Old 09-08-2013, 06:40 PM   #16
Big_John
Colorado Rider
Big_John's Avatar
Oddometer: 2,983
Not sure about the 990, but my 950 '04...was done. Very poor construction from KTM....PLASTIC crap. I replaced with the flashy, orange Oberon.
It works great.
John
2004 KTM 950 Adventure S
2004 BMW R1150RT
2003 KTM 450 EXC
Pointing the Way http://www.gracemotoadv.com
Big_John is offline   Reply With Quote
Old 09-08-2013, 06:49 PM   #17
Venturer
AKA klakeman
Venturer's Avatar
Oddometer: 689
Originally Posted by renogeorge View Post
Nothing personal--just sharing my experience......
Same here. 50k miles with no issue with stock. Then I decided to replace the stock with the Oberon and ended up with a leaking seal where the pushrod exits the engine... Personally, I am thinking: if it ain't broke, don't fix it.
Work hard, play harder...
Kirk
'04 KTM 950; '11 KTM 350 XCF;
'08 KTM 250 XCF-W; '05 Montesa 250 4RT Trials
Venturer is offline   Reply With Quote
Old 09-08-2013, 06:56 PM   #18
EastSideSM
Isn't that dangerous?
Oddometer: 1,490
If you replace it make sure to replace the backer. The stock one is plastic and mine didnt work well once i swapped the slave. Put in the aluminum oberon and it works great now. I had about 40,000 on my stocker and did it as preventative upgrade. Only 4,000 miles on oberon with upgraded backer no issues. Rebuilt master at same time. Next up cj's large clutch fluid resevoir.
EastSideSM: '06 950SM Black
EastSideSM is offline   Reply With Quote
Old 09-15-2013, 08:57 PM   #19
Big_John
Colorado Rider
Big_John's Avatar
Oddometer: 2,983
Originally Posted by EastSideSM View Post
If you replace it make sure to replace the backer......
Yep, pay for the aluminum backer....the plastic backer is probably where most problems emanate.
John
2004 BMW R1150RT
2003 KTM 450 EXC
Old 03-25-2014, 03:38 AM   #20
ericGSsti
ericGSsti's Avatar
Oddometer: 540
I'm started to give trouble last week. 950 adv S with 36,000 kms approx. Lost all pressure in the clutch lever. I got a new rubber O ring seal for the piston and it worked for a week but last night I lost all pressure again in the lever resulting in the lose of smooth gear changing.
Has any a link to any of the aftermarket ones?
2003 KTM 525 EXC
2004 KTM 950 Adventure S. (GO!!!!!!!!!!!)
IBA membership no.35934
"In the spirit of adventure, open to all riders and carrying a message of friendship between all men"- Thierry Sabine 1977 founder of the Paris Dakar -
ericGSsti is offline   Reply With Quote
Old 03-25-2014, 03:41 AM   #21
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,749
Your OEM slave has failed or Oberon?
Pete
Turtleshell5@icloud.com
For those who sit at home and dream-let them...Meoni
Pete640 is offline   Reply With Quote
Old 03-25-2014, 03:46 AM   #22
ericGSsti
ericGSsti's Avatar
Oddometer: 540
https://www.adventure-spec.com/defau...enture-se.html
http://www.adventure-spec.com/defaul...t-ktm-lc8.html
Mine is the original slave. I take it this is the up grade.
2003 KTM 525 EXC
Old 03-25-2014, 04:04 AM   #23
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,749
Yes it is one alternative and a very good one at that
The rekluse is another with the benefit of being able to "tune" out any clutch grab when your stationary at traffic lights
Pete
Old 03-25-2014, 05:06 AM   #24
ericGSsti
ericGSsti's Avatar
Oddometer: 540
Ordered the parts there. Thanks guys.
2003 KTM 525 EXC
Old 09-02-2014, 04:58 PM   #25
fxbonneville
Hopeless kid
fxbonneville's Avatar
Oddometer: 12
Oberon still strong after 20,000miles
I installed my Oberon last year and had no problem with it since. I love it!
Soon riding a trail next to you!
--- www.fxrtw.com ---
2010 KTM 990 ADV R
fxbonneville is offline   Reply With Quote
Old 10-02-2014, 07:43 AM   #26
matus
Oddometer: 70
Originally Posted by Sporting Wood View Post
The problem is sintered aluminum + mineral oil + heat + pressure. Its called a solvothermic reaction. Swap to a synthetic fluid that's non reactive with the sintered aluminum cylinder and there is absolutely no issue with the stock unit. 60+k miles and no failures. Same for every one of my customers and friends who I've swapped over to 3w synthetic fork oil.. I could make 35% selling these replacement slave but it really isn't necessary, IMHO.
So if I understand correctly, instead of putting mineral oil, as stated on the cap of master cylinder, I will replace it with the synthetic oil I use for forks, and that will work?
thank you
matus is offline   Reply With Quote
Times are GMT -7.   It's 01:50 AM.
