Old 09-15-2013, 04:38 PM   #46
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,559
what and where do you expect to see the difference with the stroker kit?
iam just not ready to be an adult
[QUOTE=troy safari carpente;24254589]
... the XR is the greatest off road motorcycle ever constructed. There's nothing it can't do, hasn't won or will not outperform.
digga1111 is online now   Reply With Quote
Old 09-15-2013, 05:19 PM   #47
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,239
a. the wallet
b. in the back pocket
He has a vairwee good fwiend in Wome you know
Big Willy is offline   Reply With Quote
Old 09-15-2013, 11:52 PM   #48
Fogo72 OP
I Bleed Green
Fogo72's Avatar
Oddometer: 1,558
Fucked if I know Digga,
I'm just bored and need a challenge.
Lets just see.
ITS like an experiment, interesting ayy.
Nah my theory is more lower RPM grunt, higher gearing, try to save reving it to self destruction.
Fogo72 is offline   Reply With Quote
Old 09-15-2013, 11:56 PM   #49
Fogo72 OP
I Bleed Green
Fogo72's Avatar
Oddometer: 1,558
Originally Posted by Big Willy View Post
a. the wallet
Cost to machine the crank.
$500. just play money
We can all just buy KTM's and live a boring existence.
Old 09-16-2013, 12:31 AM   #50
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,239
We can all just buy cars and live a boring existence.
Fixed
Love your work btw. Been following it ever since you molded a seat to your bum.
Old 09-16-2013, 12:36 AM   #51
Doctor
Doctor's Avatar
Oddometer: 8,445
a star was born
http://advrider.com/forums/showpost....0&postcount=13
keep up the fine work Fogo
Doctor is offline   Reply With Quote
Old 09-16-2013, 01:09 AM   #52
KASUYAHO
Road Hog
Oddometer: 3,651
Thanks Troy for getting us back on track.
Back to how much power I expect to get out of this thing.
There are reports worldwide of 65hp KLX650's , But there is absolutely no proof as know one can produce a Dyno sheet. So lets be realistic here.
Kermits new engine,
KLX650C electric start in an "R" model bike.
Spec, 38hp at the flywheel
Kermits specs,
STD bottom end
The electric start engine runs an alloy barrel with a cast iron sleeve pressed into it instead of the chrome bore (Nikisil)
20" thou was shaved off the barrel to raise the compression
The bore is STD 650cc
Wossner piston
STD 40 vac carbie with a 150 jet
Port and polished cylinder head and major reshaping of the combustion chamber to dome it out more which would have lowered compression a bit hence the shave on the barrel.
STD valves
STD cams
STD exhaust header
Staintune muffler with no baffle
Kermits result on the Dyno was 45hp at the back wheel. The Dyno operator said a brand new CRF450R straight off the showroom floor will pull 46 at the back wheel. So not a bad effort. Does it feel like your riding a CRF450, NO. All Kermits power is made from 1500 rpm to 4500 rpm, real deep down lugging tractor power, which is what I wanted to ADV ride around the place with a 50 kg load on his back.
So being realistic here, mods that will be done
"R" model engine, lighter rotating parts, flywheel ect compared to the "C" engine
STD bottom end, bar the 3mm stroker crank taking it to 700cc
STD 650cc Nikisil barrel, unmolested, raised with a 2mm base plate shim to get away from buying a new custom conrod and keeping the rod angle lower.
100mm STD Wossner piston with 1mm shaved off the top.
TOTAL SEAL piston rings
STD cylinder head with exhaust ports polished only
Going to purchase a new Kehin 41mm FCR carb which we have never tried on one of these engines.
1/4 bigger dia stainless custom header pipe into the Staintune muffler
Adjustable cam gear timing, Manual.
Hot cams.
So what do you guys recon we can get out of this,
I was hoping 55hp, am I myself.
I took the car pics off as requested Fogo
Do it right 60hp.
