Old 09-13-2013, 09:50 PM   #1
rgmax OP
rgmax's Avatar
Oddometer: 237
74 H2 resurrection
Started a thread on the Kawasaki Triples forum and thought I would also post here.
I'm starting the restoration on my 1974 Kawasaki H2 I bought back in 1977 from the original owner. It was the first motorcycle I ever owned.
The bike back in 1977
The bike had been sitting in my parents garage in Texas since 1981. I moved to California in 1987 and mostly forgot about it. I thought a few times about shipping it to California and restoring it back to original but that would be complicated since it had be heavily modified in the late 70s. The bike currently has a Denco Cobra 120 motor.
It also didn't help that during one of my parents moves all the boxed original parts were lost or throw away. These included the original exhaust system, air box, carbs, wheels and various small bits and pieces.
The bike is in pretty crusty condition so everything will need to be refinished.
The bike as it sat in my Moms garage.
It's finally home in my garage.
rgmax is offline   Reply With Quote
Old 09-14-2013, 12:38 AM   #2
LasseNC
XSessive!
LasseNC's Avatar
Oddometer: 1,075
More more more! :)
Old 09-14-2013, 08:26 AM   #3
rgmax OP
rgmax's Avatar
Oddometer: 237
Started the tear-down. The last time I touched the motor was around 1980-81. I had done a fresh re-bore because of an earlier piston seizure.
Left cylinder is missing its piston. I knew one was not installed but can't remember the reason why now. Probably just lost interest. At the time my buddies and I all had new Z1000s we were messing with.
Note Denco stamp and serial number.
Still looks new.....
Empty left cylinder. No rust.
Not sure what I'll end up doing with the Denco top end as I'm putting the engine back to stock spec. I already have a set of stock bore late model cylinders and heads.
Motor out.
Old 09-14-2013, 08:37 AM   #4
LasseNC
XSessive!
LasseNC's Avatar
Oddometer: 1,075
I'd store the Denco topend in a safe deposit box
Old 09-14-2013, 09:19 AM   #5
Spikester300
Roll Tide!
Spikester300's Avatar
Oddometer: 126
Looks like the port edges needs a good chamfer.
2007 Suzuki DL650 V-Strom
1976 Suzuki GT750 Waterbuffalo
Spikester300 is offline   Reply With Quote
Old 09-14-2013, 11:01 AM   #6
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,712
Are you planning on changing out the crank seals? The rust indicates you may need to do the crank bearing anyways.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is online now   Reply With Quote
Old 09-14-2013, 11:41 AM   #7
rgmax OP
rgmax's Avatar
Oddometer: 237
Yes the engine is getting a total rebuild. The crank seals can't be trusted after all this time.
I also need to bead or maybe vapor blast the cases. Anybody know a good place to do this in SoCal?
Old 09-14-2013, 12:27 PM   #8
LasseNC
XSessive!
LasseNC's Avatar
Oddometer: 1,075
If you are going to beadblast you should be painting the engine. Dirt/Oil will stick like a motherlover and will be hard to keep clean.
Old 09-14-2013, 09:34 PM   #9
rgmax OP
rgmax's Avatar
Oddometer: 237
This looks like a interesting possibly.
Vaporblasting
Old 09-14-2013, 11:14 PM   #10
LasseNC
XSessive!
LasseNC's Avatar
Oddometer: 1,075
Scooters? Two-strokes? Painted engines? Multicylinder? Sorry. I've given up on
you and your moms ever sending me parts pre-cleaned and ready for vaporblasting.
He seems like a nice guy!
Old 09-15-2013, 08:22 AM   #11
rgmax OP
rgmax's Avatar
Oddometer: 237
Everyone has their idiosyncrasies. Cleanliness is clearly his.....
Old 09-22-2013, 03:36 PM   #12
rgmax OP
rgmax's Avatar
Oddometer: 237
Made some progress with the tear down.
The frame has some issues that need corrected.
I had trimmed off the turn signal brackets, center stand and chain oiler mounts.
I also welded in some additional frame bracing that will have to be removed.
The missing brackets can't easily be recreated but I picked up a un-titled frame on eBay cheap. So with a little cutting and welding I can transfer the brackets.
I'm going to refinish the Lester's to their original finish.
Old 09-24-2013, 09:09 AM   #13
Prmurat
Prmurat's Avatar
Oddometer: 1,073
If you need I have a titled 1974 frame...
Prmurat is offline   Reply With Quote
Old 10-03-2013, 05:19 PM   #14
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 4,584
Wow, looks like a fun project. You had it set up pretty well for the day.
I'm in.
Mike
Cogswell Rides To Big Bend
See my airhead project here
Time Warp Vintage Motorcycle Club
The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED.
Cogswell is offline   Reply With Quote
Old 10-07-2013, 03:46 PM   #15
vernon dent
vernon dent's Avatar
Oddometer: 703
right on, another 1977 h2 pic. here's my with my then new bride.
diggin' the ironhead too....
I only ride 'em. I don't know what makes 'em work.
Oddball
vernon dent is offline   Reply With Quote
Times are GMT -7.   It's 09:04 PM.
