Old 09-23-2013, 03:22 PM   #1
ElRod OP
4<2
ElRod's Avatar
Oddometer: 293
Dont Use ...
Gunk Engine Degreaser anywhere around your brakes.
Yes, I screwed up and decided to wash the bike yesterday. Before beginning I notice large amounts of chain lube that had been collecting on the rim, spokes, swingarm, etc. Hmmm, I have a can of Gunk so I apply liberally to these areas. I know the rear brake is getting some on it too but hey, this is degreaser and should be OK. Wrong. After rinsing and washing I go for a short ride to dry things off and notice it's not stopping as normal. Speed up, try the fronts by themselves, OK. Repeat using only the rear and hardly nothing, try harder and cant even get the rear to lock and you know how easy that should be to do.
Remove the pads, soak in brake cleaner, deglaze with 60 grit, touch up the rotor with 180, wipe down with brake cleaner and re-assemble. No better, the Gunk must have saturated the pads.
I have some Galfer 1054 blacks on the way. I noticed on the KTM fiche the OEM's were twice the price. Are they that much better?
ElRod is offline   Reply With Quote
Old 09-25-2013, 04:04 PM   #2
ElRod OP
4<2
ElRod's Avatar
Oddometer: 293
Well, that was a bomb. Without all the extraneous details, what is the collectives opinion of the choice of brake pads?
Old 09-25-2013, 04:11 PM   #3
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,409
Good pads.
Thanks for sharing your experience with us, too!
2012 KTM 990 Adventure
Chuckracer is offline   Reply With Quote
Old 09-26-2013, 01:46 AM   #4
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,185
EBC HH sintered, these are as good as the oem but cheaper.
Or some Galfers black (I've used the green ones as well, good but don't last very long). Haven't tried the Gold on the 990.
The OEMs seem to last the longest and are excellent.
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 09-26-2013, 07:07 PM   #5
WillyD
Just Relax
WillyD's Avatar
Oddometer: 10
Heat it
Hey ya'll, I'm a noob to this so please forgive me if I've screwed up trying to reply, but I've lurked long enough and feel like sharing some of my limited knowledge.
A trick to salvaging oil/chemical soaked brake pads: pliers to hang on to them, good ol' propane torch, heat 'em until all "unwanted juices" quits bubbling out, let cool, and brake clean rotors and you're done.
WillyD is offline   Reply With Quote
Old 09-26-2013, 10:46 PM   #6
Dustodust
Dustodust's Avatar
Oddometer: 957
thanks for that tip !
makes sense to sweat out any embeded hydrocarbons with extreme heat
from a cloud of dust we race, then into the dust we return, across the finish line
04 KTM 950 S
04 KTM 525 EXC street plated
Old 09-27-2013, 03:51 AM   #7
ElRod OP
4<2
ElRod's Avatar
Oddometer: 293
Thanks, I'll try that since KTM Twins is being a bit slow with my order.
Any chance that would harden the pads damaging the rotor?
Old 09-27-2013, 05:30 AM   #8
keener
Speed changes you.
keener's Avatar
Oddometer: 945
You might have send grease remover into your rear bearings and the swing arm bearings. Keep an eye on them.
You may be able to save them by repacking them. Rear besrings are easy to get to.
04 ADV 950
keener is offline   Reply With Quote
Old 09-27-2013, 12:10 PM   #9
WillyD
Just Relax
WillyD's Avatar
Oddometer: 10
If you think about how hot they get under heavy use, I don't think a propane torch will get that hot. I've seen pics of red hot pads on cars, plus I've done this many times with no ill effects.
Old 09-27-2013, 02:44 PM   #10
ElRod OP
4<2
ElRod's Avatar
Oddometer: 293
Thanks WillyD. It's a cinch getting the pads out (push the caliper back a little, remove two clips, pull the pin, take the pads out) I wish all maintenance were that easy on the beast !!! So, I torched 'em before going to work this morning, one actually caught on fire for a few seconds. I kept the flame on them till they quit smoking. Had a cup of coffee while they cooled, put them back in, rode to work, and voila brakes again. Figured there was nothing to lose and there are new pads on the way. Thanks again.
Good call Keener, I will check the bearings and re-pack while they are out. I would have thought these were sealed bearings?
Old 09-27-2013, 07:22 PM   #11
WillyD
Just Relax
WillyD's Avatar
Oddometer: 10
You're welcome, glad I could help. I've picked up SOOO much info on here, now it feels good to contribute.
Katie Emm, age:'13, occupation:Baja
Old 09-27-2013, 07:36 PM   #12
ADVill
Oddometer: 609
Um...brake cleaner?
'08 990 Adventure Orange of course
'00 520 EXC
'14 500 XCW
ADVill is offline   Reply With Quote
Old 09-27-2013, 07:49 PM   #13
WillyD
Just Relax
WillyD's Avatar
Oddometer: 10
Originally Posted by ADVill View Post
Um...brake cleaner?
Similar to spray carb cleaner, but brakes down oil and other oily chemicals and leaves no residue(if you use enough). Most auto parts stores sell it.
Old 09-27-2013, 09:12 PM   #14
ElRod OP
4<2
ElRod's Avatar
Oddometer: 293
Um...brake cleaner?
Are you asking if I used brake cleaner or what brake cleaner is?
Times are GMT -7.   It's 04:52 AM.
