Old 09-09-2013, 04:56 PM   #1
double_entendre OP
Ticking away the....
double_entendre's Avatar
Oddometer: 4,109
Clutch perfume
Still learning to understand the GSA, but definitely having fun on it. Need to put the wife on the back and see if she enjoys it as well. That'll determine if I sell the FJR or not. Or sell the FJR and XRR and buy a Gold Wing.
I am finding that I spend a lot of time smelling the clutch on the GSA when I pull up to a stop. I do tend to feather it leaving a light and when I'm in stop & go traffic rather than just pop it into gear. I don't keep my hand on the clutch once I'm moving and it's only barely pulled in when I shift. There's definitely slack in the movement, so it's not being applied constantly.
This normal?
Also, anyone know the height difference between stock and with the lowering Hyperpro springs? I can flat foot the GSA, but don't feel compelled to do so and am contemplating putting the OEM shocks back on.
Helmets save lives. Loud pipes annoy voters.
double_entendre is offline   Reply With Quote
Old 09-10-2013, 02:51 AM   #2
Chat Lunatique
ACK
Chat Lunatique's Avatar
Oddometer: 1,070
Are you sure it's not the brakes you smell? My 2010GS brakes stunk like hell for a few months when applied, when it was new. The harder I braked, the worse it was. Some chemical crap on the pads had to burn off I guess. It was worst when they were wet.
I do not intend to tiptoe through life, only to arrive safely at death
Chat Lunatique is offline   Reply With Quote
Old 09-10-2013, 05:22 AM   #3
teomannaskali
teomannaskali's Avatar
Oddometer: 792
I get no smell from clutch except when I am 2 up, in traffic and going up a hill..
Make sure that your left handguard is not touching the clutch.
I regularly check it while riding. Push clutch lever forward to make sure there is atleast 1 cm of movement untill contact with handguard.
teomannaskali is online now   Reply With Quote
Old 09-10-2013, 05:25 AM   #4
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,032
You should only smell the clutch when is an extreme need to slip it constantly. You should release the clutch within 2 seconds of beginning to move and have the rpms under 2000 when starting out. Once you fully release the clutch accelerate as you like. I generally have the clutch fully released in under 1 second and it is very smooth, not jerky at all.
Jim
Old 09-10-2013, 06:58 AM   #5
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,558
What Jim said..
You're spending too long on the clutch..this isn't a high strung 4 cylinder with no torque at the bottom..it's a tractor motor..use it as such..remember too, it's a dry clutch, not an oil bath like your FJR..
"Ignorance is a powerful tool when applied at just the right time..sometimes even surpassing knowledge.." EJ Potter
Bill-66 is offline   Reply With Quote
Old 09-10-2013, 10:40 AM   #6
double_entendre OP
Oddometer: 4,109
Definitely not touching the hand guard and have the movement.
Could be right about the slipping it, but I also tend to rev off the line and let it slip while jumping forward.
I don't think it's brakes. Doesn't smell like brakes and with over 7,000 miles, it shouldn't be.
Hmmmmm....
Thanks for the thoughts. I got the smell when I was stuck in traffic in Portland a while ago too. Stop and go rubbish and no lane sharing allowed. Heathen bastards.
Old 09-10-2013, 11:10 AM   #7
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,558
Hmmmmm....
At least we drive 35 in the fast lane..
wait..what..?
Portland traffic sux...
Old 09-10-2013, 11:18 AM   #8
teomannaskali
Oddometer: 792
wait..what..?
Try Istanbul traffic...
Old 09-10-2013, 11:26 AM   #9
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,558
Seen pix...pass..
Old 09-10-2013, 12:02 PM   #10
double_entendre OP
Oddometer: 4,109
wait..what..?
It definitely didn't help that they had two or three lanes closed on the freeway bound for Seattle. That dogged things up pretty badly.
Old 09-10-2013, 07:06 PM   #11
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,613
Or, try traffic here in Dixie...one broken down pickup truck after another...its murder trying to get from Locust Fork to Trafford, Alabama at about 2:00 AM in the morning what with all the smoke from the stils in the woods here...glad I have GPS. We also use carbide lamps to get around here in the woods....they scare the deer though.
def is offline   Reply With Quote
Old 09-11-2013, 02:36 AM   #12
2Vulcans
Let's go...
2Vulcans's Avatar
Oddometer: 171
Question related question
Sorry but trying to avoid to start another thread:
Given all the things that you mentioned about the r1200gs having a dry clutch and all that, how do you deal when you have bad off-road with bad slopes and stones to avoid and you need to go slow and you need the help of the clutch?
I am almost new to off-roading and last week my clutch was smelling bad up to a couple of hours after the bad off-road, every time I engaged-disengaged the clutch!
Any suggestions?
Thank you!
2Vulcans is offline   Reply With Quote
Old 09-11-2013, 03:52 AM   #13
belfa
Oddometer: 24
Clutch disc splines wearing BMW 1150GSA
Is it normal that 5000km after renewing clutch disc is on the half of clutch splines visible some wearing? The input shaft of gearbox is like new without any wearing. http://photo.uloziste.com/?fotka=96f...faade68&size=6
belfa is offline   Reply With Quote
Old 09-11-2013, 07:16 AM   #14
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,558
Any suggestions?
Thank you!
You can slip it some..just keep the RPM low as possible...and remember, it's not really a trials bike..it will do goat trails but it is built for gravel/dirt roads..
If you abuse the clutch..you'll just have to replace sooner..that's all
Bill-66 screwed with this post 09-11-2013 at 08:18 AM
Old 09-11-2013, 07:58 AM   #15
JM
JM's Avatar
Oddometer: 783
Any suggestions?
Thank you!
The key is to find the lowest rpm you need to get out of the gunk you're in. High rpm and slipping the clutch puts you in the fast lane to a new clutch. These things pull pretty hard at a low rpm so don't over rev the thing.
John
Postponing retirement one farkle at a time!
JM is offline   Reply With Quote
Times are GMT -7.   It's 12:47 PM.
