Old 09-04-2013, 01:03 PM   #1
ericGSsti OP
ericGSsti's Avatar
Oddometer: 570
Fuel off loading from the left tank to the right tank causing it to over flow.
So for the second time since I got the bike I've seen the Fuel cross load from the left tank to the right tank causing it to over flow. Both times its happened when it's on the side stand and I've filled the tanks earlier in the day. Spills out of it at a steady rate. I've opened both fuel tanks both times and the fuel level equalises. I've now closed of the right tank altogether to stop the fuel entering it from the left.
Anyone come across this before?
2004 KTM 450 exc, 04 KTM 950 Adventure S.
ericGSsti is offline   Reply With Quote
Old 09-04-2013, 01:21 PM   #2
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,470
After performing the canisterectomy, route your vent hose up into the fairing to a point higher than the tanks. This should solve the problem.
Shown here partially done.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 09-04-2013, 02:07 PM   #3
Jaimoto
Spaniard in Chile
Jaimoto's Avatar
Oddometer: 1,305
No canister on EU bikes.
Eric, it sounds like the left tank is building pressure up and the only way to release this pressure is through the right tank. I would look for a pinched or clogged front ventilation hose in the left tank.
Jaime
Big, Loud and Orange KTM 990 Adv
Jaimoto is offline   Reply With Quote
Old 09-04-2013, 02:16 PM   #4
ericGSsti OP
ericGSsti's Avatar
Oddometer: 570
Mortimersickle thanks for the reply. Should have said it was a euro model.
Goti. I'll have a look at that Friday when carrying out it's service. I had the tank off fitting an alarm so may have pinched something. Thanks for the reply.
Old 09-04-2013, 02:43 PM   #5
MortimerSickle
Semi-Adventurer
Oddometer: 12,470
Would you not still benefit from the routing? or do you already have that?
You don't need pressure in the left tank to overflow the right. On the side stand the left vent fitting is higher than that on the right, and so gravity is enough to do it.
The high vent hose routing rises above both vents.
G.H.W.S. 1878-1962
Old 09-04-2013, 02:49 PM   #6
ericGSsti OP
ericGSsti's Avatar
Oddometer: 570
Definatley something I'll look at so.
Thanks.
Old 09-05-2013, 02:28 AM   #7
boy60
boy60's Avatar
Oddometer: 713
http://www.ktm950.info/how/Orange%20...endectomy.html
try this it worked for me.
boy60 is offline   Reply With Quote
Old 09-05-2013, 09:34 AM   #8
MortimerSickle
Semi-Adventurer
Oddometer: 12,470
I have wondered about the Flapendectomy, but don't know how it works: does it not cause venting through, or around the cap? When on the sidestand, would it not let gas run out at the cap?
G.H.W.S. 1878-1962
Old 09-05-2013, 10:37 AM   #9
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,457
His is going from the left to the right...... "uphill" on the side stand.
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 09-05-2013, 10:47 AM   #10
MortimerSickle
Semi-Adventurer
Oddometer: 12,470
Reading is hard.
G.H.W.S. 1878-1962
Old 09-05-2013, 11:13 AM   #11
ericGSsti OP
ericGSsti's Avatar
Oddometer: 570
That is correct. Going from the left side tank to the right side tank. Couldn't find any pinched breather hoses on the left side.
Old 09-05-2013, 11:16 AM   #12
Jaimoto
Spaniard in Chile
Jaimoto's Avatar
Oddometer: 1,305
Did you check if it was clogged?
Jaime
Old 09-05-2013, 11:16 AM   #13
ericGSsti OP
ericGSsti's Avatar
Oddometer: 570
Originally Posted by boy60 View Post
Have tried this so I'll report results on the next fill. Worst case I'll have to buy two new diaframs. Best case it works.
Thanks for the link.
Old 09-05-2013, 12:48 PM   #14
ericGSsti OP
ericGSsti's Avatar
Oddometer: 570
No actually. I'll check that tomorrow when finishing the water pump and service.
Old 09-05-2013, 05:29 PM   #15
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,066
Sometimes, hoses are not "pinched"
but too tightly bent. Then when getting hot, they soften and pinch.
Cheers.
Times are GMT -7.   It's 02:26 AM.
