Old 09-04-2013, 08:49 AM   #1
RAE129 OP
Oddometer: 33
2013 Baja Stall
Brand new 2013 990 baja, 800 miles, 1st service performed over this past weekend at dealership...
Was on the highway last night and got off at exit ramp...pulled clutch in an blipped throttle to downshift into lower gear and bike studdered and stalled. I pulled to the side and restarted her. Put bike in gear, moved to traffic signal, and rolled on and off throttle...bike stalled again... Started bike again and rode home with no more issues.
WTF is going on? I am going to go over bike tonight to see if the petcocks are fully open since the service was just performed. Anything else i should look into? kinked fuel line?
RAE129 screwed with this post 09-04-2013 at 09:17 AM
RAE129 is offline   Reply With Quote
Old 09-04-2013, 09:18 AM   #2
KMC1
There is no spoon.
Oddometer: 2,561
Is the idle all messed up?
Obama says adding $4 trillion to debt is unpatriotic: http://www.youtube.com/watch?v=1kuTG19Cu_Q&sns=em
An Overview of the United States National Debt: http://www.davemanuel.com/us-national-debt-clock.php
KMC1 is offline   Reply With Quote
Old 09-04-2013, 09:27 AM   #3
ztrab
ztrab's Avatar
Oddometer: 702
Stalled
NEW YOUR CITY (must be shouted three times while circling the bike counterclockwise). Read your manual, the bike only operates properly if you are in Baja.
Sigh, sorry. I have only ridden with two 990's and both had weird idiopathic idle and stalling issues. One of them swore by a ECU reset ritual well-documented on a thread somewhere here in the KTM chatter. Great bike when they are sorted out though I always cringed when one of them used to bring it to my garage to work on, sheesh.
Good luck.
09 1200 SGA
07 1200 GS SOLD
06 HP2 (damn it Cartwright) Sold
05 ZX 10 Track bike - (see above)
06 GSXR 600 Track Bike -ditto above :-)
06 525 EXC
06 525 EXC motard
07 12 GS for Jr. with a brand new motor12/09!
06 525 EXC for Jr., new motor, ugh
09 690 Enduro R... I know, I know
ztrab is offline   Reply With Quote
Old 09-04-2013, 09:45 AM   #4
RAE129 OP
Oddometer: 33
idle seems fine...
Old 09-04-2013, 09:51 AM   #5
Katoom72
Katoom72's Avatar
Oddometer: 915
Perform the 15minute idle procedure, see if that helps.
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is offline   Reply With Quote
Old 09-04-2013, 10:03 AM   #6
RAE129 OP
Oddometer: 33
Good luck.
Zrab...if she keeps stalling i wont be able to get to the baja... :-)
The ECU reset was going to be my next approach
Old 09-04-2013, 01:41 PM   #7
stephanektm
stephanektm's Avatar
Oddometer: 101
I think i got your answer: fuel pump! Mine busted at 600km its warrantied and i had the same problems you did!! Except when it happened to me it was pooring rain so i was double pissed!!
It kept shutting off after i put it second and gave some gas!! Bring it to your dealer quick ! So you can get it back quickly!! I have 4680km on mine since and everything is A-1!! Good luck!
if it don't smell gas, it ain't no sport....
don't dream : live!!
don't think : believe!!
don't hesitate : go for it!!
when in doubt : gas 'it!!!
stephanektm is offline   Reply With Quote
Old 09-04-2013, 02:56 PM   #8
KMC1
There is no spoon.
Oddometer: 2,561
That's so soon for the pump to be bad! I am thinking it's a fueling issue, only because you're able to start it and idle it. Almost like a bad pump or a clogged filter.
That would be pretty piss poor if it's the pump already though!
Old 09-04-2013, 03:50 PM   #9
Skinner
Mr.KTM
Skinner's Avatar
Oddometer: 5,754
You just had it serviced, check the tank vent lines are not kinked
You might be an ADVRider if:
You recognize your friends by the sound of their mufflers.
http://www.meetup.com/Chicagoland-Du...torcycle-Club/
www.jimstarwaltteam.com
Skinner is offline   Reply With Quote
Old 09-04-2013, 04:14 PM   #10
stephanektm
Oddometer: 101
My mechanic thought it was me filling up the bike with gas real close to the edge when its specificaly said not too especially on the right side!!
It was not! He even thought it might be water in the tank or pump or filter since it happened when it was raining so much!! It was not! Last chance the pump it self! I'm not the first to who. It happens but it didn't happen often!!! So i'm pretty sure from the trouble he's having that it's the pump!! 600$ pump 3 hours of work! Warrantied! It is piss poor that on such a great bike you get a problem like that i totally agree!!
Old 09-04-2013, 04:51 PM   #11
tedmarshall
tedmarshall's Avatar
Oddometer: 563
Hmm. I thought they solved fueling issues
My 2010I bought new 7/11 did same things until I installed Power Commander V using the Akro map.
When I trade mine in on the new 1190R next year I am trusting (stupid I know) that all the reviews have been correct that KTM has solved the endemic fueling issues.
Ted
tedmarshall is offline   Reply With Quote
Old 09-06-2013, 07:05 AM   #12
RAE129 OP
Oddometer: 33
Well petcocks, vents, and all else seemed ok. Bike started right up and i let it run for 15 minutes at idle. I will let you all know if it happens again.
Old 09-06-2013, 01:14 PM   #13
ColoradoBigfoot
ColoradoBigfoot's Avatar
Oddometer: 148
Although undocumented and made up by me, you are entering "Stage Two" KTM ownership.
Stage One = Total bliss. Euphoria.
Stage Two = Discovery. Reality. Commitment.
Stage Three = Invest. Repair. Replace.
Stage Four = Total bliss. Euphoria (again).
Stage Two might be the most difficult to overcome. Some cannot (me), many more have. There is no definite timeline for each stage, although Stage Two comes on within a year of purchase. Total bliss and euphoria are not obtainable during Stages Two and Three (too much focus on problems and repairs). Not sure if Stage Four is everlasting or if you go back and forth between three and four (most likely). I really, really liked Stage One. Stage Two?...not so much . I friggin' loved riding the 990r!
ColoradoBigfoot is offline   Reply With Quote
Old 09-06-2013, 05:56 PM   #14
Rodknee
sensitive? who, me?
Rodknee's Avatar
Oddometer: 3,005
ok, we get it. you hated your 990 experience, and sold it for japanese awesomeness. please go troll elsewhere.
Originally Posted by DUCATIJAY
...and that’s how I met Dickey Wittenberger, horrible agent but a beautiful man.
2015 Rides: Katie M Big girl, Berg Hoon'icycle, Katoom 3hunny (pic)
Rodknee is offline   Reply With Quote
Old 09-06-2013, 08:09 PM   #15
stephanektm
Oddometer: 101
I always had stage 1 on my 950 but on my 990r i found muself going through all four stages and would even add one more stage
Stage 5: have a cold BEER!!! Yeah! That's it!!
Times are GMT -7.   It's 08:48 PM.
