Old 09-23-2013, 03:31 AM   #1
SeikoKid OP
Oddometer: 58
Under seat battery ??
Would like to know more about how the battery for an R65 can be supported in the seat?
Mentioned have been slimline glass batteries but my research has shown they are expensive?
I am wanting the seat to remain flat to allow 2 riders. Is it possible? Are there any links please
SeikoKid is offline   Reply With Quote
Old 09-23-2013, 05:35 AM   #2
DaveBall
DaveBall's Avatar
Oddometer: 1,163
What is wrong with the original battery mount?
DaveBall is offline   Reply With Quote
Old 09-23-2013, 05:42 AM   #3
R100LT
Chasing 11
R100LT's Avatar
Oddometer: 631
Give me a few days and I will post the pics of hiding the battery in the air cover of my R65 . Been " pissing " down here .. wettest September in 90 years
BMW R100LT 93 BMW R100RS 91 BMW K1100LT SE 94 76 R90S
R100LT is offline   Reply With Quote
Old 09-23-2013, 06:04 AM   #4
sammm
Oddometer: 22
I've seen a few airheads where the battery rests in a 'dropped box' in the subframe. Just as though the battery is going to be hidden in a cafe cowl, but dropped 2" to make way for a bench seat. Looked good, and quite subtle. Can't find a picture of it at the moment, though.
Another option would be hiding it below the gearbox/swingarm. I prefer this option, personally, and would definitely be doing it if I were making my bike for 2-up riding:
http://www.bikeexif.com/bmw-r80-2
sammm is offline   Reply With Quote
Old 09-23-2013, 06:17 AM   #5
SeikoKid OP
Oddometer: 58
that would be great to see some pics please when you get time :)
Old 09-23-2013, 06:25 AM   #6
Sabre170
Sabre170's Avatar
Oddometer: 321
I made a little box (painted it black) for mine and mounted it under my seat. I'm still able to use my stock 2 person seat.
Sabre170 is offline   Reply With Quote
Old 09-23-2013, 09:33 AM   #7
big_mark
Oddometer: 44
Lithium batteries seem to be a popular choice. They are smaller though no less powerful than the stock battery. Weigh a lot less too, so you can fit them under a seat hump, for example, without messing up your bikes weight distribution.
big_mark is offline   Reply With Quote
Old 09-23-2013, 11:02 AM   #8
supershaft
because I can
Oddometer: 9,116
+1. Longer battery cables and most always moving the weight to a worse spot as far as handling is concerned. It's usually a loose/loose proposition but that is usually what going for a look gets you. Look at choopers.
Old 09-23-2013, 12:11 PM   #9
SeikoKid OP
Oddometer: 58
I like the sound of lithium batteries but they do cost . Some one elsewhere mentioned glass matt slimline batteries ?
I'd like to hide the battery under the seat to clean up the frame. I want it though to not be visible
Some great ideas mentioned here , especially the under gearbox method. here in the UK I would suffer with that due to the amount of rain we get!
Hidden away , nice n dry please
Looking forward to seeing the air box method :)
Old 09-23-2013, 12:55 PM   #10
Padmei
enamoured
Oddometer: 3,761
Here's what I did for Schmidt's one. The steel was a bit thin so made another with thicker steel & a tad longer so I could mount a main switch on it. I have a different seat on now which drops down lower hiding it a bit more.
I found those Motobatts are actually quite cheap for their benefits (for an off roadish bike anyway)
http://advrider.com/forums/showpost....&postcount=549
Padmei is offline   Reply With Quote
Old 09-23-2013, 01:14 PM   #11
Sabre170
Sabre170's Avatar
Oddometer: 321
1+
I like this. Very similar concept to what I did, but this is a buch better build than mine. I like the "wings" that hold it on the frame.....I used some electrical conduit holders, and seemed to work fine....not neary as clean of a look as yours.
Old 09-24-2013, 12:23 AM   #12
Padmei
enamoured
Oddometer: 3,761
Originally Posted by Sabre170 View Post
1+
Damn i'm a sparky & didn't even think about that. Thanks for the compliments - I don't often get them about my modifications so I'm taking it
Padmei screwed with this post 09-24-2013 at 12:58 AM
Old 09-24-2013, 07:40 AM   #13
_cy_
Oddometer: 6,443
anyone worried about cost of slimline AGM would not be a candidate for a properly sized LiFePO4.
anytime one moves from original battery tray/cables. be extra careful with positive side connections. this goes X10 for LiFePO4 batteries. they discharge violently at full tilt. heat generated are equal to Arc welding.
dead shorts on LiFePO4 installs on custom bikes are suspected of causing the fire that burnt it to a crisp.
Old 09-24-2013, 09:04 AM   #14
edray
cascadian
Oddometer: 225
stickers
diggin the stickers..
edray is offline   Reply With Quote
Old 09-24-2013, 10:08 AM   #15
Sabre170
Sabre170's Avatar
Oddometer: 321
Vorgoingon/vorwerkingon..... "Before Going On"/"before working on"? Is my horrid translation correct?
I call that a smart man's idiot switch.
Is that simply an inline battery cut-off switch? If so, how beefy (current rating) is that switch? I'd think that when starting the bike, you'd pull enough juice to toast that switch...no?
Times are GMT -7.   It's 05:25 PM.
