Old 09-08-2013, 02:57 AM   #1
kito OP
Oddometer: 279
Ktm 690 gearbox
Hi I'm just doing some research on my next bike and the ktm 690 is looking like a good one. The main concern I have is the reports of a very narrow ratio gear box. Has anyone tried to do anything about this ? Can gears out of any of the other KTMs (990 ect) be made to fit ? Maybe with a bit of machining in an engineering shop ?
I have had a x challenge which I think has a wider spread than the 690 yet I was always wanting another gear on that so would I be able to live with a 690 ?
Thanks kito
kito is offline   Reply With Quote
Old 09-08-2013, 05:08 AM   #2
zxrider11
Oddometer: 218
With the stock 15/45 gearing, 60mph = 4,500rpms.
Going to 15/42 gearing, 60mph = 4,000rpms.
The bike cruises 75mph no problem, with plenty of passing power left. Top speed is around 110mph.
Riding around town, I always start off in 2nd gear.
In the single track, first gear & 2nd gear seem fine for the tight sections.
zxrider11 is offline   Reply With Quote
Old 09-08-2013, 07:23 AM   #3
Pantah
Red Sox Nation
Pantah's Avatar
Oddometer: 10,225
I must say, it takes some getting used to, but the gearbox fits the power delivery. Unlike other large bore singles, the 690 doesn't really pull until about 3500k rpm. Most of them will pull just off idle. As a result, when you drop below 50mph you probably want 4th. Below 40mph 3rd. I don't really use 1st unless I'm rolling rock gardens or something. Around the city I short shift into 2nd as soon as I start moving.
On the other end the motor seems to rev endlessly. 6th gear is good from 50 to over 100mph!
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 09-08-2013, 08:23 AM   #4
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,820
While the 690's gear box is on the narrow side, it's not nearly as bad as something like a DRZ.
Old 09-08-2013, 02:21 PM   #5
wvridgerider
wvridgerider's Avatar
Oddometer: 570
I have a 06 525XC and was wondering if the 690 has the same box, high first and narrow 2-6? I like the gearing on my bike and I dual sport it. The 690 is the bike I really want but to out of my price range and I feel I have a great bike for this area because it does all that I want except four lanes which is no fun anyway.
wvridgerider is offline   Reply With Quote
Old 09-08-2013, 07:12 PM   #6
rudk
Oddometer: 81
I own a 2010 690 Duke R and have been riding both the 690 SMC and Enduro.
With the 690 Duke the gearing CAN be felt a bit tall and many change it from 16/40 to 15/40.
The 690 SMC to me feels great as is and I'd leave it at 16/42.
The 690 Enduro for my taste is geared too short if you use it mainly on highways, country roads etx. and I would change it from 15/45 to 15/42.
rudk is offline   Reply With Quote
Old 09-09-2013, 10:17 AM   #7
kito OP
Oddometer: 279
Interesting . So it seems at though you guys are having to change sprockets a lot depending on we're your going. If only they had a wide ratio box then I could crawl along at 5mph in the tight stuff and then cruse along at 70mph at lowish revs giving a smooth ride and good mpg
Old 09-09-2013, 10:31 AM   #8
SafteyCushion
"Ask better, learn more"
Oddometer: 81
I think you've got that right, and i wish it were set up as you described.
The gearing appears to me to be more for racing than low key recreation.
Somebody tell me if I'm wrong - I'd love to know.
The bike has such potential...
SafteyCushion is offline   Reply With Quote
Old 09-09-2013, 10:36 AM   #9
kito OP
Oddometer: 279
Thanks for the replys guys but trying to get back on topic .....The main concern I have is the reports of a very narrow ratio gear box. Has anyone tried to do anything about this ? Can gears out of any of the other KTMs (990 ect) be made to fit ? Maybe with a bit of machining in an engineering ?
Old 09-09-2013, 11:14 AM   #10
rickypanecatyl
SE Asia adventure tours
Oddometer: 1,159
From my messed up memory we did try to get a group guy going on a wider set of gears about 2 years ago but it fell thru. Sorry too lazy to search... it might of been the guy on here who did the pictures for a suspension tuning book?
Anyways from what recall they needed a minimum of 20 orders and it was going to be in the neighborhood of 1,200 to $1,500 per set. That cost would have gone down with more orders.
There are so many more owners/bikes out there now... might be worth someone trying to get that ball rolling again. I bet it'd be under $1000 if there were 40 orders...
rickypanecatyl is online now   Reply With Quote
Old 09-09-2013, 01:07 PM   #11
Pantah
Red Sox Nation
Pantah's Avatar
Oddometer: 10,225
My son built a desert racer out of a 2013 450. He had a custom gearbox made for it. Maybe could do the same for a 690.
Old 09-09-2013, 01:44 PM   #12
kito OP
Oddometer: 279
Yes please
Old 09-09-2013, 02:57 PM   #13
LukasM
Oddometer: 5,426
I somehow doubt that unless he runs with a factory team or you're a seriously rich dad, the box alone would probably cost the same as an entire KTM... Are you sure that he actually had an entire gearbox custom made or is it possible that he simply swapped parts from another model, such as XC-W to XC-F or something along those lines?
Old 09-09-2013, 03:14 PM   #14
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,820
Nope, nothing like the EXC gearbox.
Old 09-11-2013, 09:09 AM   #15
kito OP
Oddometer: 279
Why are they charging so much for a gear box ? I could make do with just 2 maybe 4 gears cutting .To up the 6th and maybe the 5th
Umm maybe I should be investing in a milling machine
Times are GMT -7.   It's 10:41 PM.
