Old 09-21-2013, 09:06 AM   #16
skandero OP
skandero's Avatar
Oddometer: 125
Ta-da! Here I am!
So, the problem was in the faulty sensor. When I stripped her down I saw the oil on the pressure sensor. But anyway tested the pressure with a gauge.
It's 35 psi on idle (1400 rpm) and 42 on 6000 rpm. Right in specs! (0.8 min at idle and 35-50 on 6k).
Pleased, that the orange lady is fine)))
The shitty sensor:
Thanks for the help, guys!
BTW, can anyone tell me, what is "oil pump pressure relief valve"? Or the partnumber. My mechanical english is not enough here, I can't recognise this unit.
skandero screwed with this post 09-21-2013 at 10:23 AM
skandero is offline   Reply With Quote
Old 09-21-2013, 03:26 PM   #17
ICERIDER
Adventure Rider
ICERIDER's Avatar
Oddometer: 586
60038010133 PRESSURE PUMP HOUSING CPL
Price: 21.66 (Inc VAT at 20%)
To order, normally sent out in 2-5 days
Or another unofficial name 'oil pressure regulator'.
An official name in the KTM Service Manual is 'bypass valve' which fits in the 'oil pump housing' on page 5-8.
http://www.ktm950.info/how/Orange%20...acing_opr.html/>Here is a nice piece on servicing the bypass valve.
950 SE
WR250R
950 ADV
950 SE
WR250R
950 ADV
ICERIDER is offline   Reply With Quote
Old 09-21-2013, 04:01 PM   #18
skandero OP
skandero's Avatar
Oddometer: 125
ICERIDER, the link is broken (is this the link form the second post in my thread?), but I understood, what You ment. Exactly the same I thought. Looks like I'm not so dumb as I mean))
Old 09-21-2013, 07:28 PM   #19
ICERIDER
Adventure Rider
ICERIDER's Avatar
Oddometer: 586
Abudgeggggg! Sorry to nomad guy for fudging his link and knowledge! I knew I'd seen it somewhere and didn't check your other page. Yes that's the one. Looking on a UK shop it shows the part as an assembly with the new part number I showed you. Quite a low price I think too. If I was doing work on the engine I would replace that part at that price and revive the oil pressure.
How did you check the oil pressure anyway? If you managed to do that and you ride a KTM you are't dumb Amigo !!!
950 SE
WR250R
950 ADV
Old 09-22-2013, 11:17 AM   #20
skandero OP
skandero's Avatar
Oddometer: 125
Will post the report in 24h))) I've took some photos especially for ADVrider brothers)
UPD. That's easy to measure the pressure.
I used the adapter from the gauge kit called "AIST", the russian tool manufacturer (BTW: if You need, I can machine the adapter for the metric taps). It is just the same as the pressure sensor, fits extremely cool. The adapter instead of the faulty sensor:
1) the sensor with oil drops(((
2) Adapter in place (when You remove the sensor, there will be a tear of oil, just some drops. I placed a rag under the sensor hole):
3) Oil gauge is connected, it's time to place carbs right here))
4) On the idle
Sorry, no photos on the 6k RPM. But it's cool)
Feel free to ask anything) Hope, this thread helps anyone)))
skandero screwed with this post 09-22-2013 at 11:30 AM
Old 09-22-2013, 01:44 PM   #21
ICERIDER
Adventure Rider
ICERIDER's Avatar
Oddometer: 586
Very nice pressure test kit! I was thinking about a post an inmate made a few days ago. Suggested attaching a braided oil line from where the sensor fits on the engine and taking it out to somewhere easily accessable. You could then fit the oil pressure sensor (and an oil pressure guage). That way if you carry a spere sensor it's just a 10 minute job to change it. The worry from when the oil pressure light comes on can mess up a trip!
950 SE
WR250R
950 ADV
Old 09-22-2013, 06:35 PM   #22
Newbusa
Newbusa's Avatar
Oddometer: 624
Why not just leave the sensor out and replace it with a hose to a dash mounted pressure gauge?
2010 990R Adventurer.
2007 Tuono 1000R
Newbusa is offline   Reply With Quote
Old 09-22-2013, 07:30 PM   #23
ICERIDER
Adventure Rider
ICERIDER's Avatar
Oddometer: 586
Would be good to retain the oil pressure warning light, and have a guage as well.
A good thread HERE on guages etc.
950 SE
WR250R
950 ADV
Old 09-22-2013, 09:15 PM   #24
skandero OP
skandero's Avatar
Oddometer: 125
Yes, I plan to leave both the "idiot light" (and place it right in the line of view, somewhere on the windscreen top) and the pressure gauge.
- it's a good idea. The winter is long, I think, I will do this)
Old 09-23-2013, 06:02 AM   #25
ICERIDER
Adventure Rider
ICERIDER's Avatar
Oddometer: 586
I'm expecting one of these LED's in red any day. I plan to mount it on my SE in line of sight as an oil pressure warning light repeater.
950 SE
WR250R
950 ADV
Old 09-23-2013, 04:09 PM   #26
pdxmotorhead
pdxmotorhead's Avatar
Oddometer: 802
Some of the aftermarket gauges have the idiot lights integrated, so all you need is the sensor and the gauge has a adjustable low pressure set-point, autometer comes to mind...
Dave
Freedom is a delicate thing.
More easily lost than gained.
pdxmotorhead is offline   Reply With Quote
Old 09-24-2013, 07:44 AM   #27
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,440
How exactly are you planning on wiring this? It'd be anice thing to have.
SA
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 09-24-2013, 08:40 AM   #28
skandero OP
skandero's Avatar
Oddometer: 125
SA
Yes, please, if You have exact idea. I thought about welding the parallel wiring from the sensor, but it not seems to be a simple/reliable solution. But I don't want to cut off the native wiring harness...
Old 09-24-2013, 04:09 PM   #29
ICERIDER
Adventure Rider
ICERIDER's Avatar
Oddometer: 586
SA
OK, First thing is I don't have my SE to hand, it's a few thousand km's away in Santiago, but looking at the wireing diagram I see that there is a single wire going to the oil pressure switch...gn-gr (green-grey). Following that back I see it goes into pin 7 on the Multi Functional Digital Speedometer.
Without seeing whats up there at the moment, Im guessing I'll get access to the gn-gr wire somewhere near the speedo. I plan to break into that wire (cut) and add the LED in series, i.e. the power comes through the standard light, then through the inserted LED, and back into the gn-gr wire to the oil pressure switch. I can't see this causing any malfunction to it's brain unless someone knows differently. It could be that LED's won't work in this way because perhaps they won't carry the current through, in which case just add a normal light such as a tail light, but I'll try it. (Oh! just had a thought, how about a nice little 21W turn light mounted out the side of the mask pointed back at you?)
Choosing the place to cut the wire will depend on where the least strain is on the loom. Could mean finding a better placed run away from the headstock nearer the switch with less stress to make it more reliable.
I plan to do this next week so I'll let you know how it goes.
950 SE
WR250R
950 ADV
Old 09-25-2013, 07:38 AM   #30
Alleycatdad
Oddometer: 1,440
Please do!
SA
Times are GMT -7.   It's 11:50 PM.
