Old 09-16-2013, 07:39 PM   #1
Ian B OP
Fairing Manufacturer
Oddometer: 589
Britannia Composites Mirage 3 fairing for the GS1200's
He 'aint heavy - he's my brother !
The very popular Mirage 2 fairing ( for the GS650/700/800's) gets a big brother.
Clearly resembling the M2, this fairing has the same features of sliding screen, GPS mount dashboard and colour options, but is a bit larger all round. Screen reaches up about 12cm higher than stock and slides down for off road use. The mount is very sturdy and designed to take the 'rough and tumble'.
The fairing sells at $495CAD ( same as the M2) with options for a carbon finish dashboard and OEM colourmatch paint.
More details here : http://www.britanniacomposites.com/i...oducts/mirage3
Ian B
Ian B screwed with this post 09-16-2013 at 08:27 PM
Ian B is offline   Reply With Quote
Old 09-16-2013, 11:40 PM   #2
Hikertrash
Oddometer: 2,778
Finally
Hikertrash is offline   Reply With Quote
Old 09-17-2013, 08:54 AM   #3
Ian B OP
Oddometer: 589
Originally Posted by Hikertrash View Post
Finally
Better late than never ! The demand on the Mirage 2 set back the work on this one, but it's here now
Ian
Old 09-25-2013, 05:18 PM   #4
Twempie
Oddometer: 202
More photos please
Can you post some more photos? I'd like to see some of the dashboard, and how it looks from the riders perspective.
Twempie is offline   Reply With Quote
Old 09-25-2013, 06:07 PM   #5
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 9,768
Looks great
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is offline   Reply With Quote
Old 09-26-2013, 10:31 AM   #6
Ian B OP
Oddometer: 589
Sorry, we really should have taken some photos of the riders view - but didn't and the bike had to go back to it's owner. However, there are quite a few fairings on their way to owners in all corners of the world now, so I'm hoping to get more photos soon .
Cheers Ian
Old 09-26-2013, 11:30 AM   #7
Twempie
Oddometer: 202
OK No worries. It looks great BTW. Are you in Vancouver? I'm seriously considering one of these.
Old 09-26-2013, 01:42 PM   #8
Ian B OP
Oddometer: 589
Nearer the border than Vancouver, in Langley. I have some suggestions for you, so feel free to email me britanniacomposites@shaw.ca
Cheers
Ian
Old 09-26-2013, 04:55 PM   #9
Twempie
Oddometer: 202
Email sent.
Old 12-25-2013, 06:55 PM   #10
fjteal
Oddometer: 23
Anyone have one of these, really interested but can't find any reviews or pictures other than whats on Ian's site.
fjteal is offline   Reply With Quote
Old 12-26-2013, 09:10 AM   #11
Zander
Zander's Avatar
Oddometer: 194
Hi Ian,
On my friend GS1200 the light reflector melted on the low beam side.
In conjunction with the Mirage fairing, what aftermarket lights can be installed?
I will be making the modification on it's bike and we decided that we don't want to replace the light assembly with another original part.
Might as well install something more efficient. Any advise ?
Beginner's mind !
KTM 950
Zander is offline   Reply With Quote
Old 12-26-2013, 11:25 AM   #12
Ian B OP
Oddometer: 589
Originally Posted by Zander View Post
Hi Ian,
Well, the M3 'shrouds' the OEM headlight unit, so in a way, the lighting issue remains the same, whether there is a Mirage on it or not. I'm not that familiar with the OEM unit on the big GS and I haven't looked at it from the standpoint of using lights from our other fairings to produce a lighting alternative for either the boxer, or the F8. I'm quite surprised that the bulb actually melted the lens ! I can only reflect my own experiences that standard halogens burn very hot and a 35w HID conversion might be a consideration because they burn much cooler as well as dropping the power requirement and banging out more light. I'm sure this conversion has been done and you may find threads out there reporting the results, although be aware that HID conversion of some OEM lights doesn't work well because of bad focusing.
Hope this helps.
Ian
Old 12-26-2013, 11:37 AM   #13
Zander
Zander's Avatar
Oddometer: 194
Hi Ian,
The reflector is melted so bad that I will not be able to do a HID conversion. Cost of a new light assembly from BMW is expensive. I will probably end up spending close to original part for the light retrofit but at least it will be much better lighting.
Thank you for the reply and information.
Beginner's mind !
KTM 950
Old 12-26-2013, 12:53 PM   #14
Ian B OP
Oddometer: 589
Hi Ian,
Yeah, I think you are on the right track. It's a shame I don't have a GS here to look at it further, because I'm sure it wouldn't take much to mount up the new HID projector low/ Squadron LED Hi that we're fitting to the new 950/990 fairing and the amount of light on that is mind blowing !! The whole thing would still come in under the cost of the OEM Beemer unit !
If I can help with the lighting spec, if you go with a 'made up' unit, just let me know
Cheers Ian
Old 12-26-2013, 01:44 PM   #15
Zander
Zander's Avatar
Oddometer: 194
Hi Ian,
I would really appreciate if you can give me some info for the Squadron lights.
By the way, nice work on the 950 / 990 fairing. I am seriously considering it for my 950.
Beginner's mind !
KTM 950
Times are GMT -7.   It's 10:18 AM.
