Old 09-10-2013, 08:16 AM   #1
tanker253 OP
tanker253's Avatar
Oddometer: 12
Pin hole in fuel line
My three month old KTM 990 adventure sprung a pin hole leak in the main fuel line leading from the tank to the engine. Sprays a fine mist of fuel all over the running engine and my pant leg and boot. I was probably a minute away from a really bad fire. Luckily I stopped at a red light and nearly fell over because my foot was soaking wet and slippery with fuel. Worst part is now I'm stranded in Winnipeg with no dealer for hundreds of miles.. Anybody ever hear about defective fuel lines?
2012 KTM ADVENTURE 990
2006 KLR 650
tanker253 is offline   Reply With Quote
Old 09-10-2013, 09:24 AM   #2
renogeorge
Oddometer: 1,482
Standard fuel line from an auto parts store works fine. The line for fuel injection would be best if they have it.
Are you sure it's not the quick connect?
KTMs--300, 518, 990
renogeorge is online now   Reply With Quote
Old 09-10-2013, 12:01 PM   #3
tanker253 OP
tanker253's Avatar
Oddometer: 12
Definitely a pin hole. I can put my finger on it when I turn on the ignition and feel the pressurized fuel squirting out when the fuel pump turns on. I think I have an idea for a "patch" so I can ride it to get fixed.
2006 KLR 650
Old 09-10-2013, 01:37 PM   #4
renogeorge
Oddometer: 1,482
You probably thought of this. But a barbed 5/16 or 1/4" connector would get you home. Cut the hose at the hole, insert barbed ends into hose ends and ride on....
Good luck
KTMs--300, 518, 990
Old 09-10-2013, 10:32 PM   #5
Katoom72
Katoom72's Avatar
Oddometer: 915
This is why i have cable tie around my fuel lines
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is offline   Reply With Quote
Old 09-11-2013, 10:08 AM   #6
tanker253 OP
tanker253's Avatar
Oddometer: 12
That's exactly what I did. It will keep my going till it gets fixed properly.
2006 KLR 650
Old 09-11-2013, 11:37 AM   #7
rtadlock
rtadlock's Avatar
Oddometer: 1,292
Just FYI, my 2013 500 XCW sprung a pin hole twice in a week when I first go it. Here's a picture:
Somehow I got a small hole in my high pressure fuel line
Turns out there was a bad run of fuel lines and KTM recalled the part. I had already fixed it with a high pressure line, but like you, I was covered in fuel twice before I fixed it and got recall letter from KTM.
rtadlock is offline   Reply With Quote
Old 10-04-2013, 09:16 AM   #8
tacosupreme
tacosupreme's Avatar
Oddometer: 302
Mine just did this this morning. Almost aced it, tried to pass a car and got a little sideways. Good times. What size is the fuel line? Is it metric?
'12 990 with some orange stuff on it to make it go faster.
tacosupreme is offline   Reply With Quote
Old 10-04-2013, 10:27 AM   #9
Salzig
Salzig's Avatar
Oddometer: 255
Yep. 8mm internal diameter.
It's a good thing to protect the fuel line from rubbing to the frame, just above the connector.
A picture is better than my english
It's where the grey duct tape is.
Actual rides:
'10 Husqvarna TE310 - '07 KTM 990 Adventure ABS (S'd) - '04 Husqvarna SM450R - '99 YAMAHA R6
"A donkey! A donkey! My kingdom for a donkey!"
Salzig is offline   Reply With Quote
Old 10-04-2013, 10:31 AM   #10
Sporting Wood
I <3 Energizer Bunny
Sporting Wood's Avatar
Oddometer: 896
Most auto parts stores have 5/16 fuel injection line by the foot. Just be sure not to let them give you carburator line! I just replaced some on a BMW in the shop that was doing the same thing. BMW wanted over $100 for the two lines...cost me $5.
Sporting Wood is offline   Reply With Quote
Old 10-04-2013, 05:49 PM   #11
tacosupreme
Oddometer: 302
My local NAPA only had 1/4" line, and being stranded I tried it. It fit, but it was tight. Interestingly, I got an FI fault and the bike won't start. You can hear the fuel pump run when you turn the key on, and it briefly started at first but it sounded like it ran out of fuel and died. Quick disconnect is attached properly along with all wires and vent lines etc. Do you need to purge the EFI or something? Second time in 3000 miles I've been stranded. Almost as reliable as a harley.
Old 10-04-2013, 06:04 PM   #12
renogeorge
Oddometer: 1,482
I have had the quick disconnect cut off fuel even when properly connected. Might want to disconnect it and push something into the connector to open it.
Good luck
KTMs--300, 518, 990
Old 10-04-2013, 07:54 PM   #13
Sporting Wood
Oddometer: 896
Those quick connects can be a pain. I bet George is right?
Old 10-04-2013, 10:49 PM   #14
Salzig
Salzig's Avatar
Oddometer: 255
Actually the sound you hear could likely come from the secondary butterflies (much more noisy then the pump).
Keep a finger on the pump while you're turning the key on to be sure it's priming the circuit.
Sometimes the electrical connector pins slip out.
Actual rides:
Old 10-05-2013, 01:06 PM   #15
tacosupreme
Oddometer: 302
Turns out it was a kink in the fuel line. The factory line has a 90* elbow where it goes into the air box. I replaced it with straight line and it was a little too long, and it kinked when I put the tank back on. Lesson learned, don't hurry maintenance just because you are "stuck" somewhere.
That said, the factory fuel line is very soft. I have had to run a few tanks of crap gas through it, I wonder if the ethanol ate it?
Times are GMT -7.   It's 06:37 AM.
