeStrom
99 SV650
82 XV920R
Old 09-04-2013, 09:49 AM   #15
scottrnelson
Team Orange
scottrnelson's Avatar
Oddometer: 1,514
Cool2
This is a nice problem that I don't need a solution for.
I'm curious how those studded tires behave on paved roads that aren't covered in ice or snow. I would expect them to be kind of dangerous in those conditions.
scottrnelson is online now   Reply With Quote
Times are GMT -7.   It's 07:51 AM.
