Old 09-13-2013, 09:43 PM   #16
Doctor
Doctor's Avatar
Oddometer: 8,445
Originally Posted by Fogo72 View Post
The KLX has not got a single backbone frame so it wont fit.
Hey guys, I need to send a base gasket to somewhere that can scan it and cut some new ones out in a water jet, out of different thickness stainless sheet. like 1mm , 1.5mm and 2mm. Anyone know somewhere that has a water jet that could do that?
once upon a time i knew a fellow that did just what you want to do
he cut a one piece alloy base gasket, it worked a treat and he did it by hand tools.
it was a Kwaka 500 triple
so alloy works well
Doctor is offline   Reply With Quote
Old 09-13-2013, 11:34 PM   #17
Eric66
Oddometer: 327
Who is doing ya crank Fogo? Ronnie?
Regards Eric
Eric66 is offline   Reply With Quote
Old 09-13-2013, 11:56 PM   #18
Fogo72 OP
I Bleed Green
Fogo72's Avatar
Oddometer: 1,561
Regards Eric
Well I have been looking for quite a while for someone to take it on, far and wide, when someone recomended a guy that lives on a farm about 20 klms away from me. I drive out there and was warned, what ever you do, dont swear, they are churchies.
Righto, I drive up the driveway to an old farm shed and an old guy shuffles out to meet me. I tell him of my intensions and hand him the crank, he laughs and said, "just go and buy yourself a CRF450" I said Nah I'm too loyal to these old pigs,
"yeah I can do it no problems but how much money ya got young fella" he said. Well I'm on a bit of a budget for this I told him.
"Leave it with me, $500 bucks"
I follow him into this dingey shed to see wall to wall Mills and lathes, some old ,some the latest technogy. One lathe you could have swung a tug boat prop in, the chuck was so big.
So as I got into the shed he stops in his tracks and swings head around on his shoulders to eyeball me in a weird and hazey glance and I see this little spakle in the corner of his eye as he said, " years ago I used to be right into this crazy sort of stuff with engines" as he chuckles.
He puts the crank on a work bench as he slides a pile of shit to the side and looks at me and says, Thats a guy who is into chain saw racing and I have to make a cylinder head for him from scratch. Ha.
I have a new found friend.
Cheers Fogo..
Fogo72 is offline   Reply With Quote
Old 09-14-2013, 12:03 AM   #19
Doctor
Doctor's Avatar
Oddometer: 8,445
i have friends up that way that use such modified things , Ask him does he know a Neil or a Bill
Old 09-14-2013, 12:09 AM   #20
Doctor
Doctor's Avatar
Oddometer: 8,445
raised the barrels just on 2mm to optimise the port timing
Old 09-14-2013, 12:12 AM   #21
wiggywildwildwest
cranky bugger
wiggywildwildwest's Avatar
Oddometer: 747
can you mock it up in the cases before you get too far ? often clearance around the rod is tight standard. might need case mods to make it work. also, with altering the height of the barrel you will need to consider how to get the valve timing right and the chain tensioned.
looks like a fantastic project.
Where you come from is gone. Where you thought you were going, Was never there. Where you are, Ain't no good unless you can get away from it.
wiggywildwildwest is offline   Reply With Quote
Old 09-14-2013, 12:24 AM   #22
Fogo72 OP
I Bleed Green
Fogo72's Avatar
Oddometer: 1,561
Sure, the timing will be sorted with the same mod I did to Kermits new engine, elongate the cam gear bolt holes, the barrel will go up 2mm and the piston shaved 1mm, heaps of adjustment on the cam chain adjuster.
Old 09-14-2013, 12:28 AM   #23
Andrew2
Team 250
Andrew2's Avatar
Oddometer: 5,290
KLX BIG
Andrew2 is offline   Reply With Quote
Old 09-14-2013, 12:29 AM   #24
lentil
All round nice guy
lentil's Avatar
Oddometer: 8,331
Hey Fogo love your work...
You gunna be around next Saturday or Sunday, I'll be down your way was gunna call in say G'day
F5 is for wussies Command R is where the actions at!
Apple fanboy
Originally Posted by troy safari carpente View Post
It's the classic freudian slip... "come out of the closet, and jump into the jaccuzzi with the rest of us..."
lentil is online now   Reply With Quote
Old 09-14-2013, 12:46 AM   #25
Fogo72 OP
I Bleed Green
Fogo72's Avatar
Oddometer: 1,561
Yeah , still got this helmet here to ay.
Old 09-14-2013, 01:20 AM   #26
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,618
aarrhh fogo, that's awesome.
iam just not ready to be an adult
[QUOTE=troy safari carpente;24254589]
... the XR is the greatest off road motorcycle ever constructed. There's nothing it can't do, hasn't won or will not outperform.
digga1111 is offline   Reply With Quote
Old 09-14-2013, 01:23 AM   #27
KASUYAHO
Road Hog
Oddometer: 3,726
I think we would have to be really carefull trying to take weight off the crank and balance weight, get it wrong and it vibrate to bits. Engine blue printers would be the people to see, maybe the guys who do all the Go cart race engines. But no endless budget here.
We are going for the raised barrel idea instead of getting a shorter conrod made from Corrillo. I might get a base gasket cut out of stainless by a water jet and raise the barrel 2 mm and mill 1mm off the top of the piston to get a round the stroke difference, that way the crank angle wont change too much I have been told, and it decreases the side load on the trust sides of the liner.
Move the piston pin up the piston ? instead of milling the crown of the piston.
What's the length of the stock rod ?
What is the diameter of the piston pin ?
What is the stock stroke ?
KASUYAHO is offline   Reply With Quote
Old 09-14-2013, 01:56 AM   #28
Fogo72 OP
I Bleed Green
Fogo72's Avatar
Oddometer: 1,561
STD bore is 100mm
STD stroke is 83mm
New stroke is or will be 89mm
1mm off pistom crown , no biggy, kind of domes in so it will just be a little around the out side.
Piston pin, not sure, have book. will find out.
Same with rod length, can find out,
why , whats your thoughts.
Old 09-14-2013, 02:22 AM   #29
2upAussie990
Oddometer: 464
2upAussie990 is offline   Reply With Quote
Old 09-14-2013, 03:48 AM   #30
Fogo72 OP
I Bleed Green
Fogo72's Avatar
Oddometer: 1,561
Not willing to show you the fairing that we have picked yet or where we are getting from until the deal is done, I don't think the manufacturer would like to see it on KLX, but If I can pull it off it will look sweet. Nothing like a KTM fairing with a huge Kawasaki sticker up the side of it.
A few pics of cam timing adjustment.
Fogo72 screwed with this post 09-14-2013 at 03:57 AM
Times are GMT -7.   It's 01:13 AM.
