Old 09-11-2013, 01:48 AM   #1
scareysage OP
Oddometer: 3
Wink Can You De-Restrict the F700GS?
I have just bought the F700GS, as it was smaller & suits my size better than the F800GS. However the BMW sales guy said that the 700 has the 800cc engine, but it is restricted to 700cc. He said BMW won't de-restrict it, but he thinks it can be done. Has anyone done it & if so how?
scareysage is offline   Reply With Quote
Old 09-11-2013, 02:13 AM   #2
Kiwi Tinkerer
Ross
Kiwi Tinkerer's Avatar
Oddometer: 389
good luck
That's an odd thing for the dealer to say. It is not restricted to 700cc.
Both bikes are 800cc.
The "700" is restricted to 75hp. (compared to 85hp for "800")
You would need cams, throttle bodies, maybe the head, and ecu's.
There is probably a way, but not easy or cheap. Buy the 800 and put smaller wheels on it.
Kiwi Tinkerer is offline   Reply With Quote
Old 09-11-2013, 04:53 AM   #3
ph0rk
Doesn't Care
ph0rk's Avatar
Oddometer: 2,113
If you want to get technical, all the f-twins are "restricted" compared to the f800gt - 90 hp.
--Semantics are everything.
ph0rk is offline   Reply With Quote
Old 09-11-2013, 10:32 AM   #4
JGoody
Oddometer: 291
Just to clarify the obvious -- the newer F650GS, F700GS, and F800GS all have the same engine displacement. Power output and torque curves are different due to cams etc. Radiator is smaller in F650GS due to lower peak hp. Fuel requirements also vary. The older F650GS is a single now renamed G650GS. Could anyone make a more screwed up naming system?
JGoody is offline   Reply With Quote
Old 09-11-2013, 11:48 AM   #5
Pete7874
Pete7874's Avatar
Oddometer: 412
BMW is good at the model nomenclature confusion. They've been doing it on their cars for years... in the past, the last two digits signified engine displacement, so a 328i was a 3-series with a 2.8 liter engine. Now the 328i has a 2.0 liter turbo engine, and a 335i has a 3.0 liter turbo. Go figure.
2013 F700GS
Pete7874 is offline   Reply With Quote
Old 09-11-2013, 03:08 PM   #6
Full Power
Oddometer: 1,483
Why don't you ride it around some first.
Wear out the original tires, and THEN figure out what limitations the bike has.
You may find 75 Horsepower adequate to your purpose.
If not, $3000 spent on a used GSXR or Ninja could give you a CHEAP fix of what yer missing.
Warm enough to RAIN is warm enough to RIDE.
Full Power is offline   Reply With Quote
Old 09-12-2013, 01:41 AM   #7
scareysage OP
Oddometer: 3
I know I have an 800cc engine in the F700 & I was told it had been restricted to entice another group of riders to the market. I can't believe BMW would go to the expense of different cams etc when they could restrict it via the ECU.
Old 09-12-2013, 05:22 AM   #8
Pete7874
Pete7874's Avatar
Oddometer: 412
If it was just an ECU reflash, it would have been very easy/inexpensive to get it performed aftermarket. BMW obviously doesn't want this to be easy/inexpensive for a potential buyer.
2013 F700GS
Old 09-12-2013, 05:33 AM   #9
ebrabaek
Oddometer: 4,763
One guy here have tried it, and it ran like crap, as he put cams from the 8 into the 7..... I think it was.... But you would need cams, ecu, and some say Throttle boddy's. After he posted a video here, where it rand bad, he dropped off. Have not heard from him since. Not a cheap prospect, as the cams, and ecu are pricy.
Erling
Old 09-12-2013, 06:31 AM   #10
MikeMike
MikeMike's Avatar
Oddometer: 4,150
The BMW sales guy is an ignorant ass hat, like many of Motorrads finest.
Go back and have him detail how to do it.
Why dont you simply take a good hard look at the dyno numbers for the two bikes and pay attention to the rev range you will be riding in? Then, compare the two bikes looking for at least a 7-10% difference.
One day spent at a decent riding school will likely show you why you dont need the relatively minor difference in hp.
Your BMW sales guy reminds me of Don Cheadle's character in Boogie Nights.
The guys in the backroom can make the super turbo X99 modifications for an extra cost...
Old 09-12-2013, 07:43 AM   #11
JGoody
Oddometer: 291
Good Advice. Motorcycle Consumer News has dyno charts of rear wheel HP for the F650GS, 700 and 800 in their reviews -- available online for free. If you read the reviews and look at the charts you will see exactly what Mike is talking about. The peak hp goes up with each model but up to a certain rpm the power is the same. The the sprockets are slightly different between the models, which has an effect on acceleration (and highway cruising rpm) but if you want to that can be changed very cheaply. None of them are sportsbikes but they're not slow pokes either.
Old 09-12-2013, 11:17 AM   #12
Wildman
In my castle
Wildman's Avatar
Oddometer: 18,106
... Could anyone make a more screwed up naming system?
Yamaha. I'm pretty sure the R1 has a bigger displacement than 1cc.
Ridden; GBR CYM DEU FRA ESP AND MCO ITA BEL SCT LUX CHE SMR LIE AUT NLD POL LTU LVA EST SWE FIN NOR DNK CZE SVK HUN ROU BGR GRC MKD SRB ALB MNE BIH HRV SVN MYS IRL BRA MAR PRT ARE USA ISL JPN MLT Planning; AUS TUR MDA UKR MEX BLR MNG RUS KAZ TJK KGZ SEN ZAF ZMB MWI NZL IND CPN
Wildman is offline   Reply With Quote
Old 09-12-2013, 11:22 AM   #13
Capt CF
Capt CF's Avatar
Oddometer: 297
+1 - here's someone getting as much as you can out of the 800. If you are at this level maybe it's time to talk about performance upgrades. :)
http://www.youtube.com/watch?v=jidVde-dIYc
You can't teach pigs to sing - it only frustrates you and annoys the pig.
Capt CF is online now   Reply With Quote
Old 09-12-2013, 01:53 PM   #14
Kiwi Tinkerer
Ross
Oddometer: 389
More power
You could go the whole hog and put the husky 900 nuda engine in. Bolt strait in! 100hp.
Though you would need the NUDA ECU to run it.
And the motor has a lot more differences. 900cc, slightly offset crank pins so the firing is not quite even. So different crank, cams etc.
Would be interesting.
Looks like the husky is the f800gs frame with f800r swingarm. I you had the money, buy a 900 nuda and convert to a GS.
Not that you need, or can ever use 100hpo in the dirt.
Old 09-12-2013, 03:35 PM   #15
scareysage OP
Oddometer: 3
Laugh
Thanks for all the info & yes it does sound as though the dealer is an ass. I have to travel 9km on dirt & cross 3 creek crossings from my house before I get to the tarmac (live in far north Queensland) & that is why I have bought the F700 & not a plastic bullet. I have been razzing around on a KTM LC4 Motard for the past 7 years, but wanted something a wee bit more comfortable with a screen & panniers & this ticks all the boxes. I did try the Nuda & boy was it fun, but certainly not a bike I could tour around Australia on.
Times are GMT -7.   It's 11:57 AM.
