Old 09-23-2013, 06:01 AM   #1
catneck OP
Rabid Motorcyclist
catneck's Avatar
Oddometer: 406
noob observations & questions
Ok.
Just brought home a 2007 GSA. Setting it up to work for me. Read the "100 questions" thread.
Observations.
1. I've seen other GSAs with adjustable height seat bars. Mine has a single location f & r bar on its custom seat. Year issue or custom seat feature?
2. What is with the auxiliary light switch on the bars? I understand mid 07 went to the backside of the left control. Anybody else move this?
More coming as I think of them. Thanks.
3. Factory BMW plug is CANBUS. What are the troubleshooting procedures, as mine is DOA.
catneck screwed with this post 09-23-2013 at 06:54 PM
catneck is offline   Reply With Quote
Old 09-23-2013, 07:18 AM   #2
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,618
Custom seat
Foglights
? Yes...for '08 it's on the left switch gear...has anyone swapped '08 switchgear for '07? Probably...
"Ignorance is a powerful tool when applied at just the right time..sometimes even surpassing knowledge.." EJ Potter
Bill-66 screwed with this post 09-23-2013 at 07:53 AM
Bill-66 is offline   Reply With Quote
Old 09-23-2013, 08:38 AM   #3
catneck OP
Rabid Motorcyclist
catneck's Avatar
Oddometer: 406
Thanks. Picture
And what happened to JVB's post? It was here an hour ago!
Old 09-23-2013, 08:45 AM   #4
Norhasken
Tryin' to find my way
Norhasken's Avatar
Oddometer: 18,947
If the seat pan is from a BMW low seat, it isn't adjustable.
Ken you are awesome - "But when Obammer calls a dick sucking football player a hero for sucking dicks"
Norhasken is offline   Reply With Quote
Old 09-23-2013, 08:54 AM   #5
catneck OP
Rabid Motorcyclist
catneck's Avatar
Oddometer: 406
I think that is the answer.
Seller stated the seat pan was BMW and the PO recovered what must be a low seat. I thought the seat bars were full length (per the owner's manual), but it must be a low seat difference.
catneck screwed with this post 09-23-2013 at 09:02 AM
Old 09-23-2013, 09:14 AM   #6
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,618
You have two threads going..
http://www.advrider.com/forums/showthread.php?t=921957
Old 09-23-2013, 11:28 AM   #7
catneck OP
Rabid Motorcyclist
catneck's Avatar
Oddometer: 406
Originally Posted by VEGASGSA View Post
Well that explains it.the joy of mobile computers...
And should be fixed now!
Thanks.
catneck screwed with this post 09-23-2013 at 12:31 PM
Old 09-23-2013, 06:55 PM   #8
catneck OP
Rabid Motorcyclist
catneck's Avatar
Oddometer: 406
Added #3
Now looking for BMW plug help. Edited OP.
Old 09-24-2013, 09:12 AM   #9
LaurelPerryOnLand
Oddometer: 3,482
Originally Posted by catneck View Post
Ok.
Observations.
Just get a Powerlet harness and wire directly to the battery. 15 amp capacity vs. 5 amps with CANBUS.
Here's a 36" version:
http://www.powerlet.com/product/bmw-...harness-36/202
Read this as well:
http://www.powerlet.com/learningCenter/iCan
LaurelPerryOnLand is offline   Reply With Quote
Old 09-24-2013, 06:52 PM   #10
catneck OP
Rabid Motorcyclist
catneck's Avatar
Oddometer: 406
Thanks. Will bypass the 5a CanBus wiring and replace the plastic socket.
Old 09-24-2013, 07:54 PM   #11
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,618
Install CenTech under seat..wire Powerlets to that...Depending on how you set up Fuse block..you can trigger it off the key..so it can't drain your battery if you leave something on..
My $.02..
Fuze Block
CenTech
Old 09-26-2013, 04:32 PM   #12
Ride4Coffee
Ride4Coffee's Avatar
Oddometer: 211
Also worth considering is the Twisted Throttle PowerHub2
http://www.twistedthrottle.com/power...or-motorcycles
(I'm not connected to TT in any way, except for having bought the PowerHub (1) only month ago )
IBA# 57940
Need the 90mm bolt for your Kaoko?
Ride4Coffee is offline   Reply With Quote
Times are GMT -7.   It's 04:19 AM.
