Old 09-20-2013, 03:05 PM   #1
cueball OP
should'a walked it first
cueball's Avatar
Location: lake serene, ms. at least it was 'til i moved in!!
Oddometer: 737
hid removal
i recently acquired a 2007 1200gs that has had both headlight beams converted to hid. the bulbs are way too far into the blue spectrum for me & don't really do a good job at night. my first thought is to go back to h7 lighting if not too involved or to go to hid bulbs that are more in the white (& more effective) spectrum. will the existing ballasts work with a whiter bulb?? what is most likely involved with returning to stock??
thanks in advance for any help!!
frank
frank
lake serene
ktm 950, r1150gsa, r1100gs
cueball is offline   Reply With Quote
Old 09-20-2013, 05:10 PM   #2
jzeiler
ADWrencher
jzeiler's Avatar
Oddometer: 109
Most of the kits now are very easy to reverse as they are mostly "plug and play" with connectors. I like the light from a 4300K bulb the best and the ballasts are independent of the bulb color temperature. If you have never messed with them there is a good pictorial post in here some where showing the install. Just have to hunt it down with a search.
Link to the thread for installation
John
2009 R1200GS (Gone)
2005 K1200LT
2009 K300GT
K4AN
jzeiler screwed with this post 09-20-2013 at 05:16 PM
jzeiler is offline   Reply With Quote
Old 09-20-2013, 05:13 PM   #3
GP1200
Oddometer: 379
Only thing you have to do is buy the two plastic screw- in caps which were likely drilled open to fit the HID rubber bushings. I think they're $5 each at BMW. Everything else should be attached by plastic ties. Cut them off and remove.
GP1200 is offline   Reply With Quote
Old 09-21-2013, 04:13 AM   #4
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,752
frank
The ballasts will work with any color bulb, you've just got to pay attention to watt ratings. Lower temperature HID = less blue light. I've got 4500k bulbs in my GS, they match my LED aux lamps well and provide LOTS of usable light.
If you decide to revert to Halogen, you'll probably just need the caps that fit over the back of the lamp assemblies.
Twilight Error is offline   Reply With Quote
Old 09-21-2013, 07:40 AM   #5
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,771
Exactly correct. I have the 4300 HID and while whiter, not at all blue.
Cups are $5, or tape them over with black gaffers tape or electrical tape.
Jim
Old 09-21-2013, 08:09 AM   #6
Iron Rey
Oh shit, not him!
Iron Rey's Avatar
Oddometer: 871
Jim
Agreed, I would switch the high beam back to an H7 and stay with an HID in the 3500-4500 range, I think you will be highly dissapointed with an H7 for the low beam.
2014 K1600GT Sport, 2014 S1000R (For Sale) 2014 HP4C, 2011 R1200R, S1000XR (ordered!)
I'm not a glass half empty or full guy, I am just happy to have the damn glass!
Iron Rey is offline   Reply With Quote
Old 09-21-2013, 11:09 AM   #7
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,545
HID lamp color (measured in Kelvin or K) is dependent on the metal salts they put into the lamp kernel at time of manufacture. To change the lamp color, replace the lamp with one of the same wattage but specify 4300K color. This is the lamp color used by the auto manufacturers who equip their cars with OE HIDs. This color provides the most lumens (light amount) in the wavelength best for the human eye. The high K lamps generate light in the UV range, not well detected by the human eye hence the eye fatigue and poor performance of your current HIDs.
If you revert back to incandescent lamps, you'll be disappointed and will give up almost 1/2 of your HID light putput...it will be like mounting a candle on your bike.
def is online now   Reply With Quote
Old 09-21-2013, 11:28 AM   #8
cueball OP
cueball's Avatar
Oddometer: 737
thanks for all the advice!! i may try the whiter hid bulbs before going back to h7's.
frank
lake serene
Old 09-21-2013, 12:15 PM   #9
JimVonBaden
"Cool" Aid!
Oddometer: 53,771
If your current bulb is too blue, it is technically whiter at something like a 6000K+. You will technically go yellower, though it will look white instead of blue.
Jim
Old 09-21-2013, 12:30 PM   #10
cueball OP
cueball's Avatar
Oddometer: 737
from that chart, i would say mine must be in the 8-10k range. seems like 4300 or 5000 would be good. where is the best source for just the bulbs?
frank
lake serene
Old 09-21-2013, 12:38 PM   #11
JimVonBaden
"Cool" Aid!
Oddometer: 53,771
They are pretty much made all in the same place. E-bay is fine.
Jim
Old 09-21-2013, 12:39 PM   #12
cueball OP
cueball's Avatar
Oddometer: 737
Jim
thanks jim!
frank
lake serene
Old 09-21-2013, 05:28 PM   #13
teomannaskali
teomannaskali's Avatar
Oddometer: 783
Bulbs alone cost almost as much as the kit itself...
Might want to buy entire kit. To keep spare ballasts.
teomannaskali is offline   Reply With Quote
Old 09-21-2013, 06:03 PM   #14
genka
SUV hater
genka's Avatar
Oddometer: 1,631
Jim
I installed HIDs on the foglights in my minivan. Although I specified 4300k, they are considerably bluer compared to the van's OEM HID headlights. Before that I tried 3000k, they sent me bulbs with yellow glass. Probably the bulbs themselves were high Kelvin value, because the light looked more greenish than anything else. You never know what you are getting from ebay...
Форум мотоциклистов в США http://www.xytopok.net/mvnforum/listthreads?forum=31
genka is offline   Reply With Quote
Old 09-21-2013, 09:04 PM   #15
JimVonBaden
"Cool" Aid!
Oddometer: 53,771
$27 HID kit from E-bay, high and low beam.
Jim
Times are GMT -7.   It's 08:51 PM.
