Old 09-08-2013, 08:54 PM   #1
pb12 OP
Oddometer: 4
New (to me) 640 Adventure, and my head is swimming, need advice!
First, I know, I know, "Search!". Please believe me, I have. A Lot, and quite frankly, the volume of information is overwhelming.
My new bike is a 2006 640 Adventure. Just 5,300 miles, and in terrific shape. Id like to keep it that way!
I need help with two quick issues:
Lighting and Crash bars
On the Lighting front, it seems that everyone goes for some sort of HID option. For the sake of simplicity, id really like to avoid that. Is it possible to simply put a brighter bulb in, say and 80w? What other simple and inexpensive options are there?
Crashbars seem to be fairly scarce. Seems Holan was (is?) making them, but has stopped? Is the only or best option the carbon fiber tank guards? Im quite sure they are effective, but one drop, and they look pretty bad. I like the idea of crashbars, so am wondering if there are any good options? If not, who makes the best tank guards, and is there a way to mount them so they can be pulled off and replaced once they've ben destroyed?
Thanks much!
pb12 is offline   Reply With Quote
Old 09-09-2013, 06:20 AM   #2
wvrocks
wvrocks's Avatar
Oddometer: 622
Welcome to the world of 640A's!
I wired both of my headlights straight to the battery with heavier gauge wire and fuses/relays. They are also set up so that they both burn when the highbeam is on. Makes things a little brighter for not much money. The downside is that it eats up power quickly, don't leave the lights on with the bike not running unless you like kick starting. I'd recommend adding some sort of Voltmeter to the bike so you can see what your charging system is doing. The stator doesn't put out much in the way of extra power. The real problem I have with the lights is the hard light cutoff on the lowbeam. It leaves the inside of left turns very dark.
Speaking of the stator and charging, you can get better charging to the battery by wiring the regulator outputs directly to the battery. In stock form they are routed into the wiring harness and eventually make it back to the battery. Its as simple as cliping the outputs, crimping on ring terminals and attaching to the battery posts. http://www.advrider.com/forums/showthread.php?t=905835
Check out Jason's build thread for info on lighting options. I'm going to go this route soon.
http://advrider.com/forums/showthrea...=888604&page=4
Crashbars seem really tough to come by. There is an ADVrider in Australia building nice carbon/kevlar tank and engine case guards for a pretty reasonable price though. No personal experience with them but I think Jason from the thread above has a set.
http://advrider.com/forums/showthread.php?t=868271
Never underestimate the power of stupid people in large groups.
wvrocks screwed with this post 09-09-2013 at 06:39 AM
wvrocks is offline   Reply With Quote
Old 09-09-2013, 12:57 PM   #3
pb12 OP
Oddometer: 4
Thanks wvrocks, that is all very helpfull info! I will look further into the tank guards, and maybe some improved wiring. The electrical work is a bit daunting, but I'll give it s shot!
Thanks again!
M
Old 09-09-2013, 01:07 PM   #4
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,991
http://www.advrider.com/forums/showthread.php?t=197163
Take your time, you can doo-eet!
I'd strongly encourage the Centech be installed for wiring simplicity before going banannas with wiring upgrades.
Dirty
No, really, the mustache means I love you.
dirty_sanchez is offline   Reply With Quote
Old 09-09-2013, 01:53 PM   #5
bisbonian
bisbonian's Avatar
Oddometer: 1,043
Like has been said, the real problem with lighting is the amount of electrical power you have to work with.
Even with upgrading all the wiring, installing a fuse panel and wiring the voltage regulator directly to the battery I was still having voltage issues.
I run a voltmeter on the dash and found that at cruise I was running about 12.8 -13.1 volts with one headlight on. I went with the HID option after reading a bunch of posts on here (thanks Dirty Sanchez!) and the improvement has been amazing. I'm now running about 14.1 volts cruising down the road with the single headlight and getting much more light out of it.
I have the Chris Barnes CF tank guards. I used some sort of adhesive to mount them and think they work fine. They have a bit of petcock protection built in as well. I have tested them out and can attest that they protect the tank. Sure they are now a bit scarred but then I didn't buy my 640A to be a trailer queen so I consider this to be character.
My 2009 Alaska Adventure
bisbonian is online now   Reply With Quote
Old 09-09-2013, 02:42 PM   #6
Beta450
Oddometer: 99
Alburmoto.com has crash bars for the 640.
Beta450 is offline   Reply With Quote
Old 09-09-2013, 06:02 PM   #7
DaddyBigDaddy
AKA -Evel Kneilson
DaddyBigDaddy's Avatar
Location: Liberal ShitHole, San Fran-sissyco, Kalee-Fornee-a
Oddometer: 306
Crashbars
Go to www.ADVmotorad.net or .com they have the Holans for around $250-300
DaddyBigDaddy
1998 KTM 620 Adventure
2007 KTM 950 SE
2008 KTM 530 EXC
2004 KTM 450
DaddyBigDaddy is offline   Reply With Quote
Old 09-09-2013, 10:03 PM   #8
bmwktmbill
Traveler
Oddometer: 5,218
Go with HID lights and separate hi/lo fused relays,
Skip the crash bars in favor of a Scott's steering stabilizer, a center stand and a kick stand.
And then add the Renazco saddle in suede.
These grips will help.
http://www.happy-trail.com/ProGrip-D...Gel-Grips.aspx
Buy a throttle lock.
Best cure for the vibes.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 09-10-2013, 05:27 AM   #9
wvrocks
wvrocks's Avatar
Oddometer: 622
Originally Posted by bmwktmbill View Post
Agree, 714's are really nice grips.
Old 09-11-2013, 07:08 PM   #10
pb12 OP
Oddometer: 4
Thanks for the suggestions guys. Looks like Chris is working on a new version of the tank guards, so I'll look forward to the update.
Any other thoughts, send them my way!
Michael
Old 09-11-2013, 07:29 PM   #11
Beta450
Oddometer: 99
What brand of throttle lock for the 640 A?
Old 09-11-2013, 09:11 PM   #12
bmwktmbill
Traveler
Oddometer: 5,218
This one works and helps tame the vibes.
http://throttlemeister.com/
bill
Bill Shockley
Times are GMT -7.   It's 03:16 PM.
