Old 09-08-2013, 04:03 AM   #1
mike.l OP
mike.l's Avatar
Oddometer: 63
950 oil leak. What is this plate?
Anyone have any ideas? I have a slight oil leak coming from a black, kind of oval shaped plate attached with two 4mm bolts to the casing above and behind where the side stand is fixed. It sits above and behind the chain guard. It can be seen on page 3-15 diagram 3 of the workshop manual. What is this, and does it have a gasket/seal that can be replaced?
mike.l is offline   Reply With Quote
Old 09-08-2013, 04:21 AM   #2
charlie264
charlie264's Avatar
Oddometer: 8,372
Sounds like gear sensor....yep rubber seal.
Old 09-08-2013, 06:12 AM   #3
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,193
Yep, gear swift sensor. It has a gasket behind it. Easy fix.
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 09-09-2013, 06:13 AM   #4
mike.l OP
mike.l's Avatar
Oddometer: 63
Ok, thanks for that.
I suppose that means I'll have to drain out all the fresh oil I've just changed! Still could be alot worse.
Old 09-09-2013, 06:19 AM   #5
COXR650L
Oddometer: 1,543
Nope, you can just pull the plate and replace. Very little to no oil will come out if you do it on the center stand.
COXR650L is offline   Reply With Quote
Old 09-09-2013, 08:28 AM   #6
igrek
Oddometer: 22
You can also lay it down on right side and change the seal
igrek is offline   Reply With Quote
Times are GMT -7.   It's 11:56 PM.
