Old 09-08-2013, 10:29 AM   #1
SauceSquatch OP
SauceSquatch's Avatar
Oddometer: 273
removing throttle body
Hey y'all. I'm doing a valve check service on my 2010 990 and following paochow's documentation here:
http://paochow.com/forum/index.php?topic=45.0
Step 25 says to loosen the bottom two 6mm bolts on the manifold, which i have done but that sucker is not coming loose. Before I gorilla-arm this thing I wanted to double check that I have in-fact loosened the correct bolts, is this them or is this just dual belt clamps for the intakes?
thanks in advance
2010 KTM 990 Adventure
2006 DRZ
1978 Harley FX cut down
SauceSquatch is offline   Reply With Quote
Old 09-08-2013, 11:09 AM   #2
Hootowl
Oddometer: 1,262
After you loosen the screws (those are the right ones circled) push on the clamp so that you know its free of the rubber then gently rock it back & forth while pulling upwards.
Keep it Wild, Keep it Free
'07 990A
'12 Super Tenere
Hootowl is offline   Reply With Quote
Old 09-08-2013, 11:26 AM   #3
DuctTape
Oddometer: 351
I had to loosen all 4 to get mine off.
2013 KTM 690 (Thanks FLHRCI Buyer! )
2011 990 Adventure Dakar (Thank you Honey!)
2010 Aprilia RSV4 Factory
2010 Ducati 1198S
DuctTape is offline   Reply With Quote
Old 09-08-2013, 12:43 PM   #4
SauceSquatch OP
Oddometer: 273
ok, got em off. Thanks guys!
2006 DRZ
Old 09-08-2013, 09:19 PM   #5
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,572
For reassembly you will want to completely clean the manifolds with carb cleaner, wiping them clean. Also make sure that the head spigots are clean as well. I recommend not using any form of lubrication on the manifolds. Then put the manifolds back onto the engine, tighten the clamps to the limiter, then open the upper clamps to 99% stroke. This will make inserting the throttle bodies into the manifolds easier. Drop the front one in first, then with a forward and down pressure guide the rear throttle body into the rear manifold. Pushing down on both front and rear should seat them.... then tighten clamps to limiters.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Times are GMT -7.   It's 07:54 PM.
