Old 09-10-2013, 02:30 PM   #1
Phoneshield OP
Oddometer: 20
Phoneshield for iPhone 5 – Weatherproof Case and Handlebar Mount
The Phoneshield™ PS-IPH5 for iPhone 5 is the most versatile case and mount combination in the world. It fits an active lifestyle whether the user is motorcycling, bicycling, or participating in any activity where they would want to mount and display their iPhone 5. The PS-IP5 is even applicable to certain water sports where full submersion is not required, such as stand-up paddle boarding and kayaking. With the PS-IP5, users have the option to utilize the included mounts or add the case to an existing Ram Mount® or Techmount® for specific applications. - See more at: http://phoneshieldmounts.com/phonesh...case-and-mount
Features:
SECURE LOCK: The case securely screws into the mount, insuring that your Phoneshield case will only detach from the mount when you want it to.
SHOCK PROOF: Protection isn’t just about protecting the outside of your iPhone. Shock and vibration protection provided by the rubber inner liner makes sure the guts of your iPhone are protected as well.
WEATHERPROOF: Protect your iPhone 5 from all the elements. The case will even protect your phone from short water submersion. Mounted - rain, sleet, or snow won’t stop you.
SCREEN PROTECTION: Protect your iPhone 5 from scratches and normal wear and tear. Whether you accidentally drop it or time takes its toll on your screen, while encased in the Phoneshield, your screen will be protected. The matte screen protector also helps reduce glare.
TOUCH SENSITIVE: While protected, you can still use your touchscreen. Keep in mind your screen will work the same way in the Phoneshield as it will when it isn’t, so if your gloves work without the Phoneshield, they will work with the Phoneshield.
CAMERA READY: Your iPhone 5 built-in camera can be used for photos or videos without having to take your iPhone out of your Phoneshield case.
SWIVEL 360°: You have the ability to change the orientation of your iPhone 5’s screen to meet your different application needs. Rotate your iPhone into landscape orientation and use it for GPS.
AUDIBLE SPEAKERS/MIC: There is no need to take your iPhone out of the cases to use the speakerphone. Unlike other hard cases, the Phoneshield allows your speaker and microphone to pass through, making the speakerphone usable. A sealed membrane allows audio to pass while keeping the phone protected from water.
CABLE PASS THROUGH: The cable pass through allows you to plug in your lightning cable for charging or your headphones for music and phone calls.
UNIVERSAL HANDLEBAR MOUNT: Mount the Phoneshield case to round handlebars of varying size. The head of the mount is on a ball that allows you to rotate your screen. Combined with the quick release you get two points of adjustment.
Apple iPhone 5 and Samsung Galaxy s3/s4 Cases and Mounting Solutions for Motorcycles. www.phoneshieldmounts.com
"The Phoneshield will keep your iPhone or Galaxy protected and conveniently accessible." Motorcycle.com review of Phoneshield for iPhone 5
Phoneshield is offline   Reply With Quote
Old 09-10-2013, 02:31 PM   #2
Phoneshield OP
Oddometer: 20
this case will work with the iphone 5s, we are 95% sure it will work with he iphone 5c and will post an update here.
Old 09-17-2013, 10:15 AM   #3
12Bong13
12Bong13's Avatar
Oddometer: 199
Any chance it is available for the 4S?
12Bong13 is offline   Reply With Quote
Old 11-07-2013, 04:31 PM   #4
Phoneshield OP
Oddometer: 20
sorry for the late reply. only available for iphone 5/5s/5c, galaxy s3, or galaxy s4.
Old 11-16-2014, 02:01 AM   #5
Pilotuh1b
Oddometer: 74
In Australia
G'day guys,
I'm in Oz and just wondering the best place to buy an iPhone 5 phoneshield over here.
Otherwise, I'll just eBay it from Lytle Racing Group.
Cheers,
Pilotuh1b
Pilotuh1b is offline   Reply With Quote
Old 11-16-2014, 08:13 AM   #6
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,897
iPhone 6 Plus?
Given the amount of room you have at the bottom of the case, it would have been a nice touch to have had a waterproof Lightning connector instead of a "passthrough".
Just a bit concerned about the "matte" finish on the screen cover. My experience is that matte finishes on screen protectors significantly cut down on light transmission/visibility.
Your thoughts?
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Times are GMT -7.   It's 02:44 AM.
