Old 09-17-2013, 01:31 AM   #76
Fogo72 OP
I Bleed Green
Fogo72's Avatar
Oddometer: 1,557
Originally Posted by Smithy69 View Post
Great project you've got going there Fogo. It will be interesting to see how all the re-engineering unfolds. Do the plans include any cylinder head work? Are they pretty good from stock? I would imagine that with an increase in swept volume by about 9%, it would be happy to take any gains in the inlet side of things, porting, valves etc.
Shhhh, no, I am gunna run outta money.
Plan is, get the frame painted and back home.
The KX250F forks are on there way from the States as we speak, then the frame will go to the machine shop with the front end to get it to fit in the head stock.
I need to buy a few more plastic crates and start cleaning some stuff up and get ready for the arrival of the crank.
Im getting excited about this build, there maybe a shed clean out coming up and going on Gumtree to make some cash. I don't think the kids rid that YZ85 any more.
Fogo72 is offline   Reply With Quote
Old 09-17-2013, 01:33 AM   #77
Aussie Steve
Aussie Steve's Avatar
Oddometer: 1,397
Not quite what you are looking for but at half the price maybe a better starting point for you.
http://www.perfect-fairings.com/en/p...ly-fairing_277
45 euro freight
Aussie Steve is offline   Reply With Quote
Old 09-17-2013, 01:45 AM   #78
Bathy
Trail Legend
Oddometer: 16
Originally Posted by Fogo72
The LHS crank main bearing now is discontinued and nothing matches up worldwide, this bearing is not great but it certainly doesn't have any pitting so if I have to run it I will. No choice really.
Cheers Fogo...
incorrect,
Kawasaki never sold it separately anyways, it's a made for oem item only.
read further to discover why....
the bearing you are after is an N208
http://www.astbearings.com/product.html?product=N208
the inner cone is the std width, 18 mm on the crank,
however Kawasaki grind the outer cone thinner, to fit the case.
I think it's 15mm from memory, but don't quote me.
mine flat spotted the rollers, and it wasn't till I pulled off the camchain drive gear, (marked it's exact position on crank 1st of course)
with a bit off heat I might add, it was on tight,
that I noticed the difference in cone widths.
I got a machine shop to grind down the outer cone of a std. N208-C3
heated the bearing and camchain drive up it hot oil, and whacked it togther.
been good as gold for the last 5 & 1/2 yrs.
I have a big bore project of me own going on as well Fogo,
posted in ya Team green thread....
http://advrider.com/forums/showthrea...6#post22303156
P.S. my other bike, which I've been told is an ex-thumpernats race bike,
has got from what i can tell a KX500 swingarm.
Alloy of course but longer than the R swingarm., and haven't got a C arm to compare.
not sure what year, been meaning to do a parts cross reference,
cause it uses the same bearings as the R.
Cheers, Let the good times roll
Bathy screwed with this post 09-17-2013 at 11:56 PM
Bathy is offline   Reply With Quote
Old 09-17-2013, 01:51 AM   #79
Fogo72 OP
I Bleed Green
Fogo72's Avatar
Oddometer: 1,557
Junior in training.
That's my boy! Future KLX700R pilot.
Fogo72 screwed with this post 09-17-2013 at 01:59 AM
Old 09-17-2013, 02:16 AM   #80
barra
trying to get there
barra's Avatar
Oddometer: 1,400
Bloody good stuff Fogo. I think I saw 150 on the clock. Was that your young lad pulling away?
barra is offline   Reply With Quote
Old 09-17-2013, 03:05 AM   #81
Fogo72 OP
I Bleed Green
Fogo72's Avatar
Oddometer: 1,557
Yes mate that was the young fella, I backed off at 150 and he left me behind, don't forget both bikes were fully loaded.
Old 09-17-2013, 04:08 AM   #82
rjf
SBS's #1 fan in January
rjf's Avatar
Location: Gosford, NSW, Aust. Scrambler, 640Adv, 300EXC
Oddometer: 4,376
Originally Posted by Oldfatbeerman View Post
When rjf last did condo on his 640 and remarked after the event that the next time he does Condo , it will be on his 300 .