1.5hp per CI easy
KASUYAHO is offline   Reply With Quote
Old 09-16-2013, 03:15 AM   #53
Fogo72 OP
I Bleed Green
Fogo72's Avatar
Oddometer: 1,558
I stripped down both swingarms today and took them to a mates place for bead blasting.
Not sure which one we are going to use, The "R" model swingarm is alloy and 2" inches shorter than the "C" model electric start swingarm.
I am thinking if I fit the longer swingarm it will lengthen the wheel base and give us better stability at high speed on the dirt as KLX's tend to get the death wobbles. A few runs up the Wanaaring road with both swingarms should tell us what we need to know. Yes the long swingarm will be no good in the single trail stuff, but this bike is not getting built for that.
Old 09-16-2013, 04:07 AM   #54
michael1968
michael1968's Avatar
Oddometer: 826
The longer one!
Loving the build thread btw.
michael1968 is offline   Reply With Quote
Old 09-16-2013, 04:11 AM   #55
mrwocky117
Oddometer: 171
Bead blaster
Watching this build with great interest !!
Been looking at buying one, what sort is it ( small cabinet type ? )and if you could post a photo of blasted swing arm when finished, cheers.
mrwocky117 is offline   Reply With Quote
Old 09-16-2013, 04:18 AM   #56
Fogo72 OP
I Bleed Green
Fogo72's Avatar
Oddometer: 1,558
That is the pics after the bead blasting, It is a medium sized cabinet type, bloody brilliant, just rips the paint off, doesn't like stickers or water coming through the air line from the compressor. Well worth the investment for sure.
Old 09-16-2013, 04:33 AM   #57
rjf
SBS's #1 fan in January
rjf's Avatar
Location: Gosford, NSW, Aust. Scrambler, 640Adv, 300EXC
Oddometer: 4,376
Considering the above to points, I reckon you might as well go all the way and stick a low rallye style racepipe on the beast
Central Coast ADVenture bike training courses and 1 on 1 lessons - For details Click HERE
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadslide, thoroughly used up, totally worn out and loudly proclaiming- WOW-WHAT A RIDE!
rjf is online now   Reply With Quote
Old 09-16-2013, 05:13 AM   #58
mrwocky117
Oddometer: 171
Still following
Cheers, great build.
Old 09-16-2013, 06:40 AM   #59
Team f5ool
troy safari carpente's Avatar
Location: "Pearl of the sound" - f5ederation of scandwegia
Oddometer: 20,444
I believe that Mick Goddard (rode the KLX 650R in both the1993 - won it - and 1994 edition Oz Safari's) looked at modifying the alloy 650R swingarm, to the same length specification as the 650C model, for exactly the reasons you mention. (straight line stability). although I don't know if he ever actually performed or ran the bike with that modification in competition?
I reckon the longer C swingarm will make for a better longdistance/high speed dirt tourer... which is what you are going for... no?
CONTENTS MAY SETTLE DURING TRANSPORT...
troy safari carpente is offline   Reply With Quote
Old 09-16-2013, 09:40 AM   #60
Earthscape
Have ya got a helmut?
Earthscape's Avatar
Oddometer: 352
Lets just see.
Ever consider more modest engine mods like Kermit, and then pair with custom gears to open the gear ratio spread to lower top speed RPM (money on transmission instead of engine)? I have no idea where to find someone with the tools and skills for this or the expense of custom gears, and I suspect it may not be cost-effective given the precision and treatment that the gears would need. The KLX seems to have more than enough low-end grunt to pull higher speeds at lower RPM, it would be really great with a wide-ratio 6-speed; or for that matter, even a wide ratio 5-speed.
"You do your own thing in your own time, you should be proud."
2004 KTM 950 ADV : : : : : : : 1998 Triumph Tiger
1999 KTM 640 ADV : : : : : : : 1993 Kawasaki KLX650
2007 Kawasaki KLX350S : : : : 1996 Yamaha XT350
Earthscape is offline   Reply With Quote
Times are GMT -7.   It's 02:43 AM.
