Old 09-03-2013, 12:44 AM   #1
Schweitzer OP
Oddometer: 52
Oil drops under side stand on 08 990
Just noticed some drops of oil (3 or 4 overnight) just below the side stand of my 2008 KTM 990 with 30k miles. I'm heading for Steamboat on the 6th and wondering if anyone has any ideas. Like can I make a 12 day trip with a minor oil leak. I'm not mechanical and doubt my dealer can get it in to look at. It started dripping just before I had an oil change a few days ago. The shop didn't see anything during the service. Damn, I don't want to miss this trip. Planning on 2 legs of the UTBDR and the whole CBCDR. I can certainly carry some oil but I don't want to screw anything up. Anyone have any experience with this. Thanks.
Schweitzer is offline   Reply With Quote
Old 09-03-2013, 01:29 AM   #2
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,190
Look at the o-ring behind the gear shift sensor. Right behind the side stand bracket. It's an easy fix.
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 09-03-2013, 03:06 AM   #3
Yascher
Yascher's Avatar
Oddometer: 388
hopefully not a cracked case
Yascher is offline   Reply With Quote
Old 09-03-2013, 03:28 AM   #4
bikyto
bikyto's Avatar
Oddometer: 2,190
Indeed…
Old 09-03-2013, 03:33 AM   #5
Alblue
Oddometer: 36
Spooge from chain lube slinging off primary sproket?
Alblue is online now   Reply With Quote
Old 09-03-2013, 03:40 AM   #6
Orangecicle
On a "Quest"
Orangecicle's Avatar
Oddometer: 3,018
Wash up the area as best you can and spread some talc powder around. Run the bike for a bit, and the source of your oil should reveal itself pretty quickly. Most likely the shift sensor. Less likely, a shifter arm seal or a cracked case. But the leak can come from higher up, like a leaking oil pressure sensor in the middle of the V of the engine.
Orangecicle is offline   Reply With Quote
Old 09-03-2013, 06:08 AM   #7
Lycan1
Grizzly herder
Lycan1's Avatar
Oddometer: 956
That is exactly what it was when mine did that. It was easy to spot when you started looking around with a flashlight.
I've learned so much from my mistakes. I'm thinking of making a few more.
09 KTM 990 Adv
Lycan1 is offline   Reply With Quote
Old 09-03-2013, 07:35 AM   #8
Sevv
Oddometer: 101
Happened on my sm. Was the gear position sensor o-ring.
Sevv is offline   Reply With Quote
Old 09-03-2013, 07:43 AM   #9
triplenickel
triplenickel's Avatar
Oddometer: 2,428
Yes, just keep an eye on it.
07 SE
PG007
Old 09-03-2013, 07:45 AM   #10
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
I had the same oil spot underneath the side stand on my 2012 990 Adv R. I initially thought the worst: cracked case, oil seal somewhere..... However, it turned out that the Uni oiled foam air filter I am using was over oiled and was dripping some air filter oil from the airbox down the side of the bike and onto the floor. I cleaned up the excess air filter oil from the ground, the side of the bike, and the airbox. I also grabbed some paper towels and soaked up the excess air filter oil from the filter and reinstalled it. All is well now and the air filter isn't dripping excess oil.
Just follow/track the oil trail up the side of the bike to find out where it is originating. I had to take the tank off to get a good view in order to do this.
Could also be that your engine is burping up oil from the crank case into the airbox too.
At any rate step one is to remove the tank and track the oil trail to the point of origin. Most of the time these things turn out to be simple and they make you go d'oh!
Good luck.
Old 09-03-2013, 08:26 AM   #11
mjskier
mjskier's Avatar
Oddometer: 495
Cam chain tensioner gasket
Same thing happened on my brand new 2012 SMT
It turns out the rear cylinder cam chain tensioner gasket must have had a small imperfection because that's where the oil was seeping out of. The shop just resurfaced it (they didn't have a replacement in stock) and no more oil on the floor.
mjskier is online now   Reply With Quote
Old 09-03-2013, 09:38 AM   #12
rburkat
rburkat's Avatar
Oddometer: 293
Good recommendation. Had same issue on mine and initially I thought it might be a cracked case due to side stand, as the gear shift sensor is right in that area and oil leaking from it then runs down the side stand relocator.
rburkat is offline   Reply With Quote
Old 09-03-2013, 04:00 PM   #13
Pumbaa
Oddometer: 10
Had same on mine. The o-ring had to be replaced. Easy fix
Sent from my HTC J Z321e using Tapatalk 2
Jacques & Mandy with Pumbaa II
www.seeyouwhenwegetthere.com
...looking for Pumbaa III (or little Pumbaa)
Pumbaa is offline   Reply With Quote
Old 09-03-2013, 06:12 PM   #14
Schweitzer OP
Oddometer: 52
Thank you all for your input. The oil drip is coming off the side stand relocator mounting bolt so I'm hoping it is the shifter o-ring. It's in the shop now for tires so they are going to check it out. So leak, or no leak I'll be in Steamboat for the rally.
Old 09-03-2013, 06:31 PM   #15
benh
lookin 4 a way outta town
benh's Avatar
Oddometer: 262
This was the issue with mine; it was an easy fix. Considering how minor, I wouldn't be concerned about the upcoming ride if that is the issue
My ambition far exceeds my talent...
benh is offline   Reply With Quote
Times are GMT -7.   It's 05:28 AM.