Although if the they stick a 75km long road section in the 640 would get dragged outta retirment.
I think a KLX650 is around 40kg's lighter than a 640adv, so wouldn't be such a pig in the tight bull dust as a fuelled up 640.
I think the perfect clubman level condo bike is a 350exc/390 husaberg or a smooth powered 450, but really what ever enduro or adventure bike you have is fine - people have a ball and do well on everything from 200 2 strokes/250 four strokes up to GTinaus smashing us all on an xr600.
I think Lance Armstrong Described Condo the best
if it helps with the gearing fogo, I'm stupid enough to pin the throttle open riding along beside a barbwire fence and the top speed was 153 on the trip computer. (IIRC I was I was geared for 165km/h top speed) The course changes from year to year, but (other than the guys up the front of the race) a really high top speed like 170km/h + isn't going to be used much if at all, I think a top speed from 140-160 and better accelleration would be much quicker. (Oh, and a rider that's fitter and quicker than me )
Central Coast ADVenture bike training courses and 1 on 1 lessons - For details Click HERE
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadslide, thoroughly used up, totally worn out and loudly proclaiming- WOW-WHAT A RIDE!
rjf is offline   Reply With Quote
Old 09-17-2013, 04:28 AM   #83
panhead_pete
Oddometer: 1,128
Originally Posted by Fogo72 View Post
Does anyone in Australia have a mould for this fairing, KTM690 2007 -2008 - 2009.?
How sick would it be to ride around the streets on something like this but Green.
Funny you should ask that. Would a later one work?
http://www.advrider.com/forums/showthread.php?t=884115
More gear and still no idea.
panhead_pete is offline   Reply With Quote
Old 09-17-2013, 08:33 AM   #84
mtbbker
MtbBiker
mtbbker's Avatar
Oddometer: 82
Have you tried
http://www.perfect-fairings.com/en/p...rbon-fiber_274
or
http://www.omegafibre.net/carbon-fibre/
mtbbker is offline   Reply With Quote
Old 09-17-2013, 04:54 PM   #85
Myway
Myway's Avatar
Oddometer: 3,141
Do not take a KTM style fairing, just look for a KLX style fairing.
How about the Argentina style klx450 fairing.
RPM motos contact them.
It could be a JVO racing fairing, or replica
Myway screwed with this post 09-17-2013 at 06:19 PM
Myway is offline   Reply With Quote
Old 09-17-2013, 06:05 PM   #86
Myway
Myway's Avatar
Oddometer: 3,141
Search for fairing rally
https://www.google.nl/search?hl=nl&q...&tbm=isch&um=1
Search for carenado rally
https://www.google.nl/search?q=caren...&bih=925&dpr=1
this is what there is and what they make.
there are nice ones
Myway screwed with this post 09-17-2013 at 06:20 PM
Old 09-17-2013, 10:38 PM   #87
mtbbker
MtbBiker
mtbbker's Avatar
Oddometer: 82
there are nice ones
Sorry for the hi-jack but you just made my day with all that pictures of rally bikes, Now I am not going to get any work done for the day
Old 09-18-2013, 12:23 PM   #88
Myway
Myway's Avatar
Oddometer: 3,141
There so many pics in this forum on all the topics.
You see something intresting contact a inmate.
https://www.google.nl/search?hl=nl&q...L-mc0QWf1ICgAw
Old 09-18-2013, 10:52 PM   #89
Fogo72 OP
I Bleed Green
Fogo72's Avatar
Oddometer: 1,557
So proud.
Back to work for a couple of nightshifts.
Last night we had to go to the TAFE awards night where Junior picked up Apprentice of the year out of 120 kids in the Newcastle and Hunter Valley area for the Plant mechanics trade.
See what a bit of time in the shed with ya boys can do!
Cheers Fogo...
Old 09-18-2013, 11:59 PM   #90
barra
trying to get there
barra's Avatar
Oddometer: 1,400
Cheers Fogo...
Sounds like a proud dad. Onya junior.
Times are GMT -7.   It's 09:14 PM.
