Go Back   ADVrider > Riding > Regional Forums > Australia
Old 09-20-2013, 02:40 PM   #1
Cooge OP
R1150 gsa.
Cooge's Avatar
Oddometer: 44
R1150GSA Cracked brackets under instrument cluster
Just got back from Birdsville and Innaminka trip. After about 10 million corrugations the instrument and front beak became quite the wobbly. Upon inspection the small frame that loops around under the instruments was broken under the bolts, which were still done up tight. Hope this makes sense. Anyway wired and zip tied it up and got home ok although I blew the RHS fork seal as well.
My question is
1. What is this part called?
2. Can it be welded or fixed in situ?
3. If I take it apart, would replacement be in favour of repair with extra bracing?
Anyone had experience with this? My bike is a 11/03 build R 1150 GSA with servo brakes and ABS. she's no garge queen , has
85000 on the clock and gets used as it should. I love her dearly though.
Hope some one has some genuine advice out there! Thanks in advance.
Cooge
'Life's like that'.
Cooge is offline   Reply With Quote
Old 09-20-2013, 03:16 PM   #2
itsgunnahurt
Gravity Enhanced!
itsgunnahurt's Avatar
Oddometer: 1,971
Do you mean this part?
Have a look on one of the online parts fische might help.
http://www.maxbmwmotorcycles.com/fic...1&rnd=04302013
Strange you "blew" a fork seal. Might just be old age, I changed the seals on my 1150 at about 90k. Check for rust spots or nicks in the chrome leg. Fork seals are easy fix on the telelever front ends, there are no springs. Just fresh oil, don't need "fork" oil, my mechanic sold me a small bottle of 10wt, all good.
I hate it when the voices in my head go silent...
˙˙˙buıuuɐןd ǝɹɐ sɹǝʞɔnɟ ǝsoɥʇ ʇɐɥʍ ʍouʞ ɹǝʌǝu ı
itsgunnahurt is offline   Reply With Quote
Old 09-20-2013, 03:28 PM   #3
Cooge OP
R1150 gsa.
Cooge's Avatar
Oddometer: 44
Thanks for the reply, the part will be the fairing bracket. The tabs are broken off on both sides near the numeral 1 on the Max diagram.
Cooge
'Life's like that'.
Old 09-20-2013, 05:20 PM   #4
GodSilla
I did that.
GodSilla's Avatar
Oddometer: 8,000
If you know someone who can do neat welds, get it fixed, reinforced, a lick of paint and you're done.
Become a corporation - deny everything, then make counter-accusations.
GodSilla is offline   Reply With Quote
Old 09-21-2013, 03:05 PM   #5
Cooge OP
R1150 gsa.
Cooge's Avatar
Oddometer: 44
After looking at the diagram on Max's site that the way I will go first. Rang Southbank in stock for $220. Not as bad as I thought. Better get cracking!
Cooge
'Life's like that'.
Old 09-21-2013, 05:32 PM   #6
Kiwirich
Kiwirich's Avatar
Oddometer: 179
One option
You could try the BM Shop in Brisbane, Chris may have a spare.
Kiwirich is offline   Reply With Quote
Old 09-22-2013, 02:02 AM   #7
AlSheehan
AlSheehan's Avatar
Oddometer: 254
Hmm. I must keep an eye on mine. I've had it work loose before...
Al.
02 BMW R1150GS Adventure | 00 Montesa 315R Cota | 93 BMW R80
http://www.advrider.com/forums/showthread.php?t=1048372
AlSheehan is offline   Reply With Quote
Old 09-22-2013, 04:08 AM   #8
notsoslow
notsoslow's Avatar
Oddometer: 249
I took the frame off and got a skilled welder to weld it back together, no problems from then on.
notsoslow is offline   Reply With Quote
Old 09-30-2013, 01:49 PM   #9
Cooge OP
R1150 gsa.
Cooge's Avatar
Oddometer: 44
Thumb
Thanks Notsoslow, that's what I having done at the moment, with some strengthening and 5mm collars. Will see how it goes.
Cooge
'Life's like that'.
Old 09-30-2013, 02:31 PM   #10
slowbike smallpenis
Tester of Tooheys Old
slowbike smallpenis's Avatar
Oddometer: 19,844
www.beemerboneyard.com
Illusion is the first of all pleasures
slowbike smallpenis is offline   Reply With Quote
Times are GMT -7.   It's 06:49 AM.
